Question about Stanley CT10C Heavy Duty Staple Gun/Cable Tacker
What staples fit the "TUV" staple gun? - Stanley CT10C Heavy Duty Staple Gun/Cable Tacker
  • Jess Stengel Oct 21, 2013
    The TUV staplers require European metric staples. Not easy to find. You can get them at Joann Fabrics. The brand is "Interior Accents" SKU 516-1732 $2.99 per 1000
  • Valkyrie-MT Apr 17, 2014
    I have the same stapler and I have a box of those Interior accents staples. After measuring with digital calipers, it appears to require Type 53 Staples. You can buy various lengths of Type 53 staples on ebay. Mostly from the UK.
5 Suggested Answers
SOURCE: staple gun
Open the chamber and drop the staples upright in to the chamber do not try to load the staples by placing them on the strip that pulls out as you do with most staple guns.
Posted on Nov 25, 2008
  • 699 Answers
SOURCE: my gun will not shoot staples after loaded I thin
Staple gun are simple device and the 'shooting' mechanism is just a sring loaded bar that hammers the staple out: the problem is usually a jam/stuck staple where the staple in the orifice where the staple comes out. Just use a small screwdriver and /or plier to remove the stuck staple which could be jammed against the hammer bar. You may need to force the hammer bar backwards with the help of your small flat head screwdriver.
Hope it helps!
Posted on May 02, 2010
  • 4090 Answers
SOURCE: I'm stumped -- I just bought a Stanley Heavy Duty
The question here is what are standard staples in YOUR opinion? Are they designed to be used with this staple gun. What length are the legs of the staple 1/4" or less.
You cannot just use any staple in these guns They have to be the correct type either stanley or Bosh
Please rate my help++++Thanks for using FIXYA
Posted on Jun 20, 2010
  • 34 Answers
SOURCE: I have a very old Bostitch staple gun Model T5.
You should not need any tools to lift the guard/nose piece. The T5 nose piece cleary has engraved on it "Pull Up To Insert Staples". To remove old staples, use a pencil or similar rod to depress the hammer/striker above the staples while the nose is open.
Posted on Aug 07, 2010
What staples fit in tuv gs staple gun?
Hi Marie
I believe this gun uses S3 staples with varying lengths of "legs" depending upon what material you're trying to staple. Any building material or hardware store will easily be able help you out on this one if you take the gun to them.
Hope this is helpful.
-Steve
Mar 29, 2015 | Tools & Hardware - Others
How do I adjust arrow manual staple gun to fit the sizes it recommends...one size seems to be too large
there is usually no adjustment for manual staple guns. you can only fit the length of staples that slide into the holder.
Mar 02, 2015 | Arrow Tools & Hardware - Others
Craftsman 68514
The replacement pack for this gun say the staples are compatible with "Craftsman 68514 and 68517; Arrow Brand T50 Staplers T50 and T55; and Stanley/Bostitch TR110 and BT110 staple guns", so I assume they are also backwards compatible. That's just an assumption though.
Mar 22, 2013 | Arrow Tools & Hardware - Others
How to load staples?
    • 1 Push in the push rod plate on the back of the Arrow T50P and press down to unclip the push rod from the gun. Pull the push rod out of the staple channel and away from the staple gun.
    • 2 Insert a strip of staples into the channel with the tips of the staples pointing toward the bottom of the staple gun.
    • 3 Place the end of the push rod into the staple channel of the gun. The end of the push rod has a small, solid piece of metal that fits into the staple channel.
    • 4 Press the rod all the way into the staple gun until the rod plate engages in the notch at the rear of the gun.
Jun 26, 2011 | Arrow T50P ARROW STAPLE GUN
The info on the gun says it will shoot many different staples, but it will only take 3/8 staples and I need to use 1/2 staples to do the job.
The T50P stapler uses T50 staples of various lengths, including 3/8, 7/16, and 1/2. Is it possible that the 1/2 inch staples you are trying to use are not T50? All T50 staples are the same width and should fit your stapler. There are several other widths of staples that are not T50, although T50 is the most common.
Nov 29, 2010 | Arrow T50P ARROW STAPLE GUN
I am luking for staples for swingline- power gun 1000
Go to your local Lowe's, Home Depot, Ace, or any other hardware/home store... in the nail/fasteners aisle.
Many staple manufacturers make them, sold by box of 1,000 and up. Just check what number gun they fit.
(example: box states "fits no. 800, 900 and 1000 staple guns.)
As long as "1000" is part of the list, they'll fit.
Feb 01, 2010 | Staples Swingline® 36115 Staple Guns Tools...
How do you adjust the staple size to load 1/2" or 1/4" staples?
Staple guns can use a variety of staples; the width of the staple is fixed, the lengths vary from 1/4" up (usually in 1/8" increments). You don't need to adjust the staple gun for the different lengths, just be sure the width fits your gun since some manufacturers have used brand-specific staples.
There are also a variety of staple types; there are staples for ceiling tile, electric wire, window screening, etc. My favorite staples for wood have the tips cut on a sharp angle, they penetrate wood well. Some staple types require a particular gun, I have a gun that shoots only round-top staples for small cables like phone & thermostat wire.
Dec 05, 2009 | Stanley CT10C Heavy Duty Staple Gun/Cable...
Reloading ace 22084 staple gun
Hello there:
when you purchase staples for this particular gun even though you might get a staple that is says it fits this gun you need to look at the type of staple if you get the one that says heavy duty it will not work it took me 2 times to find out the right ones for this gun it comes in a green box and says standard duty on it not heavy duty this is where most people make their mistake. ok?
best regards michael
Oct 03, 2009 | Ace Hardware Ace Staple Gun
Stanley CT10C Heavy Duty Staple Gun/Cable Tacker Logo
3,411 people viewed this question
Top Stanley Tools & Hardware - Others Experts
John Trevino
yoopertech
Are you a Stanley Tool and Hardware - Other Expert? Answer questions, earn points and help others
