Question about M-Audio Oxygen 25 MIDI Controller
Usb port on the back has broken.
When the usb wire is pluged in, it is very loose. this keeps it from turning on. can i possibly take it apart ,myself and replace this peice without hurting the electronics board?
How do I fix my Loose USB port on a midi keyboard?
If the port is still intact then it might just need to be resoldered. USB ports however to get strained and basically fall apart. Purchase another and solder it to the board. If you are not confident about doing this take it to your local Yamaha service centre.
HomeContact Us About UsAll CategoriesAmplifiersBanjoBaritone Horn...
If using link below please suply model number so correct part can be ordered. HomeContact Us About UsAll CategoriesAmplifiersBanjoBaritone Horn...
Jul 01, 2014 | Yamaha Portable Keyboard with 61...
I have a crate gx140c guitar amp. When I plug in my guitar there seems to be a Problom with the the input and I get no sound. Is this something I can repair myself or must I take it to a technition?
If the socket you plug into is loose, there is likely a broken wire or a broken solder joint or board. It is not beyond the abilities of those who have some mechanical ability. Just have some patience, do not force anything, and if you have a doubt how things might go back together- take lots of pictures that show details and placements.
Jun 10, 2012 | Music
How do i fix the usb port on oxygen 49 it seems to be loose . the keyboard powers on but is not being recognized.
The usual problem of these not being recognized is improper installaation or missing the driver software in the computer. The jacks sometimes appear loose but that can be normal. If you wiggle the jack and there is marginal connections, usually the computer will respond with the USB found and the disconnect tones. If the USB cable has been yanked, then solder could have been broken at the connector. Opening these units one has to be very careful to not damage the cables between the halves of the shell... also keeping track of the screws and type is a must.
Sep 07, 2011 | M-Audio Oxygen 49 USB Midi Controller
I have an M-Audio Keystation 61es. Lately I've had random loss of power through the USB2.0 cable. The cable still powers my other M-Audio products, so the issue is the Keystation. It is possible...
I have the 88 key ones and powering via the USB is marginal... IF you have a place for an adapter, use one, as the computer USB is limited to 1/2 amp and OFTEN they limit at a little less and then the keystation is not reliable...
Aug 30, 2011 | M-Audio Keystation 61es USB MIDI...
I have a kb 100.sometimes when i plug guitar in,the volume is really low.if i wiggle the jack it will come back to normal.i thought i might of been the inputs,till i pluged a microphone in(different...
The solder at the connector may be broken loose or a circuit board could have a crack OR the jack may be broken... this is a common problem because the users trip over cables yanking the jack sideways. Take in for repair if you are not electronically adept.
Jul 20, 2011 | Peavey Kb2 1x10' Keyboard Amplifier
I've got a Casio Privia (PX-400R) keyboard and it seems that the pedal jack has gone out. It's the 3 pedal jack circuit board. I took the keyboard apart almost completely to take a closer look at the jack...
Hi genoness1,
If you noticed that the pedal works on and off depending on the jack plug positioning, it is because the jack is already broken loose from the solder on the board. If the pedal that you are using can normally open as most or normally closed like Roland types, you can still replace the loosed jack. Unit has to be opened and correct jack replaced.
Hope it helps.
Thank you for using FixYa.
Apr 19, 2011 | Casio Privia PX3 88Key Portable Stage...
Guitar cable was under the amp, i picked up the guitar and it pulled the jack. it picks up static but not sound
The cable has a broken wire. If it's the type cable which allows unscrewing the jack, take it apart and look for a loose / broken connection. Repair would be to solder it back. If the jacks on the cord are the molded type, the most practical solution is to replace it.
Charlie
Feb 21, 2011 | Epiphone Les Paul 100 Electric Guitar
Need to replace usb port,
Try a local computer shop that does repairs. You will have to unsolder the old port and take it with you to get a match.Also a good electronics parts dealer should have one or be able to order one for you.
Sep 01, 2009 | Tascam 2488mkii 24 Track Recording...
Light indicator is on
Try changing the battery, if it doesn't help, some possibilities are:
- dirty contacts or a broken wire on the footswitch
- a broken wire from the distortion output to the output plug
- a broken wire elsewhere in the unit (e.g. potentiometers or rotary controllers)
- a bad input / output level or other potentiometer or rotary controller
- a burnt out component (a bit unlikely, but possible, and it could be anything)
- a bad connector contact inside the unit
- a bad pin solder contact on ANY of the components inside the unit (wires, connectors, switches, jack plugs, resistors,variable resistors, trimmers, diodes, capacitors, transistors, ICs, etc.)
Broken wires / badly soldered pins need to be resoldered, but if there is damage to any of the components, they wil probably need to be replaced.
I hope you can find out what it is.
regards
3rq8 (Triarcuate)
Jul 26, 2009 | Boss Mt 2 Metal Zone Effects Pedal
M-Audio Oxygen 25 MIDI Controller Logo
41 people viewed this question
Top M-Audio Music Experts
Matthew Spark
Matthew Spark
Vito Vacirca Jr.
Electro Med Services...
Are you a M-Audio Music Expert? Answer questions, earn points and help others
