Question about Philips VR550 VHS VCR
I have sound but no pitcher from video
I was given a tv (Ferguson F3091) Im using indoor antener /picture fuzzy. I allso tryed to hukup video player (NEC VN214) I get sond but no picture antenr autio video plugs on back of vid are white yello / plugs on tv are white red help me
    Problem Solver:
  • 3 Answers
Red, white plugs are for left and right audio..... yellow is video, your tv may not have a video plug, just speaker plugs
Posted on Jan 21, 2009
How do i set up my tv with my sony vcr
Hi Katie.. If you are using a coaxial cable to connect your TV and VCR, the TV needs to be tuned to channel 3 or 4. If you are using the Yellow, red and white cables, your TV should be on video mode to work.
Sep 14, 2015 | Toshiba 24AF42 24" TV
Anyone have problems with Panasonic TC-P60ST30 with white fuzzy picture mal-function?
Try going into set up menu and look for a screen degauzing function or try setting the screen temp. to warmer or cooler.
Aug 11, 2017 | Panasonic Viera Plasma TV TC-P60ST30
Sound on but no pitcher
Sound on means audio section is ok. No picture is video board problem. Pl check input cables. Or give Hdmi cable input. Disconnect all inputs switch on u should get plain raster that is only dots on screen, or blue back screen, if nothing contact authorised dealer,
Feb 08, 2015 | Panasonic TH-L32C20X 32 inch Multi-System...
Picture fading out but still sound
tv antener may not be in place properlry or the plugs in the back of the tv are not proper
Dec 26, 2011 | Televison & Video
Fuzzy picture wen connecting macbook to tv
Sounds like bad Earths to me... Is it better if it is OFF, the AC/DC power supply? If so then yes, bad earthing between units and earth.
Feb 03, 2010 | Televison & Video
When using cable input video is good but sound has fuzzy static
Your TVs tuner tuned a little off frequency. It could be as simple as having cable box on where you have good picture but fuzzy sound, use the TVs remote to change the channel and then change it back to proper channel. If that doesn't fix you may have wrong tuning type selected in channel set up menu.
Oct 11, 2009 | Toshiba 27A30 27" TV
Im trying to hook up my new lcd tv using a cable box and a dvd player but cant find any diagrams. As of now I can get a picture but the sound is low and can only be turned up by the cable remote. Any help...
it should not be a big deal red and white is sound yellow is video, if you have a converter box and are not getting a signal I would suggest you try moving your antene to get picture. Try hooking the DVD plaer into the TV to AUX 1 or AV1 or AV 2 Or AV3 and make sure the TV is on the right channel on to see Picture and correct level of sound, are you running anything threw a coverter box? Need to know the TV brand to do a diagram. The output from the DVD player shoud go into AV1 and the wire colors should be the same DVD output to AV1 input or AV2 in?
Jul 06, 2009 | Televison & Video
Can hear sound and see picture but it is all fuzzy
u need to reset the screen options back to regular spec if its not a 1080 p tv if its a regular tv you will need to use the 1080 p tv to fix it before you can use it on any tv
May 22, 2009 | Sony Playstation 3 (PS3) Console
Xbox Picture is Fuzzy, and sound makes picture worse
Your TV. Try it on a friends' TV using the proper cables and whatnot and see if that is the prob. I reckon it would be. Oldarse TV's may not handle the newer signal well..
Craig
http://compusure.org
Aug 20, 2008 | Microsoft Xbox Console
Fuzzy Picture when souce is not HD
sounds like you may have a problem with the digital scan card or next hyper module. i suggest calling your neighborhood tv repairman
Mar 30, 2008 | Toshiba 65HDX82 65" Rear Projection...
Philips VR550 VHS VCR Logo
147 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
