Question about Gateway E-4000 PC Desktop
What is the ram on a gateway computer model mfatxpnt esx e4000
Ram
YIRMASTER
  • 32 Answers
SOURCE: Hpw do you replace the power source on a gateway
How do you know the power supply is the problem?
What issues are you experiencing?
Have you done any trouble shooting first? It could be a bad hard drive.
If you should need to replace the power supply first you need to get a replacement power supply for a gateway MFATXPNT ESX 500S - 300 watt power supply you can get here.
The next step is to unplug the computer from the wall > remove the case side access panel > ground yourself with an Anti-Static wrist strap cord so you don't fry *********** board electronics from static electricity discharge which can cost you a lot more to replace > now disconnect the plugs from the power supply wire harness, it may help to count the connections and mark them with a piece of tape or draw a diagram so you don't forget which loose cables should get reconnected to the new power supply. There will be at least one that connects directly to a plug on the mother board, DO NOT put tape there. > Next remove the screws which mount mount the power supply to the metal frame and slide out the power supply > slide the new power supply in the same way the other other was removed (note top from bottom) and then screw back to frame and reattach the cables > close the case > remove your grounded wrist band > plug computer back into wall and start the computer.
Congratulations, you have just replaced your power supply and ready to go.
IMPORTANT: Do not switch the power output selector switch on the power supply. Usually a recessed re switch which will adjust for european vs. US power input conversion.
Additional Resources and Tutorials
Step by Step Video Tutorial to Replace Power Supply
With pictures, step by step
Diagnosing ATX Power Supply Failure with Diagram
How to diagnose and replace a failed pc power supply
Hope you find my resources and information useful and rank or review it accordingly.
Posted on Jan 12, 2010
akroyce
SOURCE: MFATXPNT ESX 500S
On my model, there is a broad recessed area on the top of the case.
On the left-hand side of this area (as you face the front), there is a 3-inch-wide, grooved-surfaced latch that must be pressed inward (to your left) to free the left panel. If you are facing the left side of the unit, pressing this latch inward by grabbing the top of the panel as if you were going to pull it off by force naturally presses in the latch, opening the case.
If you're not seeing the latch, note that the top half of the front can be covered by a rotating cover that covers the drive bays. When it is not covering the front, this rotating cover flips up and around, coming to rest on the top of the unit in the broad recessed area.
When this cover is flipped up and stored at the top of the unit, the case latch is hidden and not pressable. Flip the cover back down so that it's covering the drives, and you're good to go.
Posted on May 16, 2010
BlacMamba
  • 215 Answers
SOURCE: i need drivers for this
Try these link
http://support.gateway.com/support/drivers/search.asp?ref=step&st=browse&platform=10021&model=10613&os=10406&type=
Posted on Dec 21, 2010
  • 998 Answers
SOURCE: Looking for cheap wireless card that will work
8 years is ancient for computers. There are USB receivers that are wireless.
Posted on Jan 05, 2011
Xenturion
  • 68 Answers
SOURCE: Need memory for Gateway Desktop
Go to Crucial.
It is very easy to use, just select the manufacturer and model number from the drop down list, and it'll tell you everything you need to know, AND offer you some pretty good deals on memory direct from them.
Posted on Aug 24, 2011
I have a gateway model MFATXPNT/MDW500xl, and its has 512mb ram. Can I put in more ram, it is getting slow. Thanks
That model is a little too dated to find info on. You can download and run this free tool and it will scan your PC and tell you all you need to know about the components. Most important is how many DIMM slots, and what type of ram it has. I likely has 2 slots with 256 mb in each one (256x2=512).
The tool will tell you the maximum your motherboard will support, which I am guessing is 1GB. (2x512mb).
Jun 28, 2011 | Computers & Internet
GATEWAY E4000 Desktop P4 1.8GHz ,768MB doesn't recognize monitor
Try pulling the ram chips out and see if it turns on.
pull out the cards and unplug the cd and hard drive and see if it turns on,,
If you have no luck then its a bad cpu or motherboard,
Apr 10, 2010 | Computers & Internet
Hpw do you replace the power source on a gateway MFATXPNT ESX 500S.
Jan 12, 2010 | Gateway GT5220 PC Desktop
Neovo e-19a flat panel will not work with gateway e4000.
You may have to turn on the external video from inside the BIOS; not all systems are set up to feed video to the VGA port unless told to do so.
Oct 26, 2008 | Neovo E-19A 19" LCD Monitor
PROCEDURE FOR REINSTALLING DRIVERS ON REPLACEMENT MOTHERBOARD
1. Go to the gateway site www.gateway.com
2. Click on the download drivers link
3. type in your part number
if they do not have the drivers , perhaps www.driverguide.com may have them , I personaly do not recommend using driverguide because I find their site difficult to use , and their drivers may not be
100% accurate match. I only recommend them as the LAST resort.
shalom :-)
Sep 10, 2008 | Intel Motherboard
Gateway E-4000 PC Desktop Logo
130 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
