Question about HP Color LaserJet 9500HDN Printer
Hp colour laserjet 9500 hdn with noise and fuser error 50.6 .
Fuser unit replaced with new one and then also the problem remains same.noise coming first and after tat fuser error 50.6
    Problem Solver:
  • 16 Answers
Look at fuser rollers and make sure the new one doesnt have spacing to far in between rollers. Also on front side of fuser there is a big connector that meshes with one inside machine. The fuser connector assy RG5-5925-000CN could be broken as well
Posted on Mar 02, 2010
50.6 fuser error problem.new fusekit installed but same issue accord
Posted on Oct 05, 2012
Getting a 50.6 FUSER ERROR on a HP color Laserjet 9500 printer. I bought the image fuser kit and replaced it. Still getting the error. Suggestions?
check the connector that the fuser connects to for damage. If the plug is intact you will probably need to replace the power supply (Low Voltage PS) C8546-69003 is the part number
on a unit of this vintage the part won't be cheap. A quick search on the net shows it from $350 - $600
Good luck
Dec 04, 2015 | HP LaserJet 9500n Printer
I have hp colour laserjet cm6040f mfp, that displays error 50.A fuser error. pls your help is so much important
You will need to order a fuser and replace it or call a service tech who can. The problem is that the electronics on the fuser have actually burned out, so that is why the whole fuser needs to be replaced.
Aug 29, 2011 | HP Color LaserJet CM6040f MFP Q3939A...
Hp 9500 hdn - error message 57.70. Can I relace the fuser kit to repair the problem?
No!
The 57.7 error says that the fuser fan could be bad.
If you take the back cover off the printer and look to the right, you will see two fans, one above the other.
The bottom fan is the one you want. It is probably clogged with dirt or else the dirt got inside the fan and is preventing it from spinning. Replace it
Apr 04, 2011 | HP LaserJet 9500n Printer
Hp color laser jet 9500 hdn i have this message error 49.4c02
Unplug the printer from the pc or the network to clear the error, the upgrade the firmware.
Jun 09, 2010 | HP LaserJet 9500n Printer
HP Laserjet 2840 when operating is making a really bad squeaking noise, what do i need to do, is it just a case of removing all the colour laserjet cartridges and cleaning the printer and lubricating, when...
If you hear the noise when you power up when just the transport is running, you may need a new fuser. If the noise only comes during printing after the transport starts it could be a bad laser unit. The levels should not be changed by removing the cartridges.
Jan 05, 2010 | HP LaserJet 2840 Printer
HP Laserjet 5m, appear error code 50...please help.
Error 50 will be a faulty fuser unit or DC controller board. Try replacing the fuser unit.
May 20, 2009 | HP LaserJet 4m plus Printer
HP Colour Laserjet 3550 printing problems
I can tell you that it is NOT the Fuser unit. I would change the drum unit first. This would be the most likely cause.
Mar 11, 2009 | HP Color LaserJet 3500 Printer
Hp laserjet 2840 all in one gives FUSER ERROR
For any fuser error, the first thing that should be done is replacing the fuser. If the error still shows up after wards, it could be the LVPS (Low voltage power supply) or a board.
May 26, 2008 | HP LaserJet 2840 All-In-One Printer
HP LaserJet 4 printing but binds up
Have you tried reinstalling the fuser? I am thinking the gears are not driving the exit rollers. If you purchaseda rebuilt fuser, there may even be a gear missing. Compare your new fuser to the old one.
May 09, 2008 | HP LaserJet 4 plus Printer
HP Laserjet 9500 HDN
magenta motor is knackered, change it. the clunking noise when printer starts up is the fuser gears meshing together, nothing to worry about. you can change/swap the motor with another motor and see if the startup error message changes from 59.6M(magenta) to 59.C(cyan) or something similar.
Apr 03, 2008 | HP LaserJet 9500n Printer
HP Color LaserJet 9500HDN Printer Logo
881 people viewed this question
Ben Johnson
