Question about Lexmark P4350 All-In-One InkJet Printer
Just paper jam
It was sigested that my printer needs cleaning but I did not get the instuction book with it .How do I clean my printer?
    President:
  • 2,692 Answers
Here is your manual you manual link:
http://www.lexmark.com/publications/pdfs/2007/4300/en.html
Posted on Jan 21, 2009
I have a 7300/7400 HP Office Jet printer....keeps giving false alarms on paper jam. I have done everything the book says. The print cartridges do not return to the right. I love this printer and
there are a few sensors in the paper circuit. if those sensors have some small pieces of paper you will continue to get this error. If you have serious mechanical skills you can try to disassemble the printer and clean every sensor. if not you should go to a specialized service center.
Jan 17, 2012 | HP OfficeJet 7310 All-In-One InkJet...
Printer brother DCP330 Problem paper jamming
You may encounter a paper jam while working with your Brother printer. You need to be cautious while feeding the paper to your printer. Paper jams are often obvious, but you might come across a situation when you do not get any indication that the paper has jammed up the printer. In such cases, you need to open your printer and visually inspect it to search for the jammed paper. If the rollers of your printer are leaving marks on the printouts, then there is a need to clean them. Using chemical cleaners such as benzine, thinner, or alcohol to clean the rollers might prove hazardous to your printer.
Dec 22, 2010 | Brother DCP-330C All-In-One InkJet Printer
How to remove a paper jam brother printer
Get more information and help for Brother Carriage Jam .
Nov 29, 2010 | Brother DCP-9040CN Laser Printer
Hello, I have a Brother MFC-640CW that show a paper jam error message, but no paper jam in the printer. I have inspected the printer and can't find anything, how can I clear the error message, or repair...
Nov 10, 2010 | Brother MFC-640CW All-In-One InkJet...
Our Cannon Pixma 610 says that paper is jammed. We have looked throughout the printer, underneath, and read through the instructions. We can't find any paper jammed nor any pieces of paper lying in there....
open the printer and clean it with thinner or petroll after that un install the software and then install again.
when you open the printer and cleaned take all the cables off from the printer board and plug in again while it is dry
Apr 07, 2010 | Canon PIXMA MP610 InkJet Printer
Can't get instuctions for my paper feed cleaning kit!
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry. Keep printer unplugged for about 2 minutes and replug and try a test print. Also make sure that you have waited long enough for the printer to heat up before giving a print job. Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Thanks
Thiru
Jun 15, 2009 | HP DeskJet 520 InkJet Printer
Fake paper jam
the roler, which picks the paper need to clean, try it
Oct 28, 2008 | Samsung ML 1610 Laser Printer
Paper jam
Lift up the printer front a few inches using a book or a small box. The paper will them feed beautifully downhill into the roller.
Richard
Oct 12, 2008 | Samsung CLP 300 Laser Printer
Copier canon mf4150 says it has a paper jam, but there is no paper jam.
1. First, clean your printer. Get some spray-n-wipe cleaner and a clean cloth and clean the entire inside of the printer. Also ensure your paper isn't dirty. Now print a test page. Does the symptom persist?
2. Remove all jammed paper. Check the paper tray first. Look closely at the paper rollers nearest where the paper exits the printer; this is a common source of jams. If you’re trying to print labels, they will often jam just before exiting the printer.
3. Try to print a test page. Does the printer still jam? If you can find no source of the jamming, check the printer's message display window and refer to your user’s manual to look up the printer error code.
Sep 16, 2008 | Office Equipment & Supplies
Permanent alert of paper jam after cleaning a printer HP 5L
The paper path/paper guide may need replacement. I would also get a maintenance kit and replace all the rollers.
Jan 29, 2007 | HP LaserJet 5L Printer
Lexmark P4350 All-In-One InkJet Printer Logo
59 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
