Question about Avanti Kitchen Ranges
Where can I buy a replacement avanti ER 20AW-1 baking element?
3 Suggested Answers
MNTECH
  • 1543 Answers
SOURCE: baking element
oh bleep, right? well, if you're lucky this will get you going again. 1. disconnect power to range. 2. remove back metal cover just above range power cord (usually 5 quarter inch hex screws) 3. look for burnt off wire leading to/from bake element. If yes, 4. strip ends of broken wire and splice with ceramic wire nut if no 4. bad news. replace ERC (electronic range control) you fried something on the board. It's got the clock display and all the electronics behind it.
Posted on Aug 29, 2008
housejess
  • 317 Answers
SOURCE: Bake element for Maytag MER5765RAS did not work.
look inside the breaker box..find the 220 breaker to the range...make sure both sides are in the on possition....if not then only 110 volts are going to the range instead of 220...hope this helps..thanks
Posted on Nov 08, 2009
Hi! I am looking for a replacement BAKE IGNITER, part no. 10160404.
look up appliance wholesalers, look up authorized dealers for that manufactures.
www.wikipedia.org/mfg.name/make/model/part#/where/to/purchase/
www.ask.com/mfg.name/make/model/authorized/dealer/parts/services/
www.bake.igniter.webcrawler.com/mfg.name/make/model/part#/service/telephone#/
Oct 06, 2015 | Avanti DG-20CSS-1 Gas Kitchen Range
Need bake element for er20aw-1
TAKE MODEL # OF STOVE & ELEMENT TO CLOSEST APPLIANCE PARTS DEALER OR ONLINE D&L APPLIANCE PARTS.
Oct 23, 2012 | Avanti ER20AW-1 Electric Kitchen Range
Er 1 error
Dear Sir:
adjust the speed sensor, see the diagram attached, clean, and tight the connector very well.
2) Test the input voltage motor, if there are the motor need repair or replace.
3) Test the output voltage from the main motor board for the input of motor, if there are NOT, the board is faulty.
4) After fix it, run the software calibration, for diagnose, and troubleshooting.
sincerely. God bless you
Apr 24, 2012 | Avanti Exercise & Fitness
The broiler works and burners work but will not bake
Chances are your bake element is dead. Find replacement part and remove and install as per directions.
Oct 06, 2009 | Avanti Kitchen Ranges
Oven not heating
Check the baking element. It is most likely faulty. Disconnect the power to the unit, and remove the element. Test for continuity with a meter if you can, or just take it with you to an appliance parts supply houst. They can test it, and provide a replacement.
Regards, --W/D--
please feel free to rate my solution
Jul 25, 2009 | Avanti ER20AW-1 Electric Kitchen Range
Getting to heating element/thermal fuse for amana model LED 20AW
I just replaced mine by taking the bottom off, but in hindsight I think I should have been able to do it by just removing the lower front panel. With long arms, you should be able to reach back and loosen the two bolts holding it in place. Good luck!
Apr 05, 2009 | Amana Dryers
Baking element
Aug 29, 2008 | GE JBP90 Electric Kitchen Range
Bake element doesnt work everything else does
Control unit is probably the problem, You should check your Breaker to make sure it didnt trip outside of that you can check voltage to the element with the oven set to bake, if you dont have votage to element then it would most likely be the board. I just checked the wiring diagram for this unit and there is an over limit switch which is a long shot but worth checking. My bet is on the board. There are 2 listings for the part number so if you check on parts make sure you have full model # serial # AND series #(should be a 2 digit number like 10 or something)
Mar 20, 2008 | Maytag MER5775Q Electric Kitchen Range
My ge spectra stove bake element is not heating
I have a GE Spectra stove. The top element over heated and broke in half.
Dec 18, 2007 | GE JKP20 Electric Single Oven
Avanti er24aw1
Call avantiproducts.com sales (service didn't work) and get a replacement bake element. It was about $35 including shipping. Download the manual from the site and study the structure. Uncover the back cover using standard phillips screw. TO DO THIS, SHUT DOWN YOUR HOME BREAKER AND MAKE SURE THE OVEN OPERATION LUMP DOES NOT LIGHT. OTHERWISE YOU WILL BE EXPOSED TO HIGH VOLTAGE. Additionaly use multimeter to make sure the voltage is not there. Remove back inner cover. You can't remove this inner cover completely because of the thermostat line but try to make a work space in the lower part of the oven. The bottom element cover can be uncovered readily without any screw or pin. At this point you have access to baking element from the bottom of the oven. Loosen two nuts to remove the bad element. Reverse the procedure to install the new element.
Dec 03, 2007 | Avanti ER24AW-1 Electric Kitchen Range
Kitchen Ranges Logo
29 people viewed this question
Top Avanti Kitchen Ranges Experts
Craig Butler
Craig Butler
Andrew Taylor
Andrew Taylor
ray gallant
Are you an Avanti Kitchen Range Expert? Answer questions, earn points and help others
