Question about Refrigerators
I have a whirlpool side by side refrigerator Model # ED5VHE*V0* and the door that the ice comes through will not shut completely sio moisture is getting in freezer and forming ice on the shoot entrance and where the ice comes out of the bin and goes down the shoot out the door. I am not sure how to get to the little door to see if there is a mechanism that is broken.
catriver
  • 878 Answers
SOURCE: Whirlpool refrigerator ED22TEXHW01 ice maker
Tammi, you first want to check to make sure the water inlet tube to the icemaker is not frozen shut. Next, get yourself a jumper wire about 4 inches long with the ends stripped exposing the wire on each end. Pull off the ice maker cover, it will pull right off. Now you are looking at the module. On the module, left side, you will see two test points marked V and L. Insert one end of the jumper wire into V and the other marked L. You are now sending 120 volts to the water valve and water should fill the ice maker providing the inlet tube is not frozen over. If it doesn't fill, you either have a bad water valve or module itself. Also check to see if the clips that hold the center gear on the module are not broken. Catriver..post back.
Posted on Mar 22, 2007
  • 87 Answers
SOURCE: Whirlpool s/b/s refrigerator - water not evaporating on freezer side - collects & freezes under bottom food bin
Did any of the repairmen replace the heater which is at fault or did all three of them change it? If it has not been changed then I would suggest that it should be. If it continues to be a problem then you can get drainline heaters added to the system but you would need to talk to a fridge guy before they wasted a journey. The other possibility is that the front cover is not inside the drain pan or a leak in the drain pan, and if you have an icemaker you could even get water coming from further up the cabinet. Either way I would suggest picking your favourite of the three and tell them that the problem is unresolved. Most fridge guys offer some sort of warranty on work that they do. Hope this is of some help.
Posted on Sep 11, 2007
watugot
  • 290 Answers
SOURCE: Frost on icemaker door
Most likely the ice door is not closing properly.
Clean out the ice chute and look down it from the inside while you shine a flashlite up from the outside. If you see light around the door then it needs to be replaced or something is wrong with the mechanism.
Post back and let me know what you find.
Posted on Nov 21, 2007
aborcass
  • 2651 Answers
SOURCE: Water collecting in refrigerator and ice collecting in freezer
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you access to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somewhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wire around the heater( black heater right above the drain trough) and stick it in the whole maybe an inch or so. now every time the heater comes on to defrost it will prevent the hole from freezing over
Posted on Mar 15, 2008
aasc
  • 1606 Answers
SOURCE: frost building up in ice maker exit shoot and
Look into the dispensor , and see if the door flap is closing , or letting warm air in which will cause the frost buildup . If not closing completely , remove the top cover on the freezer door hinge , and unplug the plug . This will remove power to the door . Use a small screwdriver , and insert under the freezer door dispensor control board , and pry outward . Remove the 3 plugs on the board . Next , remove the 4 screws holding the white dispensor cover , and slide outward . At the top right , you will see a solenoid and plunger , which control the door flap . Usually , this plunger rusts on the solenoid . Replace both , the solenoid and plunger ( come together in kit ) Pt # WR62X10055 . Re-assemble in reverse .
Posted on Oct 02, 2009
Whirlpool gold refrigerator electronics for icemaker and water are dead
Moisture damage or bad connection. Take apart and check wires and circuit board.
Jul 24, 2014 | Whirlpool Gold White-on-White 21.9 cu. ft....
I have a side by side with ice/water dispenser on the freezer side of the door. a couple of months ago the ice maker stopped working and just today the water stopped coming out the dispenser and none of...
1light not work , may lightbuld loose in the socket , or door switch
2 ice maker not work? may the ice maker arm shut-off. sut-off arm to be on(sure be down position)
3 is the ice maker switch in the off positio ( on some models)
4 is the freezer door not closed completely ? if it will not shut all the way,push the door firmly shut for the water dispenser poblem
5 check water filter. or water valve clogged or bad? replace them if necessary
good uck
Jan 11, 2011 | Whirlpool Refrigerators
Bottom of ice dispencer freezes and wont let ice come out. It is a whirlpool side by side
Check the door flap on the freezer door , which opens to let the ice come thru . If this flap does not close completely , then it will let frost accumulate inside the ice bin , blocking ice from dispensing . If you had given the model number , I would give the part number for the door kit .
Aug 15, 2010 | Refrigerators
Ice build-up in bottom of freezer section.
your defrost drain on the freezer side is stopped up causing the drain to freeze over then eventually running out on the floor during the defrost cycle. Locate the drain at the back of the freezer and thaw it out using hot water. Using a screw driver or other object gently push down into the defrost hole and dislodge whatever is stuck there.
An air hose with good air pressure may also work well. When the drain line is clear you should be able to pour water through it freely.
Jun 30, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
FROST BUILD UP ON ICE STORAGE BIN AND INSIDE OF
Most times this is caused by the dispenser door not shutting all the way. This causes moist air to be drawn in through the opening and the moisture will freeze in that area and also cause the dispenser door to have even more problems closing. Check the door and get me your model number so I can list the parts that are most likely causing this, Thanks Sea Breeze
Oct 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice cube flap door
try this site...input your model # and look for the ice door parts. Maybe a bad spring. They are also very helpful with their chat and phone assist., video repair etc. Make sure to get the model # though.
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Refrigerator/62-5-1414685-/Whirlpool-Refrigerator-ice-maker-overflowing-WRX735SDBM00?r=%2fShop-For-Parts%2fa4b5c21i2659d1414685%2fModel-WRX735SDBM00-Whirlpool-Refrigerator-Gasket-Seal-Door-Gasket-Parts
Best to you.
Oct 22, 2017 | GE Refrigerators
Whirlpool side by side ice maker freezes up. can't get ice out of
Can you give more details?
If the ice chute is frosting up, chute door is not sealing, air , with moisture, is getting in and freezing. An ice cube getting trapped by the door will cause this also. Either case, replace door and delay mechanism.
May 01, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Exterior Moisture
sounds like you have warm air getting into the machine, id check to make sure the doors are closing tightly around all sides with no gaps
Oct 26, 2008 | Whirlpool Refrigerators
Ice maker is not working
hi. thanks for the question. because the door was left open . moisture got into the small tube that lets water in to the ice maker.. and froze. use hair dryer to thaw the tube. remove and clean. thanks the appliance doc. please rate me
Sep 11, 2008 | Whirlpool GD2SHGX Refrigerator
Water dripping from the water dispenser on freezer
If the water is dripping from the dispenser tube, you need a water valve. The valve is not shutting off completely. Check to make sure water is not dripping from ice chute. If the chute door doesn't seal off you will get moisture there and it will also frost up the ice chute.
Sep 30, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
