Question about Kenmore 44072 Front Load Washer
Water not pumping out and spin cycle not working.
The water is not pumping out of the machine before the spin cycle starts. It has a buzzing sound and the machine continues to wash during the spin cycle rather than spinning.
  • gambrooks211 Jun 30, 2008
    Water pumps out v-e-r-y slowly. That is, if I leave the machine for an hour and start the pump, a quick burst will come out then it slows to a trickle. repeating this eventually empties the washer.
    The hoses are clear, the external one into the tub and also the internal one that goes up the inside of the washer and links to the external hose.
    I have a 45072 front load washer.
  • Anonymous Mar 13, 2014
    water wont pump water out in the lasrt spin cycle
  • 164 Answers
It sounds like you have something obstructing the pump. does the machine eventually empty? or does it remain with water in it. you need to remove the hose that leads from the tub to the pump and clear any debris. if you continue to run with debris in the pump you could burn out the pump motor
Posted on Jul 02, 2007
Kenmore washing machine series 90, will not agitate, spin, or drain. Door switch is good. Wigwag solenoids have continuity. Motor start capacitor good. Motor will spin if belt removed.
Unplug the unit. Remove the hoses on the water pump to check if it is clogged. Water will come out so be prepared. Check how you can check for error codes.
Dec 13, 2016 | Kenmore Washing Machines
What is causing the loud buzzing sound during spin ctcle on my Frigidaire Affinity Series 6000 front load washer ?
buzzing sounds are a frequency buzz from a problem solenoid or start/run capacitor failing
it could be the water inlet control for the rinse in the spin cycle
call a technician for a proper diagnosis
Feb 02, 2018 | Frigidaire Washing Machines
Maytag Neptune TL clothes still dripping wet after full cycle
Pump out time of 40 seconds sounds good.
No ND error code and you spin up to 850RPM which is max for the machine.
You have no standing water in the wash basket.... I'm scratching my head.
Could you do a Spin Only cycle with that same wet wash load and set the SPIN for Max Extract. After you start the Spin Only cycle put the machine in Service Mode and watch the RPM range. This cycle sets the display to 12 minutes. Let’s see if the wash load remains wet and what max RPM is reached.
""Maybe the pump is not turning on during the spin cycle?"" You have no standing water in the wash basket correct? I feel the pump is turning on or you would have standing water in the wash basket and the pressure switch would have never indicated an empty condition (Low Level pressure switch contacts) to the Control Board. The Control Board would have stopped the wash cycle with a ND for no drain error code.
The pump in the spin cycle will turn on a number of times see if you hear turn on in a Spin Only cycle
I just ran a Spin Only light wash load with about 5 gallons of water in the wash basket. Timer went to 12 min. I toggled into Service Mode to watch wash basket RPM. At about the 5 Min mark (toggle in and out of Service Mode) the wash basket reached 850RPM then a few minutes later it stepped down to 830RPM to end of Spin Only Cycle. You don’t have a water valve stuck open or you would flood/over flow of the machine. Did you here the drain pump turn on several times during the Spin Only cycle?
Rich
Apr 08, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Kenmore washer doesn't drain
This is likely a pressure switch issue.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 27, 2009 | Kenmore Washing Machines
High pitched buzz/whine during wash cycle only, spin fine
1) Make sure valve is open all the way 2) some machines have a screen inside of the hose hook up which could be clogged. 3) last check to see if it is the hot or cold by switch your selector switch on your machine to hot then cold. If one of these positions eliminate the noise then the valve in the machine is bad.
May 16, 2009 | Maytag Atlantis MAV8000
Kenmore model 22432100 - it won't drain or spin
sounds to me that something is stuck in your pump check the pump if you open the pump have lots of towels on hand the machine will not spin if it does not drain
Dec 29, 2008 | Kenmore 24032\24036 Top Load Washer
Washing machine makes buzzing noise
Check the water pump for an obstruction in the chamber area, your pump may be sticking and that will cause the buzzing sound. The water pump runs during the fill portion of the cycle on several of the selected wash cycles to recirculate the water.
Nov 06, 2008 | Fisher Paykel EcoSmart GWL15
Whirlpool Washer LSR7233BQ2 Buzzes/Humms during spin cycle...no movement
No belt on your machine. Sounds like motor coupler that joins motor and transmission is broken. Very inexpensive part but a few steps involved in getting machine disassembled Look up YouTube video on replacing motor coupler on Whirlpool washer.
Sep 26, 2017 | Whirlpool LSR7333 Top Load Washer
Washer making buzzing sound during spin cycle,then stopped during wash still has water in tge clothes,buttons light up as if going to work but nothing happens jusy buzzing noise
If I understand correctly, the washer made a sound in the spin cycle but didn't actually spin the clothes dry?
If so you may have something in the pump that is not allowing it to pump out. Disassemble the pump and make sure it is clear of any debris.
Jul 21, 2008 | Frigidaire Washing Machines
Kenmore 44072 Front Load Washer Logo
167 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
