Question about Vertex FNB-27SM, YAESU,FT-26,FT-76,FT-415,FT-416,FT-815,FT-816,FT-530, 12v 1500mAh NiMH 2-Way Radio
Yaesu ft-815 Just replaced battery working but no sound and no sql
    Master:
  • 623 Answers
Double check that "TSQ" is not enabled. In the menus you can fine "SQL" and select the type of squelch. If you have "TSQ" selected you'll only hear signals from radios that a re transmitting the CTCSS tone selected.
Posted on Oct 30, 2013
4 Suggested Answers
  • 518 Answers
SOURCE: Yaesu FT-50R battery drain
I have the same radio.
Does the radio work? Could it be the battery that's getting hot?
Geno
N8BHG
Posted on Feb 20, 2008
  • 11 Answers
SOURCE: I need to replace the internal lithium battery on
I have a Yaesu FT-415 and the same problem. My original battery is a SONY 1220-VJ2H (solder tabs, blue insulation on the outer edge and two stick-on paper insulaters) and is soldered in to the Control PC board (mounted vertically). I'm going to get a new battery and hopefully am brave enough to get the soldering iron to the board. It looks like you have to unsolder the board from the speaker to lift it up enough to get at the solder tabs on the battery, luckily I have access to a Pace soldering station with a vacuum pump. I'll hopefully try this next week and get back to you all.
Posted on Jul 11, 2009
  • 211 Answers
SOURCE: yaesu ft 1500 m
Here you can see the schematics http://www.repeater-builder.com/yaesu-vertex-standard/ft-1500/ft-1500m-sch.pdf
The manual can be found on the Yaesu website, http://www.yaesu.com/indexVS.cfm?cmd=DisplayProducts&ProdCatID=106&encProdID=92FB2363C1E0B9EBC9D3479054E0120B&DivisionID=65&isArchived=1
Good luck,
Gerard
Posted on Jan 30, 2010
My Yaesu Ft-857 transmits ok on 2 meter. But the receive only work sometime?
Sounds like a bad receiver in the radio.
Have you checked the VSWR of you antenna system?
Did it ever work with the current setup?
If so has anything changed with the programming of the radio or the antenna system?
Does 70cm work OK?
Are you sure menu item 080 is set to "SQL" and not "RF-GAIN"?
Are you sure the receiver is not programmed for tone squelch?
Either of those settings could cause receive problems if not used properly.
Sep 26, 2014 | Yaesu FT-857D transceiver
Yaesu ft 416 ver a2 need reset to get extended receive
You may find detailed instructions for this on www.mods.dk
Jul 03, 2011 | Vertex FNB-27SM,...
Hello! I've a couple of battery packs yaesu FNB27. The old NiCad batteries do not work. I want to replaced it by new LiH type. What is the best way to open the battery case without damaging it? thanks...
It's difficult to open the Vertex packs without ruining them. FNB27 is widely available on eBay or you can get them from manufacturers such as W&W in Hicksville NY online. I don't know if anyone has made them in Lithium Ion yet.
Mar 13, 2011 | Vertex FNB-27,...
I need a new battery for a yaesu ft 26
Try "Batteries Plus" either online or possibly a local outlet. I found the batteries for my FT51 there and half the price of the factory ones.
May 19, 2010 | Vertex FNB-27SM,...
Yaesu ft-50r HT getting very hot and not charging battery
From the description your battery has one or more shorted cells. Replace the battery.
Mar 15, 2010 | Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R,...
Yeasu ft270r handheld do u have a mod for this
Check on www.mods.dk. Pretty sure you'll find one there - you may have to join and pay a small fee but, worth it.
Oct 09, 2009 | Vertex FNB-26,...
I need to replace the internal lithium battery on a yaesu FT-416 - how do I do this?
Jun 17, 2009 | Vertex FNB-26,...
Ft530 heating up on rx
kenwood 44s 28mhz to 24 mhz omes on and gos away
Jun 01, 2009 | Vertex FNB-27,...
I need a memory battery for a ft 50r both sides are sorderd the main board
I just had my FT-50R repaired due to a overheat issue with a reverse polarity diode. When I asked Yaesu to alao check my Yaesu for the memory battery I was told by their top technican that the radio does not have a memory battery in it. I hope this helps.
Apr 02, 2009 | Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R,...
Yaesu FT-416 not Transmitting
Check the connection going to the BNC antenna connector from the circuit board. I have seen this wire break before. KB9EKH
Feb 24, 2009 | Vertex FNB-27SM,...
Radio Communications Logo
238 people viewed this question
Top Vertex Radio Communications Experts
Steve
scott265
Level 1 Expert
eradiostore
eradiostore
Are you a Vertex Radio Communication Expert? Answer questions, earn points and help others
