Question about Cameras
Built in flash is stuck on the cannon rebel t4i
4 Suggested Answers
SOURCE: built-in flash
do you get an error message? if yes the screws which are on the sides that hold the stainless steel slider bars could be missing the nylon spacer shims. a common fault
Posted on Jun 22, 2008
SOURCE: The built-in flash on the Canon Rebel XTI won't flash.
i am having the same problom try this i just found this ... http://www.fixya.com/support/t1021194-flash_not_working
Posted on Sep 16, 2009
  • 102366 Answers
SOURCE: I have a canon rebel xti with a 18-55 and 75-300 lenses. I want to purchase a new body and reuse the lenses. Would the lenses fit on a T4i? Or what body would work?T4i bo
Yes, they will.
Posted on Nov 01, 2012
Color on canon LV7290
Wrong section unless cars are coming with Cannon cameras installed.
Nov 06, 2013 | Canon 6558B003 EOS Rebel T4i Digital...
I have a cannon rebel xt and when the flash pops it it will no longer take a photo but works fine outside if flash is not needed?? Help
Does the little flash lightening bolt light up in the viewfinder to let you know the flash is fully charged? If it does, but when you push release it goes out and then comes on again in a few seconds that is the sign of a bad flash board.
Does the flash go all the way up?
Is the switch that is under the flash come all the way up (not stuck down)?
Mar 12, 2013 | Canon Rebel XT / EOS 350D Digital Camera
Canon EOS Rebel T4i 650d flash pops up but does not work.. Camera is 2 months old any suggestions please
I suggest you return the camera back to the shop and get the camera repaired or replaced as it would be still under warranty.
If you try to fix it yourself you may void your warranty.
Feb 22, 2013 | Canon Cameras
How to mount 67mm thread lens to t4i body only canon
One side of the reverse adapter has a 67mm thread, the other side has a lens mount. Mount it to the camera body as if it were a lens. Bear in mind that it's intended to screw onto the front of a lens and then mounted onto a camera to put the lens onto the camera in a "backward" position.
Dec 16, 2012 | Fotodiox 67mm Filter Thread Macro Reverse...
I own a cannon rebel eos xsi... my flash will not work.. it says ... Error 5? I am getting really frusrtrated. Any help would be great.
This error occurs when the camera thinks that the flash has failed to pop up. There's a small button switch down near the hinge, and it should be up when the flash is up.
Sometimes it gets stuck down by a bit of dirt, and can be freed using a toothpick/cocktail stick but more often the switch itself has failed. Repairing it simply isn't worth it, like all digital Rebels (EOS triple number models in the rest of the world) your model is a consumer grade product that really isn't designed with repairs in mind. The switch is not a separate item and is an integral part with an internal flexible circuit board which is not easy nor cheap to replace.
You'd be far better off investing the likely repair costs on a proper external flash; it will be more bulky but the results you get are vastly better than you get with the in built flash.
There's a short discussion about the same question here.
I hope that you have found my reply to be of use; please don't forget to rate my answer.
Mar 01, 2010 | Canon EOS Rebel G 35mm SLR Camera
Canon Internal Flash will not Pops up and will not flash. Is there something I can check for or replace? I have a cannon rebel xti, the external flash works great, the button to make the flash pop up will...
Is it trying to pop the flash and making noise, or is there no noise at all?
If it's audibly trying and it won't pop up, it's stuck and something is blocking it. May need to send it in.
If there is no sound, then something is making it think that there's an external flash attached. Check out this photo here:
http://www.flickr.com/photos/dougpardee/133066175/
Doug Pardee on flickr may be able to help as well.
Hope this helps you! If so, leave me a rating!
Feb 26, 2010 | Canon EOS 400D / Rebel XTi Digital Camera...
Erro 5
Err 5 is the code shown when the flash isn't correctly released.  Try cleaning the area around the built in flash and make sure it can pop up freely
Jan 27, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Err 05
I did some research on this and it looks like this is a common problem. If your camera is still covered under warranty, Cannon will take care of it.
If it isn't check for any dirt objects within the area of the flash. You can gently lift up on it from the front of the camera as well.
Jul 12, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Cameras Logo
339 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
