Question about LG Washing Machines
How to remove tub of LG WF-T7070CT washing machine
drsn
  • 42 Answers
SOURCE: I KEEP GETTING A dE
you will need to replace the door sensor, this error will appear until it has been replaced. it is inside the unit and pretty much hard to get to if your not familiar with workin on it. take it to an LG tech or some one whos familiar with it..........
good luck LG's are very sensitive.
drsn777@hotmail.com for more info.
Posted on Dec 15, 2008
SOURCE: Dead LG WF-T8016TP washing machine
Solution # 2 worked for me. I used a 15A "fuses for microwave ovens".
item bar code 0 68938 90277 3. Cost $ 3.00
Thanks
Posted on Apr 26, 2009
  • 4 Answers
SOURCE: lg wf-s6607tc
This is probably a lid cover open protection. Check to see if there is a magnet on the cover, positioned almost to centre (slightly to the right) at edge of the cover. There is some sort of plastic catch to house the magnet. If it is not there, place a magnet at the corresponding area on the washer where the plastic catch will touch when the lid cover close.
Posted on Sep 09, 2009
SOURCE: Clean LG WF-T652a Top Loader Washing Machine
I have this problem too and I solved it easily !!!!
I hypothesised that something was blocked by dried up lint/silt. So I filled the machine with very hot water and also poured hot water down the lint filter outlets. I left it for 5 minutes and then started a wash cycle - and the water now comes out of the lint filter ducts. ! :-)
Posted on Jun 19, 2010
jyackle5
  • 8197 Answers
SOURCE: MANUAL FOR LG WASHING MACHINE,
You can get the manual on the link below. Just click on where it says it is free top right.
http://safemanuals.com/user-guide-instructions-owner-manual/LG/WF-T653A-_E
Good Luck and please rate 4 thumbs up for the free answer
Posted on Sep 06, 2010
I have a lg top loader washing machine model:wf-t1391tp when wasing and rinsing it makes a huge grinding and crackling sound like is going to brake something underneath motor or gearbox.
Check whether the inner rotating drum is contacting the stationary tub.
The other problems that cause this condition is the clutch assembly and or the motor drive system.
Check both assemblies for security and free movement of rotating parts.
Check also the tub supporting dampers for condition.
Feb 23, 2016 | LG Washing Machines
The Tub Clean function never ends
why do you use tub clean function, we have never had the need to reclean the tub having just run hot detergent and water thru it .
Oct 04, 2015 | LG WM Washing Machines
Wash a sheep skin cover now the machine will not drain water as it usually did...it is an LG WF-T7016PP
The hose from the tub to the pump or from the pump to the drain hose is blocked, remove and clear blockage.
Aug 19, 2013 | LG WFT1071TP Top Load Washer
Dear expert of LG WF-F783PC (washing machine). i am using an LG washing machine model LG WF-F783PC.its giving a warning alarm after 3-5 seconds of operation (wash & spin mode)
Possible that the inlet flow is low , check the inlet valve and filter. Also try using the manual settings and if all the cycle works well then it is possible that the fault is with the controller unit or a possible errors from the level controller or the inlet valve.
It is best to remove them , check reset after cleaning.
Nov 02, 2011 | LG WFT1071TP Top Load Washer
Where does the fabric softener and washing powder go in the LG WF-F5207PC 5.5KG top loading washing machine?
Put powdered detergent in the box at the back of the opening of the washer (opposite the control panel when the lid is open). If you use a liquid detergent, dilute it 1:1 with water and pour into the bleach dispenser at the front left of the washer. The fabric softener dispenser is near the bleach dispenser but a little closer to the tub and towards the middle of the left side of the unit. As with a liquid detergent, dilute 1:1 (30ml:30ml) with water before pouring into the dispenser.
If the fabric softener dispenser isn't working, add the fabric softener in the final rinse.
The manual for the washing machine is available here: http://safemanuals.com/user-guide-instructions-owner-manual/LG/WF-F5207PC-_E . You will need to review the unit or enter a security code.
I hope this helps.
Feb 13, 2011 | LG Washing Machines
My LG washing machine WF-950 had stuck with coin.Its make the water can't get out manually and automatically. How do i get out??
did you try little door at bottom left of machine? there is little hose in there that drains tub or haul it outside and unscrew filter.
Apr 18, 2010 | LG Washing Machines
LG WF-T753A Top Loader washer hot water inlet valve
Just found this whilst looking for known issues with my machine as the cold water won't stop when filling.
http://safemanuals.com/user-guide-instructions-owner-manual/LG/WF-T753A-_E
Aug 25, 2008 | LG WFT1071TP Top Load Washer
Washing Machines Logo
44 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
