Question about Electrolux Central Vacuum
NO SUCTION My Electrolux Z2274 upright vacuum cleaner has lost it's suction and is very noisy. Have checked and rechecked there is no blockage. Have cleaned the filters. In fact done everything I can think of. Any one know why and how to fix this??
  • jknight Jan 21, 2009
    Many thanks for your reply Chris321918. I think it's time for a new vacuum cleaner as I feel it would cost more to repair than replace.
  • 32 Answers
If you have no suction, there are only a couple of things that could cause it. As you have checked for blockage, and changed your filters, you may have a vacuum motor with bad bearings, or broken fan blades (inside/on the vacuum motor). Either symptom points towards a vacuum motor being bad and needing replaced.
Posted on Jan 21, 2009
My vax pet Hoover has lost its suction I've emptied it there's no blockages and Iv cleaned the filter
first, if it has a hose check for being plugged, you may have to take the vacuum apart further till you reach the fan on motor which may have hair,lint,etc wrapped around it which can cause low suction.
Checking for Blockages in Your Vax Upright Vacuum Cleaner
press helpful button
Jan 09, 2016 | Hoover Vacuums
Why when I Pull out handle to use edging attachment, suction stops?
Make sure that the vacuum cleaner is in the fully upright position as there is a slide 'gate' thet directs suction to either the vacuum head or to the handle section depending as to which section you wish to use. In the upright position, you shoud be able to hear the vacuum at the handle where the attachments connect. If you still have vacuum at floor level, check the action of this gate. The actuating mechanism may be broken. Cheers Bob
Jul 12, 2014 | Dyson DC14 Animal Bagless Upright Cyclonic...
My electrolux versatility vacuum doesn't have much suction
Hello, this is Ava with Think Crucial.
If you are experience less or no suction of you vacuum, most of the time there is a blockage that clogs up your unit resulting to this. Turn off your vacuum first and unplug the machine from the power before doing any troubleshooting with your vacuum. Remove the attachment hose and check inside the hose and the openings where the hose attaches for any blockages. You may refer to your manual below for troubleshooting solutions:
Electrolux EL8502 User Manual
You can purchase a wide variety of high quality Electrolux replacement parts for your Electrolux vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=electrolux
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Jun 18, 2014 | Bissell 9200 Upright Vacuum
Precision model blockage
No solution but we seem to have the same problem it is as if the valve isn't working. Please don't tell me to check for blockages.
Feb 24, 2014 | Electrolux EL8807A Precision BrushRoll...
The vacuum seems to have lost a lot of suction power and it is only a month old. Seems like there is a clog or something, all filters are cleaned and after a vacuuming session, nothing is in the...
sounds like there is blockage in the suction hose -- lay the machine down and remove the lower floor plate and clean out the hose area where it bends down to the floor unit ( use a wire coat hanger to fish out the blockage ). also check the main hose for any obstructions.
c...
Feb 17, 2011 | Bissell Cleanview Helix Deluxe Bagless...
Suction/Brush not working
Hi there SmartAlec from NelsonVacuums.com.au here.
There are a couple of common reasons that your electrolux vacuum cleaner would appear to have lost it's suction. The first and most common is that it has actually broken a belt. If the belt is broken the brushes won't spin and it will not pick up dirt. It is easy to test simply turn the vacuum on, release the handle (as if you were about to vacuum carpet) and lift up the head and see if the brushes are spinning. If not i can supply you with a new belt.
If the brushes are spinning then your next most likely cause is that there is a blockage in the vacuum somewhere. Test this by turning machine on and checking the suction at the hose (as if your were going to vacuum the couch) if it is poor then remove hose and fish out blockage. If it is ok you may have a blockage between hose and the brush of the vacuum.
If it is neither of these problems i can trouble shoot over the phone if you live in Australia 0269215200 or by email nelsonvacuums@netspace.net.au
Happy Vacuuming.. :)
Aug 25, 2009 | Electrolux EL5010A Bagged Upright Vacuum
My VAX Vacuum has lost ALL suction power. I've
vax power pet 1 filter keeps getting clogged up so dirt not going into cylinder
Jul 05, 2009 | VAX Appliances Vax X5 Bagless Upright...
It has lost most of its suction power...what to do?
clean all the filters if this doesn't help then check for blockages at head, hose and entrance to collection chamber
May 30, 2009 | Vacuums
EL7020A ELECTROLUX VAC SHUTS OFF AFTER 10 MIN
The symptoms you describe are typical of a vac that has a blockage (hence poor suction). It cuts out because it's over-heating. You need to check the hose, the filters and anywhere else where something may have got stuck. Blockages are often caused by things like paper clips, but can be caused by something as apparently harmless as a piece of paper which gets stuck and then debris builds up behind it and causes a log-jam.
Feb 10, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Vacuums Logo
378 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
