Question about Encore 802.11G WIRELESS LAN ROUTER W/4-PORT SWITCH
Encore router i have a encore router and i can't connect to the internet coz i don't know the default user name and the password of this router can you help?
  • jhen_bisco
    jhen_bisco Mar 02, 2013
    I used admin as username and password but it didn't works for my router
Default UN and PW: admin
Posted on Apr 08, 2009
What is the device password for encore wireless-N router ENHWI-2AN3? I cannot connect because of this device security password. It says that i should see it on the device or any printed information but i...
normally the password is in BACKSIDE of the device, or in the users manual. But, sice i have the same router, the username password combo is; username : admin password: admin
Apr 06, 2011 | Encore 802.11G WIRELESS LAN ROUTER...
Need the password
You can know password in router settings.
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Mar 17, 2011 | Encore ENAFN-RT514-PR Router...
How to put password on my encore wifi router
Jan 05, 2011 | Encore 802.11G WIRELESS LAN ROUTER...
Icant remember may user and password i cant log in.
Get a paper clip or anything sharp on that size and insert it into the the little reset hole on the back of the router and hold for 15 seconds or so. This should reset the router to manufacturer's settings. Wait for all the lights to stop flashing and remain on, then try to connect to the internet.
Here's a pdf guide. http://www.encore-usa.com/us/sites/default/files/product_documents/ENHWI-N3_UM.pdf
Default user name is: admin Default password: admin
Nov 20, 2010 | Encore ENHWIN3 Wireless Router
How do I lock my Dell TruMobile 2300 wireless router to keep the neighbors from getting access to my wireless internet connection
press win key + r
under run type cmd
on the command prompt type ipconfig
not down your defaut gateway.
type it in your web browser, and then enter the correct user name and password for the router.(i u dont know the user name leave it blank or try admin for both user name and password or its combination o call dell for it)
Create a unique password on your router : Once you have logged into your router, the first thing you should do to secure your network is to change the default password* of the router to something more secure.
This will prevent others from accessing the router and you can easily maintain the security settings that you want. You can change the password from the Administration settings on your router’s settings page. The default values are generally admin / password.
Change your Network’s SSID name:
The SSID (or Wireless Network Name) of your Wireless Router is usually pre-defined as "default" or is set as the brand name of the router (e.g., linksys). Although this will not make your network inherently* more secure, changing the SSID name of your network is a good idea as it will make it more obvious for others to know which network they are connecting to.
This setting is usually under the basic wireless settings in your router’s settings page. Once this is set, you will always be sure that you are connecting to the correct Wireless network even if there are multiple wireless networks in your area. Don’t use your name, home address or other personal information in the SSID name.
This is sufficient to secure your router from other to use it.
Aug 11, 2010 | Dell TrueMobile 2300 Wireless Router...
How to install the router
onfigure your router with below method then all messup will be fixed. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then click on WAn settings and set wan settings as internet service provider settings. Then click on wireless settings then enable wifi also enter SSID name and enable broad cast turn on wifi . If you want to secure wifi then enable WEP in wireless security .Enter code it is your password to connect wifi. Then connect internet cable to WAN port then you can use internet with it. Let me know if you need further assistance. Thanks for using FixYa.
Aug 07, 2010 | Encore 802.11G WIRELESS LAN ROUTER...
Renew password
http://192.168.1.1
or
http://192.168.0.1
Click on wireless settings then WPA Security then not down code .It is your password to connect wi fi..
Then you can connect your wi fi network with that code.
Jun 22, 2010 | Encore ENHWI-N2 802.11n Wireless Router...
Configure the modem without cd installer
You need to configure your router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Click on wireless settings enable wireless then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Apr 22, 2010 | Encore 802.11G WIRELESS LAN ROUTER...
How can i put a connection password on my Encore IEEE 802.11g ?
go to -
Start -> Run -> type CMD and press enter
when the box opens type
IPCONFIG/ALL and press enter
scroll down to the header Connection and look for Default Gateway
Copy this number down - make sure you write it down correctly
now type exit and press enter
open your web browser and type that number into the address bar and press enter
this will take you to your routers setup
enter your password if prompted. if you never set one the defsult Name=ADMIN and default password=ADMIN. if this doesn't work you may have to reset your router by holding in the reset button for thirty seconds and reconnecting to with the same i.p. address you used before.
go to Authentication Security
you can choose WEP or WPA i strongly urge you to use WPA. WEP is a very weak security type
let me know
Dec 25, 2008 | Encore 802.11G WIRELESS LAN ROUTER...
Reset Password
please post the model name of the router
Aug 04, 2007 | Encore 802.11g Wireless Cable/DSL Router...
Encore 802.11G WIRELESS LAN ROUTER W/4-PORT SWITCH Logo
672 people viewed this question
Top Encore Computers & Internet Experts
Michael Galve
Michael Galve
Prashant M
Prashant M
Are you an Encore Computer and Internet Expert? Answer questions, earn points and help others
