Question about RCA RTS736W Rts736w 30 Wi-fi Streaming Soundbar
My dog ate my remote
My dog chewed up my remote. Is there something i can do to replace the remote or can i buy a 4 device rca universal remote to work with it?
SOURCE: RCA Universal Remote stopped working
I also have the same problem with my rcv remote and it started when the batteries accidently feel out
Posted on Feb 05, 2008
  • 95 Answers
SOURCE: RCA universal remote
This is the eastest way to program your remote. To program a component using the Automatic Code Search method, perform the following steps: 1. Turn on the component you want the remote control to operate. 2. Press and release the component button that corresponds to the component you want the remote control to operate. info.gif The illuminated ON-OFF button turns on and remains on.
aud_remote_on-off.gif 3. Press and hold both the component and ON-OFF buttons. info.gif The illuminated ON-OFF button turns off. 4. After the illuminated ON-OFF button turns back on, release both buttons. info.gif The illuminated ON-OFF button remains on. If you press an invalid button during Auto Code Search, the illuminated ON-OFF button blinks four times and turns off. The last programmed code under that component button is retained. 5. Press and release the PLAY button. aud_remote_play.gif 6. If, after five seconds, the component does not respond, continue to press the PLAY button every five seconds until the component turns off. info.gif Each time the PLAY button is pressed, the illuminated ON-OFF button blinks ten times while a block of 10 codes is sent to your component. This process continues until all of the codes in the Code Lists have been searched. If the component has not turned off after all codes have been searched, the illuminated ON-OFF button blinks four times, turns off, and the Auto Code Search Entry method is exited. 7. When the component turns off, press and release the REVERSE button, then wait two seconds to see if the component turns on again. info.gif If the component does not respond, continue to press the REVERSE button every two seconds until the component turns on again. This will isolate the correct code in the last block of codes sent. Each time the REVERSE button is pressed, the illuminated ON-OFF button blinks. aud_remote_reverse.gif info.gif If the REVERSE button is accidentally pressed after the component responds, press and release the FORWARD button. Wait two seconds to see if the component turns off again. 8. To save the new code, when the illuminated ON-OFF button turns off, press and release the STOP button. aud_remote_stop.gif info.gif If some of the features of your component do not work, different codes in the list can be tried until you find the code that allows the remote to control the majority of your component’s
Posted on Mar 16, 2008
VOTIT
  • 2071 Answers
SOURCE: I bought your RCA universal
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing thefollowing steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): clip_image001.gifclip_image001.gifWe could not find an exact match, we think this code will work. 10054 clip_image001.gifclip_image001.gifSetup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Aug 25, 2008
I have an old KTV, model 13tec and need a new remote.  Which RCA should I purchase RCR 312W or RCR 451??  What code do I use??
Posted on Oct 23, 2008
SOURCE: universal remote codes
I found the following web site which lists the codes for the RCA SystemLink 4 RCU400C universal remote.  It's http://www.thompsontv.com/rcarc.html.
Posted on Nov 28, 2008
The back of my TV says X42gv-naga. Is the naga and komodo the same tv? same remote control?
If you wish to buy its original remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have setup code to your TV/device brand. You should first make sure about the number of digits in the codes to your device have. There are 3-digit, 4-digit, 5-digit and even 2-digit codes. You can get this detail by the code list attached to every universal remote control. The brand name of the remote control you select isn't a matter; but, its code list should have setup codes to your TV/device brand, otherwise you can't set it up with your device. Check this link and note which brand remote control have set-up codes to your device brand, and buy that brand remote control, according to availability. . If you wish to get more information, check these links. Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts.
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Dec 18, 2013 | Sceptre X42GV-Komodo 42 in. LCD TV
Dog ate remote where can i find one?
Hello
If you want to get its original model remote control; you have to contact the nearest RCA authorised service center at your town. You can't buy its orignal from nowhere else. A universal RCA remote control will work with it, but sometimes some buttons of it may not synchronised. So try to get its original model. Moreover, if by anyway this set happened to be in FPA lock, you cannot open the lock without the orignal remote control. A universal remote control, whatever it may be, won't work then. OK.
Sep 24, 2011 | RCA 20F512T 20" TV
My dog ate the remote control for my Insignia DVD player and have tried using a universal remote, but I am unable to use all the functions on my DVD player. I am hoping to find an Insignia remote for my...
LOLOLOL. I'm sorry, i can't help but laugh. Try using ebay, or use the shopping feature under google. Or better yet, take your dog to the vet and get its stomach pumped. I'm surprised you havent already done that. Also, when you get a new remote, dust the outside with something like cayenne pepper. For dogs, the taste is EXTREMELY unpleasant, and s/he will generally stay away from the remote. dust anything you don't want the dog to chew on.
Mar 11, 2011 | Video Game Consoles & Games
My dog ate mi remote control...I have not been able to find a new control
Your dog ate your remote? wow, My best advice is get a universal remote capable of blu-ray player codes or try ebay for a replacement remote.
Jan 19, 2011 | Sony BDP-S350 Blu-Ray Player
Remote will not work on TV
forget the universal, just go on line and find one on ebay. it shouldnt cost mor than 30 bucks.
nbcrca
Apr 11, 2009 | Televison & Video
Code for Yamaha YAS 71 Surround Sound System
If you can get a new remote either buy a new one from Yamaha or do like I did (I still have my Yamaha remote) for 29.99 Radio Shack sells a Auvio Universal remote and all you have to do is use the "learn" function......operates all my stuff including my YAS-71!!! great remote!!!
Mar 25, 2009 | RCA RCR311B Remote Control
Remote Control Menu
acquire universal remote.
acquire exact replacement from mfg if avail.
no alternative if your remote is destroyed.
based on your need to access menus with it.
then hope your dog develops a taste for something else.
to that, my dogs chew bully sticks. it satisfies their need to chew. which is a really big drive. and they cost a bit, but last a long time.
and its cheaper than replacing remotes and furniture, shoes and other things.
and your dog will be extremely happy.
costc has started carrying them.
most pet stores carry them.
they are also known as pizzle.
you really don't want to know more about them.
they will keep your dog happy when otherwise bored.
good luck
have a happy dog.
mark
Dec 14, 2007 | LG 42LC2D 42 in. LCD HDTV
RCA RTS736W Rts736w 30 Wi-fi Streaming Soundbar Logo
74 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
