Question about AOpen AX4B Pro-533 (91.88M10.102) Motherboard
Unable to access files on SONY memory stick
I have a SONY USB memory stick (2 G) that initially worked fine on any laptop Sony, HP, Acer) but seemed to automotically change to a different drive letter depending on which computer I was using. However, now when I plug it in it is visible on 'my computer' as a removable disk, but when i try to open it I get the message 'please insert disk into drive F.' This occurs regardless of which drive letter I assign or the computer I use. I have also tried to right click on the disk drive to use the 'search' and 'explore' options but no luck. The memory stick itself does not have any buttons on it that i can push to reset or unlock. Any suggestions?
    President:
  • 1,314 Answers
Hello. Windows will automatically give it the next drive letter available whenever you install it on a computer. That being said, it sounds like the stick itself is bad. It won't work on any computer so that rules out a computer issue. Since you cannot access it once it recognizes the drive, the media has become corrupted or gone bad. Try right clicking on the drive and formatting it but if that doesn't work, I'm afraid its toast.
Posted on Jul 02, 2007
How do i get pictures off my sony memory stick pro duo with adapter on to my hp laptop
You will need to purchase an adapter that will fit the SD card slot or USB connector. When connected, use the computer to open the files from your memory card and save them on your computer.
These adapters are available from big box stores and online from eBay and Amazon.
May 27, 2015 | SanDisk Electronics - Others
Tip
Sony Memory Card File Rescue Service If your Sony Memory Stick has stopped...
If your Sony Memory Stick has stopped working in your digital device,
use Sony's Memory Card File Rescue software to recover your data.
Compatible operating systems include:
* Windows® 7 Starter / Home Basic / Home Premium / Professional / Enterprise / Ultimate
* Windows Vista® Home Basic / Home Premium / Business / Ultimate
* Windows® XP Home Edition / Professional
* Windows® 2000 Professional
Download Sony Memory Card File Rescue Here.
I hope that helps.
____________________________
Download Sony Memory Stick Formatter here.
on Apr 18, 2010 | Sony 1GB Memory Stick PRO Duo Memory Card
Ok so my sony viao vgn nr120e caught a virus. I finally ordered the recovery cds but my cd drive no longer works. I really do not want to replace the cd drive. Is there anyway to bypass the recovery cds...
Buy a 4GB (or larger) USB memory-stick.
Connect it to a different computer.
Copy all the files from the recovery-CDs onto the USB memory-stick.
Move the memory-stick to your computer, and try to install from the files on the USB memory-stick.
Oct 23, 2010 | Sony VAIO VGN-N320E Notebook
Problems with my Sony Cybershot W210
1) Make sure that you're not using more than 4 GB memory stick pro duo with the camera. Then try to remove the memory stick and capture 2 images in the internal memory and turn OFF and turn ON the Camera and check. If the error message comes, its the issue with the Camera itself and requires service after resetting. to reset the Camera, select Initialize under Main Settings 1 menu under Settings. if the issue persists, the camera may require service
If its working fine, transfer all the images to the Computer and format the memory stick. Formatting will delete all the contents. If the issue persists, memory stick should be replaced.
Sep 21, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
Wont access memory card
i) try to put memory card in any mobile if it working in it is fine, if not your memory is having some password put on it or attached, try to remove the password and then work with it ........
you can remove password by keeping the memory card only in that mobile where you kept the password(only in that mobile through which u kept the password...)
Dec 28, 2008 | Sony 1GB Memory Stick PRO Duo Memory Card
I am unable to upload my pictures from the memory stick.
I sugest a usb card reader. they are much easier to use and don't involve the camera in downloading.
Dec 20, 2008 | Sony Cyber-Shot DSC-S85 Digital Camera
I have hp photosmart 1315 printer but the lead i have got does not attach to the laptop, any suggestions? also when i plug my sony memory card into the side it says card access error so i cant even print...
I assume you mean that the connectors of the cable you are using aren't fitting either into the the laptop. I went to HP.com and looked up the printer's specifications. It seems like a USB 1.1 (but not a USB 2.0) cable should work. Here's the reference:
Product Specifications
Since you say the cable doesn't attach to your laptop, make sure the USB connector is correct side up before trying to insert it (I apologize if this seems too obvious, but I've spent plenty of time wondering why a USB cable wouldn't fit into this port or that only to realize that I was holding the connector upside down).
As far as the memory card error, there are a number of different causes, mostly based on the card manufacturer. You say it's a Sony card, so that narrows it down some. I found a web page that addresses general memory card error issues:
Resolving a Card Access Error
I'm going to post links to the several other web pages I found that are related to card access errors, just to make sure you have as much information as I can provide:
Card Access Error when using Lexar CompactFlash
Compact Flash Card Not Recognized by Printer
Card Not Recognized Error Displays on Control Panel
Memory Stick Memory Card Error
Most of these don't have to do with your Sony card, but it couldn't hurt to go over them if the suggestions in the initial link don't work out. Sorry to bombard you with so much information, but you never know what piece of data might hold the key to resolving this issue.
Good luck and post back your results.
Oct 15, 2008 | Office Equipment & Supplies
Can't access pictures taken
If you can't access the memory card even with a card reader...your camera is working fine...the problem is ith your memory card (internal problem)...if your warranty is not finished sony will replace that to a new one
PLEASE RATE ME ( FIXYA )................................
May 26, 2008 | Sony 2GB Memory Stick PRO Duo Memory Card
Problem accessing memory stick
I had the same problem. I bought a 2 gig memory pro-duo with the adapter and it gave me that error even though it fit just fine. I then tried a 512 memory stick and a 1 gig memory stick and neither one worked it gave me the C:13:01 error code. So I found out the hard way that the camera will not read it. The Sony DSC-S85 will not take memory above a 128. Try the Lexar 64MB memory stick. I just bought 4 and they work perfectly fine.
Nov 02, 2007 | Sony Cyber-Shot DSC-S85 Digital Camera
AOpen AX4B Pro-533 (91.88M10.102) Motherboard Logo
50 people viewed this question
Top AOpen Computers & Internet Experts
Alun Cox
Jim Goldsmith
Jim Goldsmith
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
