Question about LG Microwave Ovens
Lmv1681ss lg microwave keypad not working - LG Microwave Ovens
2 Suggested Answers
MicrowaveSvc
  • 9047 Answers
SOURCE: lg lm1935 keypad
I answered this one the phone before I got to it online.
William E. Miller
Posted on Oct 11, 2008
Lg microwave reset button?
press start button twice it sounds as if it is still in child lock mode
Mar 27, 2014 | Microwave Ovens
LG touchpad doesn't work
use the common sense,logically, fix it. God bless you
a stuck key or non-responsive key, most of the time you will have to replace the keypad for this microwave oven repair. If your keypad is connected to your control board by a flat ribbon wire, try disconnecting it and clean the silver contacts with an ordinary pencil eraser. After cleaning, plug it back in and try it. If it doesn't fix it, replace the keypad unit. Some units actually have keypad tests to confirm your diagnosis of a bad key.If your keypad and control is the same unit, replace that unit. Another note, unlike stove/oven keypads and controls, most microwaves do not have error codes or tests to distinguish whether it is truely the keypad or control. Most of the time, it is the keypad that needs replacing, but a small percentage of the time it can be the control. Check the tech sheet if they can point you to the right part.
Aug 02, 2012 | LG Microwave Ovens
Buttons not working on keypad of microwave
The keypad control board is defective and must be replaced.
Apr 22, 2012 | LG Kenmore 1.2 cu. ft. Countertop...
LG microwave LMVM2075ST panel started acting crazy after I cleaned it. Will not do anything if I push a button except beeping noises. Any suggestions as to what is going on with this machine? Should I try...
liquid probably has entered keypad laminate; causing a short. unplug unit, direct warm hairdryer to entire keypad; plug back in; and hope for the best. if no luck; replace keypad. also never spray anything directly onto keypad; always clean with a moistened towel with light force.
Sep 07, 2009 | LG LMVM2075 Microwave Oven
Lg lm1935 keypad
William E. Miller
Oct 10, 2008 | Microwave Ovens
LG Microwave oven LMVM2055ST
Same issue here. LMVM1935 about 2 months past warranty keypad stopped working. Apparently they need to add something in the manual about not boiling water on the range over which the microwave is installed (gee who would have thought that there would be steam over the cooktop and we should seal the membrane?).
The silver traces on the keypad got corroded and no longer conduct. After complaining to Sears (NO HELP) and LG (EVEN MORE INEPT) and running on 30sec button for about 6 months, I found a replacement keypad $30 w/ shipping and didn't break anything taking the door apart, thanks to the parts list link above. Thanks Rickzilla!
Life's Good, Their Keypad SUCKS, or apparently we are the only people that boil water anymore.
Sep 05, 2008 | LG LMVM1935 Convection/Microwave Oven
How to replace keypad on LG Microwave
If you might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
It's at http://www.microwavedisplay.com/keypad_replacement.pdf
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 20, 2008 | LG LMVM1935 Convection/Microwave Oven
LG LMVM2055SB over the range microwave keys not working
Is it possible someone may have sprayed cleaner directly onto the keypad area?
This causes moisture to get into the keypad and sometimes onto the control board.
This could mean that they control panel frame with keypad (membrane switch) would need to be replaced.
Can you give more details on the cleaning?
Nov 18, 2007 | Microwave Ovens
Microwave Keypad not working
This model does have a child lock. If it's on, the display will say "LOCKED". It is turned on and off by holding dfown the "0" key for 4-5 seconds. You may also have a bad keypad, which in many cases can be replaced. A bad keypad may be worn out due to age, damaged, or it may have gotten wet or otherwise contaminated. Moisture and contamination can be caused by spraying of cleaners, by storing the microwave in an unheated garage or shed, or infestation. I warn my customers to never spray cleaner directly onto the microwave keypad, since the liquid can get inside and "lock up" or even ruin the keypad or controller. Apply an alcohol-based cleaner (such as the purple kind) to a cloth (paper towels can scratch) and gently wipe it off. I suggest to my customers that they NEVER use any ammonia-based cleaner (like the blue stuff) on a microwave, since the ammonia will crack and distort polycarbonate plastics. Repost if you need more help.
Nov 04, 2006 | LG LMVM1935 Convection/Microwave Oven
Microwave Ovens Logo
55 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Greg Cann
Greg Cann
Devabhakthuni...
Devabhakthuni...
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
