Question about GTCO CalComp Drawing Board III 34480 Graphic Tablet
Does the drawing board III use WinTab for arcGIS 10?
    Problem Solver:
  • 9 Answers
ALL ESRI ARC Programs as far as I am aware use the Standard GTCO Tablet Works drivers. All GTCOCalcomp digitizers are or were level 1 supported by ESRI and the standard tabletworks driver will work just fine (This only applies to Windows versions of ARC, not Unix or other OS's)
Drivers can be obtained from GTCOCalcomp or from this link at the Interworld Site: http://www.interworldna.com/GTCO/gtco-drivers.php
If your digitizer has a serial interface use the SuperSet code 01 or 11. If you digitizer uses USB then no superset is active or needed (This only applies to GTCO or GTCOCalcomp Digitizers)
Calcomp or Summagraphics digitizers will need to be set to 9600,8,N,1 with High Resolution Biinary output to work with Tablet works. Hope this helps you
Posted on Feb 22, 2015
3 Suggested Answers
SOURCE: Autocad 2008 et Drawing Board III (is there compatibility?)
If you are using the drivers supplied by GTCO, they won't work with Autocad 2008.
They are not a fully compliant Wintab driver. Check with the Autocad software to be sure of what kind of tablet driver it needs.
There is a site called www.vtablet.com that sells a tablet driver that is fully Wintab compliant.
Posted on Jun 10, 2009
SOURCE: GTCO Calcomp Drawing Board III connects but won't function...
I HAVE CALCOMP DRAWING BOARD II BUT MISSING ALL CONACTION FOR IT ( CHARAGE , POINTER , 1/O )
PLEASE WE NEED PAY THIS CONACTION FOR RUN
MY EMAIL SAYEDTEBBIN@YAHOO.COM
Posted on Nov 13, 2009
GTCO CalComp Drawing Board III 34480 Graphic Tablet.lectra tablet utilities is not running
First conform that serial port is selected as NONE on digitizer manager while you running the lectra tablet utilities. If you try this already please check your cable connectivity any one of the line may be missing connection. It may work but you can't able to run lectra tablet utilities.
Jun 19, 2011 | GTCO CalComp Drawing Board III 34480...
Dell M6500 w Eports Dock setup rollup Serial Dig. Tablet Works Can not find (10.09 ver)
The GTCO drivers only recognize Com ports 1 and 2, if you are using a serial port for communications.
If you are using the USB driver for Wintab, the drivers may not recognize the E-Ports.
I would try the USB driver and cable,(CAUTION) the RUD III,gets its power from the USB cable,so don't plug in a power supply and the USB cable.
Only use the USB cable when using the 10.9 drivers.
Jan 11, 2011 | GTCO Roll-Up III Digitizer
Jan 06, 2009 | GTCO CalComp Drawing Board III 34180...
Digitalizzing problem
I have a problem with the same hardware and software. I'm using AutoCAD 2008 and when I trace an object that is 1:1 it come into AutoCAD as a different scale. I have tried different scale factors in AutoCAD and nothing.
Jun 02, 2008 | GTCO CalComp Drawing Board III 34180...
May 30, 2008 | GTCO CalComp Drawing Board III 34180...
I think that the II and the III is the same.
(sorry for my bad english)
I have the II and I have the user's manual, but my scanner it's death...
Mar 26, 2008 | GTCO CalComp Drawing Board III 34600...
If you need documentation, go to GTCOCalcomp.com and they have FREE documentation for your tablet.
It may be a software switch is turned on and is causing this problem. Also check the driver and turn off any mapping.
When you read the manual it will show you how to turn off/on the software switches on the tablet.
These tablets should boot-up in the GTCO binary mode.
Feb 14, 2008 | GTCO CalComp Drawing Board III 34480...
This tablet,when turned on,should only beep once.
It sounds like their may be a hardware problem or corrupt firmware.
Make sure you are using the correct power supply, these use a 12 volt power supply,center negative.
If this fails contact GTCOCalcomp Tech Support.
Sep 13, 2007 | GTCO CalComp Drawing Board III 34480...
GTCO CalComp Drawing Board III 34480 Graphic Tablet Logo
283 people viewed this question
Top GTCO Computers & Internet Experts
David Payne
David Payne
Are you a GTCO Computer and Internet Expert? Answer questions, earn points and help others
