Question about Bosch Nexxt WTMC 6500 Gas Dryer
Remo front panel on Bosch Nexxt Premium Model #WTMC6500UC-01 gas dryer
Removing the front panel to access the gas valve.
SOURCE: Bosch nexxt 500 series dryer
I have a Siemens dryer and few days ago it stopped heating, but the drum rotates. The problem was because of a safety reset button that went off. On the Siemens (WT dryer series), it is a red button behind the dryer.
Press the red button and it will restart. I might have started a fire, if not for this safety switch.
A similar reset button must have tripped on the Bosch dryer.
FYI: Remember Bosch and Siemens share their technology.
Posted on Aug 31, 2008
SOURCE: Squeaks from drum area during operation
We have a Bosch Nexxt dryer and it, too, squeaks during operation. We have not been able to find a permanent solution for this problem although we've had the repairman come out 3 times now. We have however found a temporary solution that lasts for about a week. We spray Static Guard (in an aerosol can) in the inside lining of the dryer... kind of in the lip of the front. (You shuld be able to feel it if you put your hand right inside the door.) We've just been spraying the static guard all the way around that area and the squeaking stops! Hope this works for y'all. May not be permanent but at least it stops the annoying sqeaking!
Posted on Jan 18, 2009
hunter19_46m
  • 7482 Answers
SOURCE: The dryer (Bosch Nexxt 500) makes a loud grinding
The noise could be your drum rollers need lubricant or replacement.
When the drum rollers get flat spots on them they will make a bumping/thumping type of noise.
The grinding noise sounds to me like the drum rollers are in need of lubrication.
Posted on Sep 26, 2009
Ranglo
  • 1194 Answers
SOURCE: Bosch Nexxt 500 series dryer, E:01 and lint light
This indicates the sensor near the lint filter gets too hot. This is usually caused by bad air flow.
Try running the unit without the vent hose attached. If the problem goes away the problem is in the ducting.
You may need to have it cleaned out. May be lint filter is clogged due to the use of dryer sheets or fabric softener. You can try to clean the filter with Windex.
If neither one of this suggestions resolves the issue there may be a problem with the sensor, there may be heat escaping somewhere within the dryer. This is only resolved by technician.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
Posted on Jun 27, 2010
  • 39 Answers
SOURCE: Where do I find the
Have a Nexxt 3300 and believe yours is about the same so yes, several screws to remove from the back. Top also has to come off because two screws to the back are under the top. And for the top to come off the control panel has to be pulled away. Only four screws under four white caps to remove for panel to be loosened. The top is attached with two screws in the back and four nylon clips under the top. The red reset button will be easy to see after removing the back. It is attached to the heating element housing. It is not hard to do, just a pain to get to the reset button. Link to Bosch appliance website with give you a diagram to help. http://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/us/prodp.htm?prod=WTMC632SUS%2f02&ESHOPTYPE=A Good luck.
Posted on Mar 02, 2011
I NEED SERVICE MANUAL FOR BOSCH NEXXT 500 GAS DRYER
Hi.
I am sorry but unfortunately I could not find the manual for Nexxt 500 gas dryer in my database. The full model number may help me to find the file more than the model name.
A manual for Bosch gas dryer is available in this forum. Subscription to the forum is free: http://applianceguru.com/view_topic.php?id=21241&forum_id=19
When you ask for the manual always include the full model number(e.g.WTMC332SUS ). There are different Nexxt 500 models.
Regards.
G.
Nov 24, 2011 | Bosch Nexxt 500 Dryer
Trying to locate the ignitor on a bosch nexxt dryer..........looking through the round hole on the bottom left.....haven't found it yet. any help? tx
Welcome to FixYa.
The ignitor and burner assembly/burner tube are accessible from the rear and the rear panel must be removed.
i.e.
Once that has been removed, you'll need to remove the rear drum support & drum.
i.e.
Then you can pull the drum assembly out...Now you should see the motor and burner components. The ignitor is partially hidden via the burner tube, but is pointed out in the image below.
Hope that helps you identify and access the ignitor for your Bosch WTMC dryer, good luck.
Regards,
Macmarkus :)
Feb 17, 2011 | Bosch Nexxt WTMC3521UC Gas Dryer
Bosch Nexxt wtmc6500uc dryer. We receive an e01 error with every load and now cannot run the dryer at all. The vent is less than 5' with one bend, we clean the filter with every load, we've replaced the...
This was a previous post, but it may work for you.
A friend of ours has a bosch gas dryer and she had the same problem. She called the Bosch repairman and he sprayed the lint filter with Greased Lightning to clean out the tiny holes in it. He charged $100 and left. He said it would take care of the problem. Has not had any problems since. http://www.greased-lightning.com/ It is worth a try.
Feb 12, 2011 | Bosch Nexxt WTMC 6500 Gas Dryer
I need owners manual for bosch nexxt premium washer and dryer
Unable to read the display. The letters are no longer readable.
Jun 21, 2010 | Bosch Nexxt Premium WFMC6400UC Front Load...
Noisy; how to remove circular service access panel on front?
If you are referring to the filter, then unscrew it anti-clockwise to remove and clean.
Or if are referring to filter access panel, thrn it it could be a drop down flap, or press the flap to. release.
Trust this is the info you are looking for.
Jan 30, 2010 | Bosch Nexxt WTMC3521UC Gas Dryer
Bosch washing machine show E;04 plugged drain hose or pump
Remove cover to gain access to water pump, low rightside of front panel. Clean water pump. You should be good.
Jan 31, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
No LCD Display
they can fail try writing a letter to the manufacturer,if there a good company the will help.
Feb 11, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch Nexxt WTMC 6500 Gas Dryer Logo
104 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
