Question about Acer Ferrari Computers & Internet
Power surge, nothing working - Ferrari Acer Computers & Internet
  • Acer Master
  • 32,281 Answers
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Posted on Jan 10, 2013
Check for power at surge protect strip, some have a reset, some are just done after to large a surge. If that has power, check with voltmeter to see if your plug into the computer has voltage, generally they say what the output is on the inverter (black thing between plug in and computer) if both of those are good....its internal on the Acer laptop...and above my paygrade
I had a power surge in my house and my EMERSON 900W MICROWAVE OVEN MW8999RD control pad is not working. The lightbulb works and the tray spins slowly when I open the microwave door. However, nothing
I hope it's still under warranty. Think about getting a replacement, and about next time: Get a surge protection device between the oven and the wall plug! I have suffered from power surges in my house as well, and a surge protector is the only cure.
Dec 07, 2014 | Emerson Microwave Ovens
Had a power surge to tv. Have replaced power supply board, power cord, and inverter board. Still won't work. What to try next?
Is there nothing in the system that acts as a fuse? Get yourself a surge protector for next time
Sep 30, 2014 | Televison & Video
I had a power surge my TV, DVD player and my Direct TV box were all hooked to the power surge strip. After the power surge only my TV would not work. I have tried the 30 sec power off but still nothing
Hello, Some UPS have surge protection and come with guarantee insurance for up to a million dollars. Use one of these and if it happens again you have someone to file a claim with.
Oct 16, 2013 | Sanyo Televison & Video
Bose remote will not work after power surge
the power surge . Nothing had to do with the power surge. Maybe you must check the C.breaker or reset button from the device, TV, Dvd, OR Whatever . and try again.
Reset the code from remote control, replace the batteries, clean the batteries contacts. retight the springs contact batteries for better contact and try again. download the code www.remotecodelist.com and instruc.manual from www. fitness.manualsonline.com
God bless you
Sep 02, 2012 | Bose Televison & Video
Wii wont turn on, nothing had a lightning storm last night and now nothing
Try replacing the power cable, many times when there is a power surge and you do not have a surge protector it will burn out the transformer on the power cord. If you replace it and still nothing, most likely your Wii has been burned out by a power surge.
Feb 28, 2011 | Nintendo Wii Console
I have a cuisenart dcc 2200 coffee maker. We had a power surge.
mcdevito75, Unit coild be burned out from power surge, Test at a known good electric outlet. If burned out replace your coffee maker.
Jun 22, 2010 | Cuisinart Brew Central® DCC-2200
Olevia 37" no picture
check the TV power cord first., try to plug any other appliances on the same surge protector or outlet, like electric fan, electric iron., see if's work., if it does, probably the power supply of your TV is in trouble.
May 09, 2010 | Olevia LT37HV 37 in. HD-Ready LCD...
Last night I turned-off my PC througg Windows and when I pushed the power button this morning nothing hapened. There is no sign of "life" from the PC.
Check the power source to the computer (both ends of the cord), if a surge protector is in line with the power , remove it and plug the computer straight into the wall. also check the wall plug with a lamp or something to ensure power there. make sure the switch on the power supply hasnt been changed to the 220v side.
If no power at the wall- check your breaker box in the house
If it works plugged straight into the wall- check the surge protector
If power at the wall and plugged straight into the computer (no surge protector) and nothing lights up when you turn it on- have your power supply checked.
Oct 08, 2008 | Acer Computers & Internet
Possible power surge?
Sounds like you got a surge which damaged the control panel. This is the most likely thing. We regularly repair these control panels nationwide for $32.50. A fuse is designed protect against excessive current. But if you have excessive voltage (a surge or spike), it can be so fast that it gets past the fuse and damages the control panel without actually blowing it. While the panel does have surge protection to keep that surge from actually destroying the control panel, the panel is damaged and will have to be repaired. If any power line connections were broken or are suspect, I hope you have contacted the power company. Either way, I would test any affected outlets to be sure the neutral and ground are present so the voltage output is within the proper range.
Nov 16, 2006 | Samsung MW5351G Microwave Oven
Computers & Internet Logo
77 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
