Question about John Deere 3010,3020 Tractor Basic Carburetor Repair
3010 John Deere running rich and rough
I have rebuilt the carb..changed the rotor , plugs, condensor,dist cap. Runs rough and fouls plugs
5 Suggested Answers
wilsodfarm
  • 986 Answers
SOURCE: 3020 carburetor ? john deere gas tractor, 3020
those carbs are real simple you will not have any problem
Posted on Jul 29, 2009
SOURCE: John Deere ZTRAK 737 zero turn - runs rough - one plug
My idea would be to replace the coil to that plug
Jim Kite paris, il
Posted on Apr 15, 2011
machinist84
  • 25 Answers
SOURCE: 2003 john deere x465, runs
carb is a good place to start but if pops thru intake you need to do a compression check if you have the means this is the easiest find out or at least make sure it does not have bent or burnt valves but the most common problem for the one you described is the carb.
Posted on Aug 26, 2011
DIESELMUDDER
  • 2760 Answers
SOURCE: yanmar 2 cylinder deisel in john deere tractor runs rough above idle
engine starving for fuel 1 st change fuel filter then check fuel pump then ck injector pump pressure (caution high pressure)
Posted on Oct 05, 2012
Just got used john deere riding mower model L118 with briggs 22 hp v-twin,runs rough and spits back through carb
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Mar 07, 2017 | John Deere Garden
Have a John Deere 11hp. Runs great for 5 minutes, mows fine too. Then is starts to miss and pop and will barely stay running with choke. Then it pops some more and acts like the safety was bumped and dies...
Hi Laurin:
Considering all that you have done, it is possible that you do have a bad condensor. If the consendor has a defective component that reacts to temperature, it may be that when cold, the correct function is happening, and as it warms up (the 5 minutes run time)
the expansion associated with the temperature change causes the malfunction.
Considering the relatively low cost, I'd be considering doing both the points and condensor.
Jul 01, 2015 | John Deere Garden
Have a John Deere 3020 with a Marvel-Schebler carburetor. Not staying running seems like its out of gas and it is getting fuel it runs a short wile and dies pump the fuel pump manual pump and it runs for...
Have you checked that your float is working properly in the carb? If it is sticking with the plunger shut it will block fuel inlet regardless of having fuel supply?
Have you checked to see if there is definitely fuel in the line at the carb when it's acting up?
Have you made sure that there is still spark when it quits running? You could have something that is grounding out when it warms up and makes it quit firing that while you 'fuss' with gas issues, cools enough to spark then fails again. Hard to say without more details. Also are you sure there isn't a clogged fuel filter in the tank, carb-inlet or inline somewhere?
Oct 06, 2013 | John Deere Garden
1980 dodge d50 running bad
My first guess would be a weak coil or something going on with the carb.
It could have jumped time but you would probably hear noise coming from the timing chain.
Can you tell if it is not firing on one cylinder ? Checked compression ?
Too rich or too lean on the fuel mixture ?
Jan 19, 2013 | Cars & Trucks
John deere lt155 lawn tractor shuts off when it gets hot while mowing, could this be electrical?
I had a similar problem lasy year.
Try this:
As soon as the machine seems to be stalling, loosen the gas cap.
If the engine continues to run, clean the gas cap vent hole(s).
Gary
Jun 26, 2011 | John Deere Garden
John Deere 115 lawn tractor - won't start. Replaced fuel filter, fuel pump, spark plug, oil filter (changed oil), but still won't start. Engine cranks, but won't run.
I have a 115 john deere tractor that runs but the engine will not run smooth I've put a new fuel cap on it a new pump and clean out the carb.
Apr 16, 2010 | John Deere Muffler 1010 Diesel Tractors
Car runs very rough 1965 ford 250 3bbl engine. I am not sure what the problem is but the car runs very rough and is using a lot of gas. Is it a carb adjustment or soemthing else? How do I tell if it is out...
well to see if changing the timing helps / loosen the distributor bolt so you can turn the dist , keep track of where it is before you turn it incase it is right . with it running by turning the distributor it will either get better or worse / make sure you have good spark plugs and wires ,make sure there on the right plugs and cap . find the firing order / do a test on them all with them out of the engine but grounded and observe for a bluish strong spark on the plug if it's weak and red color spark you might need to check your ignition points or coil /cap / rotor,even do a compression test, if you have the timing right then obviously a bad carb is next to check
Nov 29, 2009 | 1965 Ford Mustang
BEEN RUNNING ROUGH WITH LESS POWER THAN BEFORE. NOW WON'T START AT ALL. NEW PLUG, CHANGED OIL AND FILTER, HAS A GOOD SPARK.
1956 420 john deere new plugs, wires,cap,plugs,rotor,points set on 20.condenser good blue fire on points and plugs carb rebuilt BUT want start you can pull off it will start and run
Sep 28, 2009 | John Deere 420,1020,2010,2020,2510,2520...
My john deere 737 lawn mower runs ok untill I leave the seat to pick up limbs. When I return it will start running rough and smoking. It seems to be an intermittent problem. It also uses alot of gas. Any...
from what you have said sounds like you have a dirty carb.,try cleaning or rebuilting carb. change air filter,, hope this help you ,, good luck
Aug 15, 2009 | Garden
Jul 04, 2009 | John Deere 3010,3020 Tractor Basic...
John Deere 3010,3020 Tractor Basic Carburetor Repair Logo
99 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
