Computer turns off and won't turn back on
Ladytech, still need help the cd drive is empty. please help
    Problem Solver:
  • 19 Answers
IF your computer turns it self off and wont restart for a period of time it sounds like a thermal event is occuring--possibly a bad fan or perhaps dirt has clogged the heatsink
If this is a desktop you can take off the side and blow it out with compressed air (make sure you unplug the computer from the wall and discharge the system), after you blow it out leave the side off and try booting it up and see if the fan is spinning
Posted on Jan 23, 2009
Computer won't recognize external usb hard drive
try it on another computer if that dosent work you should
reformat your computer but first backup all your data by putting your another internal hardrive on your computer and move all your files you need to the empty hardrive and after that take the hardrive with all your stuff in it off the computer and then reformat the hardrive which the external hardrive does not work on and install a new operating system then put the other hardrive with all your stuff back on your computer and transfer your stuff into the hardrive with a operating system then try the external hardrive
OR
you can burn all your stuff into a CD or a DVD
OR
you can put all your stuff into FlashDrives and then after you reformat the hardrive with an operating system put your stuff back into the computer and after that the external hardrive should work
Dec 27, 2012 | Toshiba HDWC130XK3J1 Hard Drive - Canvio 3...
Labtop won't turn on
Turn on, hold F8 button down until boot menu appears. Download Norton Boot Recovry to disc from another computer. Install in ur CD/DVD drive. Boot ur computer. Or install ur operating system disc in cCD rom drive. Reboot computer, hold F2 button down, modify BIOS boot sequence so CD Rom in 1st boot device. Boot computer, repair or reinstall operating system.
Sep 08, 2012 | Toshiba Satellite L355D-S7813 Notebook
On my Toshiba Satellite Laptop I have opened and started the computer but can't get past the sign in window because my enter key and space bar won't respond. I can type letters but can not enter...
> hardware problem or software or keyboard?
Experiment #1: turn the computer off. Connect a USB keyboard. Turn the computer on. Use that keyboard to try the 'TAB' key (to move from field-to-field). If TAB works, then try using the SPACE or ENTER keys.
Experiment #2: turn the computer off. Turn the computer on, and look for the message:
PRESS <blah> to ENTER BIOS SETUP
When you see the message, press the <blah> key. On the BIOS SETUP menus, try the ENTER key to "select" a field, to prove that the ENTER key works fine.
Experiment #3: Turn the computer off. Disconnect the AC power. Remove the battery.
Remove the disk-drive. Take the original CD/DVD disk, and start to install Windows to the disk-drive. As you work through the installation screens, you'll need to press ENTER at least once,
if only to acknowledge that installation cannot proceed, because the disk-drive is not connected.
If the ENTER key works, it works.
Experiment #4: Like #3, but connect a different, empty, disk-drive, and reinstall Windows.
If it completes, then your "original" setup has a SOFTWARE problem.
Jul 14, 2011 | Computers & Internet
I inserted a cd in to the Studio One 1909 and now it won't come out. When I shut down the computer and re start, the eject light comes on the front of the screen and you can hear the disc turning but...
Try to check if you have a small hole on the optical drive (cd / dvd drive). If you see a small hole, use a paper clip to manually eject the disc. Reloading the BIOS default settings of your computer can also help.
Hope this can solve your concern.
Jun 26, 2011 | Computers & Internet
Hello.My ACER Aspire One netbook will not properly load, or load at all actually. It worked fine yesterday, I shut it down.. and when I turn it back on it won't work correctly. It comes to a black load...
Hello my friend. The problem is that the "hard drive" has a lot of bad sectors and the netbook cannot recognise it. The Hard disk might need replace with a new hard disk. Please refer to a computer technician. Please rate my help! Thanks!
May 11, 2011 | Acer Aspire One PC Notebook
Was full - turned off to empty - replaced empty bucket, won'r turn back on and keeps beeping full
Try reinserting the bucket, making sure that it's positioned properly. So that the safety switch is engaged. If that still doesn't solve the problem. Turn the MASTER ON/OFF Switch to OFF and unplug the unit from the wall outlet. Wait 12 - 15 minutes and plug the unit back in. Turn the MASTER ON/OFF Switch to ON and hopefully, if the bucket is positioned properly, the unit will have reset itself.
Hope this helps you to solve the problem. Please let me know.
May 08, 2011 | Maytag Dehumidifiers
Laptop Optiarc DVD RW AD 7530 B is not reading CD or DVD media. 1.DVD icon displayed in My Computer. 2.When I insert DVD or Cd in the drive,Green light flashes and tries to read the nedia and goes off...
2.When I insert DVD or Cd in the drive,Green light flashes and tries to read the nedia and goes off within few seconds.
3.DVD drive in My Computer when clicked shows empty folder
4.Uninstalled DVD drivers in Device Manager and let windows find it on reboot
5.Issue still persists.
6.Right now external DVD RW works perfect.
Please help
Oct 29, 2009 | Sony NEC Optiarc AD-7530B 8x DVD?±RW DL...
CD ROM DRIVE/DVD ROM DRIVE PROBLEM!
it is infecetd by viruses.. scan for viruses..
please vote for me...im sure this will solve your problem...
Sep 14, 2009 | Computers & Internet
I NEED TO KNOW HOW TO INSTALL A CD-ROM DRIVE INTO MY E-MACHINE..
Step1 Turn off your computer and unplug. Remove the left and right side panels.
Step2 Remove the covering of the drive bay that you plan to use for your new CD/DVD Drive.
Step3 Set the jumper. This is the most difficult part involved with the installation process. If you only have one drive for your system set your jumper on the back the drive to Master. If you have two or more set it to slave. Consult your drives manual to see a picture of what a master/slave jumper configuration looks like. It is best to have the fastest drive set as the master.
Step4 After you have set the jumpers insert the drive into the empty drive bay you selected.
Step5 Secure your CD/DVD drive to your computers chassis with screws and a screwdriver. Mounting screws are typically included with your drive.
Step6 Locate and connect the required power and IDE cables to the back of the drive. These cables are keyed, meaning they are shaped specifically for that drive. It's impossible to install the wrong cables.
Step7 Put the side panels back on and plug your computer back in. Turn it on and your computer should recognize the new drives. If they are not recognized you may need to install the drivers, which are usually included on a CD that's included with your new drive.
I hope that helps. If you have any more questions, let me know.
Jan 10, 2009 | E-Machines emachines (emachinees) CD-ROM...
Computers & Internet Logo
135 people viewed this question
David Payne
David Payne
