Question about GE Zoneline Deluxe Series Cooling & Electric Heat Unit AZ25E07D3B
Ge zoneline az22e09d3bm
Need a wiring diagram
2 Suggested Answers
ACTECH
  • 80 Answers
SOURCE: I WANT TO BUY THE UNIT WHICH CHANGE HEATING AND COOLING AND TEMPERATURE UNIT FOR GE ZONELINE
WITH ANY OF THESE UNITS YOU CAN WIRE AN EXTERNAL THERMOSTAT WICH WILL ACOMPLISH THIS, JUST MAKE SURE YOU PURCHASE A T-STAT WITH A HEAT / COOL AUTO CHANGE OVER.
Posted on Jan 14, 2008
Why is there a ***** smell?
I worked extensively on GE Zoneline AZ Air Conditioners and Heat Pumps while a Maintenance Superintendent at a Senior Citizen's Apartment Complex. Not knowing what type of smell to which you are referring, I can assure you that other than "burnt electrical" smells, the only smell that could possibly be produced would be that from within the INDOOR SPACE. Perhaps something has made its way into the INDOOR AIR FILTER? Perhaps that INDOOR AIR FILTER needs to be cleaned. To clean the INDOOR AIR FILTER, simply lift both of the filters from the front cover, take to your clean bath tub. Run EXTREMELY HOT WATER from the back of the filter to the front of the filter. Then, fill your bathtub 1/4 way with EXTREMELY HOT WATER. Add 1 cup of Hydrogen Peroxide and 1 cup of Real Lemon Juice. Set both filters in this solution for 30 minutes; then rinse with clear water. Set filters up to dry for at least 2 hours in the sun or an air breeze. Replace filters into the GE Zoneline.
Also, not knowing how OLD your GE Zoneline system is, the COILS may need to be cleaned. To do this, simply turn OFF your GE Zoneline unit and remove the front COVER of the unit. Next, mix in a spray bottle 4 packets of LEMON flavored KOOL-AID (without SUGAR) and water. Shake well. Spray the INDOOR COILS of your GE Zoneline unit with the entire contents of this mixture. Let set for at least 10 minutes. Then turn your GE Zoneline to the COOL position. The citric acid in the lemon kool-aid will be forced through the coils to continue to remove any dirt, dust, debris and effectively CLEAN those coils. This will also provide you a LEMONLY odor within your room. Simple and cheap.
Enjoy your GE Zoneline unit.
Aug 30, 2014 | GE Zoneline AZ55H07D Air Conditioner
Is it posible to konnect a remote thermostat model TR400HC-A to the air conditioner model AZ28E15DABm1 GE? The Zoneline Air Conditioner is working "On" "Of" and again when the outside...
You can connect That thermostat provided your unit must have option of 2 stage cool and 2 stage heat. If not you have to jumper with Y1 and Y2 and also W1 and W2. Follow the manual and wiring diagram. If any more details plz write here again. Thanks.
Feb 16, 2011 | GE Heating & Cooling
GE Zoneline blowing hot air in afternoon.
Maybe but check the temp difference between outlet and inlet. Should be 25 to 30 degrees. Rus
Jun 29, 2009 | GE Zoneline AZ55H07D Air Conditioner
Compressor keep running in off position
you could have a relay or contactor inside the unit welded closed, therefore compressor will keep operating when unit is off. replace compressor contactor.
Feb 09, 2009 | GE Zoneline AZ55H07D Air Conditioner
I have an older ge zoneline and one of the locknuts came off a selector switch. when it was turned it turned to far and twisted off five wires. i can put them back on but im not sure what terminals they...
I obtained the following statment from the GE web site:
How to Obtain a Wiring Diagram or Schematic...diagram. If you are in need of a replacement wiring diagram, simply call the GE Answer Center with your complete model number. The diagram may be faxed, e-mailed or mailed. You can reach us by dialing 1-800-626-2005. We are available...
http://genet.geappliances.com
Dec 19, 2008 | Heating & Cooling
GE zoneline - about 23 years old
theres a heat relay and also the wire used for heat.either could be bad.
Nov 05, 2008 | GE Zoneline AZ38H12DAD Split System Air...
Filters needed for Old GE Zoneline 2100
My name is brian pfeiffer . I run a ptac business in griffin ga. I have many parts and filters for most all types of ptac units. Please feel free to contact me at brian@dreamgreenservices.com. Nobody can beat my prices!!!! Or call me at 770-233-9987
Sep 03, 2008 | GE Zoneline AZ38H12DAD Split System Air...
Zoneline PTAC short circuit
Most likely you will need to either replace transformer or there may be a low voltage flat type "car fuse" usually 3 amp or 5 amp for just such an occasion. Good luck!
Mar 29, 2008 | GE Zoneline AZ55H07D Air Conditioner
Jan 10, 2008 | GE Zoneline AZ38H12DAD Split System Air...
Heating & Cooling Logo
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
