Question about Honda Electrical Supplies
Honda ex 5500 generator overheating - Honda Electrical Supplies
4 Suggested Answers
SOURCE: Honda 5500 Generator
If you have checked the stator, rotor and brushes and they appear alright then it is probably a voltage regulator. The honda dealer can run a test and confirm the problem at very little expense. It cost me 25 dollars Canadian to preform the test and it was well worth the money because you cannot return electrical parts and they can be very expensive. Have a great day!
davedulmage@sympatico.ca
Posted on Aug 14, 2009
  • 5603 Answers
SOURCE: Honda motor runs fine but will not generate power
try this site:
http://www.endtimesreport.com/dead_gen.html
Posted on Nov 02, 2009
  • 12 Answers
SOURCE: RGH 5500 IE never used.
check to make sure your spark plug is clean and that your rpm is set right. if the rpm on the engine is not right it will not put out the right current and you will burn something up. take a lamp with 100 watt or higher bulb or an old power too and plug it in and turn it on and see if the motor speeds up. if it dosent then you have a rpm problem that could be as simple as the sparkplug or gas to the governor not letting the engine speed up. both are simple fixes. if the engine does speed up then you have either an armature problem or or a regulator problem. if it has never been used then it may be under warranty and should not cost nothing to repair it.
Posted on Sep 08, 2011
I have a honda ex 5500 generator that keeps triping the on and off breaker to the outlets what could it be
Hi there. 1) Remove all loads and start up.2) Connect a known working load and if it trips on a load too small then the tripswitch is faulty and must be replaced
Dec 10, 2016 | Honda Electrical Supplies
Why ex 3000s does not produce electricity
Residual magnetism of the rotor out. Lift one brush off the slip rings and flash a 12 volt battery on the rings. Reconnect brushes and start engine no output? Repeat then seek help as I need to put my grippers on it to check
Jun 20, 2014 | Honda 3000 Watt Portable Generator
How to measure the stator on a honda ex 5500 generator
You need a volt meter an ammeter and a variable power supply and with ohms law the resistance can be calculated. V=IR thus resistance is the applied voltage devided by the current R=V/I Set the psu till a convenient current is indicated on the ammeter and take an accurate voltage reading and do your calculation. Normal multimeters cannot read reliably below one ohm and these rotors do have a low resistance
Jun 09, 2014 | Honda Electrical Supplies
I have an older honda ex 1000 that just will not charge,
When you say "can't get to charge" are you talking about the low ac voltage coming out or receptacles or what?
Mar 11, 2014 | Honda Electrical Supplies
Honda EX 800 does it have fuel filter in gas tank
You need to change the small thing that lets fuel flow into the carb... "turn fuel off and on gauge" do u understand GetMonthlyPay com Get Your Guranteed Home Job for 1500 weekly ?
Jan 12, 2014 | Honda Ex-800 Portable Gasoline Generator...
HELLO, The Problem I'm having is My Honda EX 800 Generator, The Problem is, it's loud and also has a loud rattle, ANY IDEA'S ????
When it comes to gas generators "quiet" is a relative term, the EX 800 is quiet relative to other gas generators yes, but is not quiet by any means. If you hear a rattle check the panels for a loose sections which you should be able to hand tighten with a screwdriver from either end of the unit.
May 16, 2012 | Honda Electrical Supplies
I have an EX 5500 Honda generator. Carburetor was lost. How can I get one?
Your local small engine service center will be able to get you a replacement.If you had posted your zip code I could of even found one for you.
Jan 28, 2010 | John Deere A,b,g Tractor Carburetor Float...
Aug 13, 2009 | Northstar Generator 20 Hp, 13,000 Watt,...
Electrical Supplies Logo
112 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
