Question about Crafts & Hobbies
How do you mystery braid a piece of leather? - Crafts & Hobbies
    Problem Solver:
  • 18 Answers
Look at the step by step pictures here. Its really simple http://www.marthastewart.com/908041/mystery-braided-leather-cuff
Posted on Jan 10, 2013
I purchased my first Giani Bernini bag as birthday gift to me and after 2 weeks, the handles of my tobacco dome satchel have cracked & pinch my arm! about every inch of the handle, on the sewn si
if you have receipt and this was original (it will have tag, as you did not state whcih model, cannot say where tag is), as any other merchandise, this have warranty, these bags depending on the model are between $110.00 up to few thousand dollars, but they all have warranty...
if you bought it new, from the store - warranty in most cases is at least 1year. go to the store and you will have either bag repaired or replaced.
if you find this info helpful - do not forget to vote...
Feb 02, 2015 | Giani Bernini Handbag, Mothers Day Braided...
What is the best way to use pump spray on leather
sparingly until you understand the absorption level of nthe leather you are working with. If it is veg tan very light,it will not need much,if it is a lace product the surface will not absorb but the flesh side will,if some kind of upholstery or chap leather lightly but more often,....
mcgonigal studios===== custom leather/artifact restoration
May 19, 2014 | Crafts & Hobbies
What is a good idea for my first leather crafts project?
As a beginner, a good idea for your first leather crafts project would be to make a bracelet. This is relatively easy to do. You can split the leather into strips and braid them or add beads for decoration. You can find many how-to videos online.
Feb 20, 2013 | Crafts & Hobbies
How can I keep my leather gardening gloves clean?
Leather gardening gloves demand special treatment. In order to clean them, gently scrub with a pumice-based soap. Rinse, apply a leather protector, and then hang the gloves on the line to dry. Before they dry completely, put them on to restore their shape.
Feb 06, 2013 | Clothing Accessories
How to get pen off fake leather
Fake leather AKA Bonded leather markings is a fixable problem. First assumption is that the pen markations did not etch or scratch the leather. Leather color spray is available from the Mohawk Co http://www.mohawk-finishing.com/ for a variety of common leather colors. The goal is to mask the ink in this case. Should the leather be etched or scratched, there are flexible filling adhesives that fill marks in leathers and are heat cured. Following the fixing of a scratch the mark is then colored to match the furniture piece.
Jun 28, 2012 | Furniture
I have a new FY5618 and it keeps skipping stitches ... and on one piece of leather it will ... but if i put ANY other piece of fabric ... it wont!
the reason it may skip stitches on leather is because it cannot form a loop for the hook to pick up because of the closeness of the material, you must use a proper leather needle
Aug 13, 2011 | Yamata Sewing Machines
Can sirius antennas be cut and spliced back together
If your antenna cable has been cut or severed, it can be repaired without the need for a replacement.
You will need the following things:
Small 600 degree soldering iron and solder.
Liquid flux for soldering the braid.
Small sizes of heat shrink tubing.
Small heat gun.
Small pliers, cutter, and Xacto knife.
1) The first step is to use the Xacto knife to cut both ends of the antenna cable so you have a clean end.
2) Using the Xacto knife roll the cable on a board and gently cut all around the cable to cut the outer insulation. Remove about 1/2 inch of the insulation from each end.
3) Push the braid back to expose the center wire and gently roll the cable and cut the center insulation to expose about 1/10 inch of the center wire. With your small long nose pliers, bend the center wire into a small hook shape.
4) Repeat all the above steps on the other end of the wire.
5) Put a 1 inch piece of heat shrink tubing on one end ( the black piece), and a 1/4 inch piece of heat shrink (the white piece) on the center conductor. Look at the picture to see this.
5) Hook the two ends together. Gently squeeze the hooks closed and solder them together. Be very careful when soldering this. Be quick so you do not apply to much heat and cause the heat shrink tubing to shrink on the side where you do not want it to be.
6) Slide the small white heat shrink to cover the cooled solder joint you just made and use the heat gun to shrink the tubing in place.
7) Now push the braids back together to cover over the connection you just made. Try make the braid smooth together by GENTLY rolling the cable between your fingers. Carefully solder the braid. A little liquid flux on the braid prior to soldering helps the solder flow and makes it look better.
8) Slide the final piece of heat shrink tubing over the braid and shrink it with the heat gun.
Jun 12, 2009 | Sirius Satellite Radio Receiver
Crafts & Hobbies Logo
666 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
