Question about Maytag Refrigerators
ICE BUILDS UP IN BOTTOM OF FREEZER
MODEL #MFF2558VEB4
IrishDruid
  • 2712 Answers
SOURCE: freezer drain line freezes up
Check to see that the thermostat setting are correct. If the freezer temperature is too low and the fridge section is kept high, then the cold air from the freezer does not circulate properly causing the ice build up in the freezer. The freezer compartment is where all the cold air in the fridge is created, and its blown from here to the other compartment by the evaporator fan. Ideally, the freezer should be about 10F and the fridge should be 35F. Remember that any changes in the thermostat controls takes upto 24 hours to take effect.
If you find that the freezer drain is freezing, you can try adding some salt to try to melt the ice. Or carefully poke through it using a chop stick or thin blade screwdriver. Be careful not to damage the tube. You can then flush this out with hot water.
You can even install a defrost drain strap kit to prevent drain freeze ups...In any case, I'd recommend that you get a profession to asses and diagnose the problem.
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 05, 2008
freetek
  • 5568 Answers
SOURCE: ice build up on bottom of freezer
For units with automatic defrosting, there is a drain, sometimes concealed, for the defrosted ice (water) to drain into a removable pan under the coils below the two compartments.
I suspect this is clogged with bits of debris and preventing the melt-water from dripping into the pan.
Check under your ref./freezer behind a trim grill for this pan and check the condition of it; overflowing or empty.
Normally, the fan that blows ambient air through the coils keeps this pan dry-to-moist.
It's fairly shallow so if your ice maker is leaking it will overflow but it should normally only be wet for a short time after the defrost cycle.
If it is pretty dry, note which side is wet. If it is wet under the freezer section, the clog might be loacted there.
If you do not see any holes that could be a drain in either side of the fridge, you could have a more serious problem trying to free it.
Each liner is made as one piece to help keep the inside free of dirt traps but there may be access panels and if they are found low and in the back, they may be intended to access a drain.
If you are lucky enough to find a hole toward the bottom, you should be able to free the drain.
Depending on the location for access, you should be careful poking anything too stiff (like a screwdriver) into it as the coils could be damaged.
Something like a piece of 18 gauge copper wire would be better.
Posted on Aug 31, 2008
SOURCE: maytag side by side, bottom freezer compartment had daily ice build up
I had the same problem with mine a couple of months ago. There is a drain which gets plugged. You have to remove the contents of your freezer, and then look at the back area of the freezer. The panel that's on the back is removable. Once it's removed, you will see a drain at the bottom. Mine was clogged up with debris, and was covered with ice. I poured warm water over the drain, soaked it up...did this a few times to melt the ice, then I worked at cleaning out the drain. Mine wasn't plugged too badly, I ended up having to blow air through the drain using my air compressor, to be positive that it was clear of debris. You could poke something down the drain, but it won't go very far because there is an elbow on the drain tube(visible on the backside of the unit itself)
If you get it cleaned out, it should be fine. Mines been great ever since I cleaned mine out...no more puddles on the floor.
Posted on Feb 18, 2008
Sea Breeze
  • 4654 Answers
SOURCE: My LG GR-349SQF freezer keeps getting ice in the very bottom
I believe your defrost condensate drain is blocked with ice or other foreign objects. Could you also double check the model number? Thanks, Sea breeze
Posted on Dec 29, 2009
  • 66 Answers
SOURCE: Build up of ice on bottom of LG fridge freezer
water drain clogged !
see this page for a fix, it might suggest a fix to your frig a s well
Avi
Posted on Jan 13, 2011
My maytag fridge model# mff2558veb4 ice maker is not making ice
Is temperature cold enough in the freezer .if it is cold enough can be water valve or ice maker unit
Mar 08, 2015 | Maytag Refrigerators
Tdc18paaaww leaking ice buildup
Is this auto-defrost model? Usually, heating element that defrosts the ice in back of freezer can go bad. How old is the model?
Dec 29, 2013 | GE Profile 22.2 Cu. Ft. Bottom-Mount...
Ice builds up at the bottom
Does your freezer have an ice maker? Possibly slight over filing.
Apr 12, 2013 | Bosch KGU6655
Water in bottom freezer
Sounds like possible defrost drain. Water builds up over time. Need to pull evap cover and see if ice is build up in tray. If so defrost drain, should fix issue
Aug 24, 2012 | Maytag MBF2258XEW
Dec 29, 2009 | LG Refrigerators
Model 363.582 62 894 Our freezer is frost free. There is heavy ice build-up. How do we get rid of it?
Option1: Unplug refrigerator and wait for it to melt. This will take a long time.
Option 2: Remove the rear and bottom panels from the freezer. Carefully chip away the ice. Use a hair dryer or hot water to melt the ice in the coils and drain.
If the ice builds up quickly again, test the defrost circuit and repair as necessary.
Nov 01, 2009 | Kenmore Refrigerators
Kenmore elite fridge. Bottom freezer ice builds
You have a bad defrost system on this unit, that's why you're freezing up. Call us with the model number and we'll get the correct part out to you right away. We hope to hear back from you soon.
Oct 09, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerator doesn't defrost
theres a defrost control on the unit that is probebly bad. its in the upper right of the refrigerator aand depending on the unit is either solid state or mechanical
Mar 26, 2009 | Kenmore 53342 / 53344 Side by Side...
Refrigerators Logo
59 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
