Question about Hamilton Beach BrewStation Deluxe 47474 12-Cup Coffee Maker
Hamilton Beach Brewstation won't keep coffee hot enough.
After just a couple minutes after brewing coffee is only warm, not nearly as hot as most coffee makers.
  • 3 Answers
SOURCE: I have a Hamilton Beach
http://forumappliances.com/images/Hamilton%20Beach/Hamilton%20Beach%20Parts/Hamilton%20Beach%20P-990021600.jpg
IF BY BOTTOM YOU MEAN BOTTOM OF THE POT, YOU'LL LIKELY NEED A REPLACEMENT POT (CALLED A TANK). REPLACEMNT PARTS YOU NEED ARE NO WHERE TO BE FOUND BY ME AND I HAVE LOOKED FOR HOURS.
Might want to call to assure this will work in your model Brewstation.
This vendor is in canada. $9 CDN is cheap enough.
Posted on May 16, 2008
SOURCE: Need to clean my coffee maker
me to dont know, sorry
Posted on Dec 18, 2008
SOURCE: Hamilton Beach Stay or go Coffee Machine
I finally got in touch with the Hamilton Beach (1-800-851-8900 between 8:30-4:00 EST) and found out that Model 45235G replacement carafe is available for order from them for $25.98 (S/H included) plus state sales tax.
Posted on Jan 29, 2009
  • 3 Answers
SOURCE: Leaking Coffeepot
I have the same leaking problem. I just called Hamilton Beach and gave them the model and serial numbers. They are sending me a new "gasket" complimentary but she said if that doesn't work, I'll have to order a whole new coffee tank.
Posted on Apr 09, 2009
  • 68 Answers
SOURCE: Hamilton Beach 40540 Brew Station 40-Cup Coffee Urn, Silver
Try to see your manual.
Posted on May 18, 2009
How do I get a copy of a manual for a Hamilton Beach Brew Station Deluxe Model #47454 ?
The manual is available on the Hamilton Beach product page: http://www.hamiltonbeach.com/coffee-makers-legacy-products-brewstation-deluxe-12-cup-coffee-maker-47454.html#careguides . (If needed, click on the Use and Care Guides tab.)
The direct link to the Use and Care Manual is http://useandcares.hamiltonbeach.com/files/840160504.pdf . (Note: Adobe Reader or a similar program is needed to read or print the manual.)
I hope this helps.
Feb 24, 2015 | Hamilton Beach Brewstation Brew Station...
Hamilton beach brewstation will not brew
Can you define will not brew? Do you mean no water transfers from the holding tank to the brew carafe? Does coffee not heat up?
Apr 11, 2013 | Hamilton Beach BrewStation 47665
Hamilton Beach BrewStation 12 cup Coffee Maker, coffee leaks into the bottom water reservoir after brewing.
there is a small rubber flap valve in the tank. if you carefully clean that on a regular basis your problem should end.
Dec 26, 2011 | Hamilton Beach BrewStation
Hamilton Beach brew station dispenses very slowly. I have cleaned it twice but still takes a long time to fill a cup!
Try to have a look whether there is a limestone layer built up on the element.
That will slow it down, while most probblems will stop it alltogether.
Remove by leaving white vinegar in it overnight.
Sep 04, 2011 | Hamilton Beach BrewStation Deluxe 47474...
Brews finw but won't keep coffee hot
Could be the thermostat sensor, or the warm mode heating element, or the section of the control module for the warm mode. The details are model dependent.
If the coffee maker is out of warranty, it may not be worth servicing.
Jerry G.
May 12, 2010 | Hamilton Beach BrewStation 47224 Coffee...
Stops brewing before all water empties from reservoir
I went to Hamilton Beach site and read the troubleshooting. I followed there cleaning instructions and reduced grind time on my coffee and the machine is working perfectly again. I stressed over this problem for a long time before following their operating instructions. Have had the machine for over two years now and it's back to working perfectly. i.e. Run a pint of white vinegar through it. Wait 30 minutes and run another full vat of water....wait again and run another full vat of water. If you're grinding your own coffee, you may be grinding it too fine. Otherwise Hamilton Beach recommends the kind of coffee to use. Also the problem maybe too dense of a filter. This is all info I got on the H. Beach troubleshooting site. Good Luck !!! Mine is back to working great !
Jul 24, 2008 | Hamilton Beach BrewStation 47214 Coffee...
My brewStation 47214 stopped pumping water today, even though the warming element continued to get hot. A half dozen screws later I discovered a second heating element inside the coffee maker. The internal element is what heats the water and forces it into the basket. This element was burned out, religating my brewstation to the garbage. Probably last 3+ years.
Jul 11, 2008 | Hamilton Beach BrewStation 47214 Coffee...
I have a Hamilton Beach Brew Station Deluxe coffee maker that has been leaking from the bottom of the unit with almost every pot that is made.
Apr 30, 2008 | Hamilton Beach BrewStation 47224 Coffee...
Hamilton Beach BrewStation Deluxe 47474 12-Cup Coffee Maker Logo
155 people viewed this question
Top Hamilton Beach Coffee Makers & Espresso Machines Experts
jason
Greg Cann
Greg Cann
Are you a Hamilton Beach Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
