Question about D-Link Computers & Internet
Dir 655 blinking triangle light - D-Link Computers & Internet
    Novelist:
    Habit-Forming:
  • D-Link Expert
  • 199 Answers
The blinking triangle light indicated the wireless portion of your router is active and sending/receiving connections.
Posted on Jan 06, 2017
mastersaintx
  • 928 Answers
SOURCE: Setup DIR-655 w/ Westell 6100 USB DSL Modem
First check if your computer can get on the modem with an Ethernet ( This is to find out if your router will work with your modem) If you cannot get on give your ISP a call to have them configure the modem for Ethernet connection. If you do get on then connect the router to the modem and your computer to the router. You can run the CD for the router or do the connection manually.
Posted on Jul 27, 2008
beeveez
  • 167 Answers
SOURCE: My DIR 655 is able to conect to my laptop through wireless
Do you see wireless signal of your router from your Laptop? If not! make sure the Wi-Fi of your Laptop is activated for you to get online wirelessly.
Posted on Mar 08, 2009
beeveez
  • 167 Answers
SOURCE: Will a D-Link DIR-655 accept a usb data card?
- They're both function as an USB and Air Card.
Posted on Mar 17, 2009
dante777
  • 623 Answers
SOURCE: work as acsess point
first let's back up and get the terminology right (otherwise you will not find any information on the internet.)
Your 655 will be the Access point, because it gives access to the wired WAN (ISP, Internet, etc.), or 'outside world".
Your 635 will be called a Bridge, because it bridges the connection from the access point to other wired or wireless clients inside your own network.
If this mode is accessible for you depends on the firmware you have installed. Look at this posting.
Your D-Link 635 is unfortunately not compatible with other firmware, which would be necessary to convert it into a bridge. (See here)
Sorry - but that's the reason why so many people get a Linksys or Buffalo router.
Also - the distance of 500 meters (open air or not) requires an increased transmitting power from the access point (655) and you will have to use different antennas. Third-party firmware also allows you to modify the standard power settings, but you have to make sure that you stay within legal limits of the place where you set this up. If your signal interferes with someone else's, you might get into trouble or even get a fine.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Posted on May 30, 2009
  • 1341 Answers
SOURCE: Really unstable Dlink dir-655 router
I would suggest you try to change the channel to a higher one and this solves this problem most of the times...You need to go to your router configuration to do that usually by opening a browser and type 192.168 ... and log in into your router...Hope this helps.
Posted on Jun 25, 2009
I've plugged the modem into the router and the four lights on the left of the router are on, the middle two blinking; however, despite being able to detect the router wirelessly I am not able to gain...
One thing to try is to hard reset the modem and the router. This will work on an unprotected router that won't connect most of the time.
This link is to the data sheet d-link gives for this router. ftp://ftp10.dlink.com/pdfs/products/DIR-655/DIR-655_ds.pdf
This one is to the software and instillation guides they provide. Select your country from the three. Then there is a link to a FAQ below the two download links that will help you find which of the two that you need.
http://www.dlink.com/products/default.aspx?pid=DIR-825&tab=3
Jun 18, 2011 | D-Link Xtreme N DIR-655 Wireless Router
How do I reset my d-link 655? I tried to reset by pushing a pin into reset but it did not work. I also forgot my security code how do I establish another? Thank You, Morris morriszemliak@shaw.ca
Maybe you push the reset button not long enough, you need to wait for the lights to die down and blink again. Thats how to reset most routers.
hope this helps. please rate my solution thanks.
Jan 12, 2011 | D-Link DIR-655 Wireless Router
D-link DIR 655 owner's Manual
Look on router ID plate for REVISION.
Owner Manual Links:
For DIR-655: http://www.dlink.com/products/?tab=3&pid=DIR-655&rev=DIR-655
For DIR-655 REV. B: http://www.dlink.com/products/?tab=3&pid=DIR-655&rev=DIR-655_revB
Thanks for choosing FixYa, If you find this helpful please vote and comment.
Oct 11, 2010 | Computers & Internet
My DIR-655 won't work!
It would be helpful if you could be a bit more specific regarding the way you hooked up the dir 655 to your network and your specifc DSL modem. If the modem you are using is the Actiontec M1000 DSL modem you will not be able to obtain internet access because the DIR 655 is trying to route an already routed IP, the M1000 has a built in router / DHCP that by default is enabled. You can use option 1, access the configuration settings of your M1000 and change the WAN configuration to act as a transparent bridge. After doing so and rebooting the modem you will have to enter your DSL login information like a PPPoE username and password for example into your DIR 655 network settings. With this configuration the modem simply acts as a bridge to relay data directly to the DIR 655 and the 655 itself provides login credentials to obtain internet from your DSL provider as well as hand out IP addresses to the local network. Option 2 is to continue to use the M1000 as a router by default and disable DHCP on your DIR 655 so that it essentially acts as nothing more than a switch or wireless access point while the M1000 hands out local IP addresses. I personally would recommend using the DIR 655 to route IP's as it's got far more configuration utilities than the M1000 does as a router, and really what's the point of getting the 655 if you're only going to use it as a switch or access point when there are other simpler and cheaper devices that could do that for you.
Jul 20, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Mar 07, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Status LED doesn't even glow nor blink
The router was apparently faulty and should be returned to D-Link for a replacement to be sent. Just call them and they'll help you!
Jan 17, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Computers & Internet Logo
109 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
