Question about Seiko Solar Quartz Link Bracelet Mens Watch SNE039
Seiko sne039 watch won't charge
Brand new seiko sne039 runs for about two seconds & then quits , won't take a charge
Techjoel
  • 79 Answers
SOURCE: I have not worn my SEIKO kinetic wrist watch for a
Here is the information from the website. The link to the manual is provided below. HOW TO CHARGE AND START THE WATCH Swing the watch from side to side approximately 50 times. * Before swinging the watch, check and remember where the minute hand is so that you can tell if the start-up indicator has worked or not. First, check that the crown is at the normal position. * If the crown is pulled out and the watch is swung, the start-up indicator will not work even if the watch starts operating. * Swing rhythmically at a rate of twice a second. * No additional benefit is obtained by swinging the watch more quickly or with greater vigor. * When the watch is swung, the oscillating weight in the generating system rotates to drive the mechanism. As it rotates, it gives out a sound, which is not a malfunction. 1 2 The minute hand moves quickly and stops as the watch starts operating. (Start-up indicator) Then, it will move at 20-second intervals. 3 After checking that the minute hand has done this, pull out the crown to set the time. 4 After pushing back the crown in to the normal position, swing the watch further approximately 350 times to reserve one day of power, and then, put the watch on your wrist. http://www.seikowatches.com/support/ib/pdf/1m20_e.pdf Good luck, Techjoel
Posted on Jun 05, 2009
  • 3 Answers
SOURCE: Seiko Chronograph Sport 150 - Problem: After
Please folow this link:
http://www.seiko.co.uk/support/instructionbooklets
Enter your calibre code (its on the back of your watch, it will explain which numbers to you on the website), you'll then be able to download an instruction manual for your watch, this will detail how to adjust hands to their corect starting position :)
Posted on Dec 01, 2009
Testimonial: "PDF link states reseting the watch is the problem, and now that I have instructions, I should be able to reset the watch. Thanks"
  • 3 Answers
SOURCE: seiko watch stop watch needs resetting
You can download an instruction manual for your watch here. It will detail how to reset the hands. :)
Tom
Posted on Jan 03, 2010
  • 2501 Answers
SOURCE: SEIKO KINETIC SQ 50 HAVE USE MY WATCH FOR 14 YRS
It is unlikely that the capacitor will have any charge on it so you should shake it gently to charge it up. You certainly can't do any harm by charging it, even if the capacitor did have any charge.
Posted on Feb 20, 2011
escapement
  • 2334 Answers
SOURCE: Hello, My 1998 Seiko Kinetic SQ 50 with dual
Yes Sir, this indicates that you have to replace capacitor.
Posted on Feb 28, 2011
Charge indicator on my Seiko Kinetic watch does not work. Watch keeps good time. Is there a fix?
Bill, when you say "does not work" I am going to guess you mean that the second hand does not sweep as it should, so you do not have an accurate indication of remaining capacitor charge.
There are many other malfunctions of the Indicator on a Seiko Kinetic but I am guessing that is your current watches malfunction.
The button at 2 o'clock depresses a tiny lever inside the watch, and that in turn releases a discharge from the capacitor.
The strength of that discharge swings the indicator.
The lever itself is very very small, and can be misaligned, very commonly after capacitor replacement.
Actual breakage of the lever is quite rare.
Does the button have a definite detente when you press it?
Or is it instead like pushing on Jello.
Is the button spring loaded such that it returns to the neutral state on its own?
It is actually a quick diagnosis for anyone familiar with Kinetics; as a quick peek will tell if a broken lever, absent button gasket, need of lubricant, etc.
Aug 08, 2016 | Seiko Kinetic watch
Just got a new Seiko watch but the date won't change automatically
Main cause would be that the date gear teeth have been stripped. This is done by setting the date whilst the hands are trying to change the date themselves (between 10pm and 2am). Always adjust the date with the hands around 6.0clock. You will need to return your watch to where you bought it for repair I'm afraid.
Jan 18, 2013 | Seiko watch - SXDA42 Watches SXDA42 Ladies
Why does my seiko sne039 only work in direct light and the second hand advances 2 seconds with each movement
Its ticking in two second intervals because it is very low on power. It should keep correct time and eventually settle down. It needs a long exposure to a nice bright sunny day and it will be fine once it has a good charge for definate.
Jan 15, 2013 | Seiko Watches
Seiko sne039 only runs in direct light
It will be ticking in two second intervals, This is because it is very low on power. It should keep correct time and eventually settle down. It needs a long exposure to a nice bright sunny day and it will be fine once it has a good initial charge.
Jan 15, 2013 | Seiko Solar Quartz Link Bracelet Mens...
I have purchased a new Seiko kinetic SUN007 mens watch. After hours of swinging back & forth to charge the watch, the 'second' hand still moves in two-second increments. (After charging via movement,...
I have a Seiko kinetic watch and it has behaved perfectly for over two years and therefore I think that yours is faulty.
I suggest you send it to Seiko to have it repaired or replaced under warranty.
Apr 05, 2011 | Seiko Sun007 Kinetic Watch for Men
My seiko 5 automatic runs to quick
Balance spring in your watch is sticking together and causing the watch to run fast. It can happen when watch gets magnetized or there is some oily residue left on balance spring. To fix this you will have to show your watch to the watchmaker, because this is very specialized job to do and the balance spring is so delicate part, it can be damaged by simple touch.
Feb 28, 2011 | Seiko Watch SNXJ89K1
Feb 20, 2011 | Seiko Kinetic watch
Watch stopped while in hospital and now, although running again, has the second hand moving in two second intervals
Some Seiko kinetic watches and other self charging watches do this when the battery is low. If it relies on you moving to keep it charged that may explain why it stopped in hospital. Try giving it a good shake and see if it starts moving smoothly again
Aug 10, 2009 | Watches
Seiko Kinetic that doesn't work
This watch does not have a battery, but has a capacitor which is rechargable. It is not taking a charge, and needs to be replaced. You should take it to a store with a watchmaker ON THE PREMISES. Or you could send it to: www.bscwatchrepair.com
Jun 27, 2007 | Seiko SKA192 Wrist Watch
Seiko Solar Quartz Link Bracelet Mens Watch SNE039 Logo
467 people viewed this question
Top Seiko Watches Experts
Jerry Greenberg
Jerry Greenberg
just-ice
Are you a Seiko Watch Expert? Answer questions, earn points and help others
