Question about Palm AT&T C/PHONE PALM CENTRO S64801
My palm centro wont turn on. it has the red light on but its not on the charger
  • 9 more comments
  • Jagjit Mahal Jan 21, 2009
    I have first time refilled the HP Black Cartridge # 27 as per the instructions. On running I am getting "Cartridge Error". I have also tried after cleaning the contact points of the cartridge and printer but still does not work. Please advise.
    J.S. Mahal
    www.jsm2u@gmail.com
  • Anonymous Feb 01, 2009
    red light is on and the phone won't turn on
  • boss g Feb 11, 2009
    i have the same problem . solution
  • Anonymous Feb 14, 2009
    My palm centro has a red light but will not turn on?
  • arich46 Mar 18, 2009
    My palm centro will not turn on. The red light is on but I cant get it to turn on.
  • Anonymous Mar 20, 2009
    this phone is such a piece of ****.
  • hannahgirl3 Mar 25, 2009
    i was texting on my phone then the keys wouldnt work?!
    and then i was like kay,so i took the battery out and
    went to turn it back on...but it didnt turn back on..
    so yeahhh!
  • Anonymous Apr 01, 2009
    my centro died so I turned it off
    the next morning I plugged it in and it wouldn't turn on
    I tried taking out the battery and everything
  • ledoux Apr 10, 2009
    My palm centro will not do any thing,red light comes on.
  • Anonymous Apr 17, 2009
    my f****** phone just wont turn on!!!
  • Anonymous Apr 22, 2009
    2nd phone that ive had. same thing happened to the last one. such pieces of sh!t
Hey i had the same problem but just a tad different, my phone just wouldt turn on in general so i plugged in the phone and just started messing with the keys, i dont know if that will help but its worth a try
Posted on Jan 29, 2009
  • ihaveanidea Jan 29, 2009
    o yea after i messed with the keys it turned on
My PALM Centro will not charge i have it plugged in via USB my AC charger quit working months ago and i threw it away. Therefore i have it plugged in via USB and the LED at the top it green but barley on...
Hello salvidor72,
It's more effective to use a charger than the usb adapter. The wirelessemporium.com web site has a nice deal on a Palm Centro PDA Phone Home/Travel Charger:
http://www.wirelessemporium.com/p-16501-Palm-Centro-PDA-Phone-Home-Travel-Charger.asp?refer=bizrate
You may also do a google search for palm centro charger. I hope this helps.
Have a great day, martyshaw152
Feb 22, 2011 | Palm Treo 500 Centro
My centro's charger when plugged in does not turn the light on or charge the phone after i changed chargers. So what could be wrong with the phone?
Sounds like the charger is faulty. Do you have a USB cable if so plug into a computer and see if it charges it
Apr 04, 2010 | Palm Treo 500 Centro
My palm centro will not turn on the red light just blinks and occationally it does come on
Hello abevagota25,
A flashing red indicator light (upper left-hand corner) occurs when the Centro is connecting to the the cell phone network. The light will continue to blink until it gets a strong enough signal to make a good connection. Try turning the phone on from different locations to see which one makes a good connection
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Feb 02, 2010 | Palm Treo 500 Centro
Palm cantro keeps hot syncing can not use my phone
this has also happened to mine like yesterday, dont remove the battery mine wont turn back on now, try letting it charge overnight withoout touching it at all
Oct 23, 2009 | Palm Treo 500 Centro
Treo very hot and not turning on
I think your battery failed. When the red light is on that indicates the unit is trying to charge the battery, and it usually will get a little warm, but if it's really hot then a cell in the battery has probably failed.
You will need to take it to a dealer and get a replacement battery. (I've had to replace the battery in my Centro twice since I got it a year ago!)
Sep 23, 2009 | Palm Treo 500 Centro
Put the battery in the red light comes on and wont turn on
Will it turn on if the phone is plugged into the charger? Pull the battery, clean the terminals on the phone & battery, let the phone set or 30 minutes and reinstall battery. If it fires up, I would suggest syncing the phone immediately, then performing a hard reset and resync.
If that doesn't work , the battery could be the issue, but the phone is more than likely becoming unstable.
Sep 21, 2009 | AT&T Palm Centro Cell Phone - White
Palm Centro will not charge. Red lite comes on
Jim,this shows that the charger and the charging circuit are fine and kicking. Only the battery is debatable. If an old battery then it has gone. even not so old battery could be the culprit. so, replace it.
Sep 08, 2009 | Palm Cell Phones
My palm centro was hot cyncing intself
I just googled this issue b/c my daughter got a hold of my phone and somehow (as only an 8 month old can) hotsycned my phone. O
ut of total frustration at the thought of having to replace my phone, I took the battery out and left it on the counter for about a minute. It works fine now.
Aug 04, 2009 | Palm AT&T C/PHONE PALM CENTRO S64801
I drop my phone centro palm into water! I charge the phone and the red light turns on but my phone wont turn on at all. What can i do
Get a bowl of rice. Remove the battery from the phone. Leave the phone back open. Put phone and battery in the bowl of rice, cover and leave overnight.
The rice will hopefully soak up any water inside the phone and battery. If this doesn't work there may be permanent damage to the phone from the water and charging afterwords.
Mar 02, 2009 | Palm AT&T C/PHONE PALM CENTRO S64801
My palm centro kayboard light wont come on.
Have you tried the option key + menu key? It turns dims the screen and toggles the keyboard backlight on and off.
Dec 04, 2008 | Palm Treo 500 Centro
Palm AT&T C/PHONE PALM CENTRO S64801 Logo
581 people viewed this question
Top Palm Cell Phones Experts
Computer Repairing
Computer Repairing
fhonwizards
wayne chamberlain
Are you a Palm Cell Phone Expert? Answer questions, earn points and help others
