Question about Dell Dimension 2400 PC Desktop
Would like a diagram on how to hook up extra speakers to my dell 2400 and just how many can be added to system
My system works good now but I just want more speakers to run throughout my house. Thanks
  • Dell Master
  • 998 Answers
If your current speakers are plugged in to the back of the computer, then there is no way to install additional speakers unless you purchase and install a sound card.
Posted on May 03, 2014
4 Suggested Answers
ghouliass
  • 105 Answers
SOURCE: trying to get wifi for Dell Dimension 2400
Less expensive for recieving is simply the "usb stick" I would recommand a "ralink" chipset, (can be found in USROBOTICS and some less expensive brand like TOPLINK
Posted on Nov 26, 2008
  • 159 Answers
SOURCE: i have a dell 2400 that won't play cds anymore it
Please download and install advance Power DVD or VLC player software and try to play the CD.
Posted on Aug 05, 2010
ZorWiz
  • 120 Answers
SOURCE: Can I hook up my dell dimension 2400 to my laptop
Well you can connect the two computers on a LAN (local area network) and copy files from one to the other. This may or may not be what you really want to do.
If you have a LAN available just connect both machines to it. Then you have to set "File Sharing" on the computer you want to copy to.
Open up Windows Explorer on the machine you want to copy to and find the folder you want to copy your files to. Right click on the folder and select Properties then select the Sharing tab.
Follow the instructions in the second section.
After that is done you can go to the computer you want to copy form and from Windows Explorer in left hand pane, "Folders" scroll down to "My Network Places" -> "Microsoft Windows Network" -> "Workgroup" -> "MSHOME" and find the computer you want to copy to in the list.
Find the folder you want to copy to on that computer and then copy your files in to that folder.
If you don't have a LAN you can use a special LAN cable called a NULL cable to do this. Connect the two machines with the NULL cable and the run the "Network Setup Wizard" from "Control Panel". Select "This computer connects to the Internet through a residential gateway or through another computer on my network". Then follow the setup dialog from there.
Hope this helps.
Posted on Jul 23, 2011
I have a dell 2400 desktop computer. I recently got FIOS and they hooked my wife's computer to their router with an ethernet cable. Can I also hook my dell up the same way?
Depends on the hardware. Is it a router or modem? Does is have extra ports in the back,
Router with extra ports, just connect new device with wire or even wireless if it has wireless.
Modem, most likey you have to buy a router.
Dec 28, 2012 | Dell Dimension 2400 PC Desktop
Why no sound from my speakers with Dell Dimension 2400, even though it's equipped for sound? Speakers worked fine plugged into Compaq.
Please try other speakers to make sure that it is in fact the computer and not the speaker port itself. If other speakers work, then it is most likely a driver problem. Try to find the drivers for your speakers and install them, restart, and reconnect your speakers. Good luck!
Dec 22, 2010 | Dell Dimension 2400 PC Desktop
I have a dell 2400 that won't play cds anymore it runs and makes noise and the speakers are working good
Aug 05, 2010 | Dell Dimension 2400 PC Desktop
No audio from external speakers dell 2400 computer
hi,
1)Check audio Enabled in bios
2)Check whether audio drivers are installed in device manager if not install audio driver for DIMENSION 2400 from Support.dell.com
3)Check Audio port using Head phones to ensure is audio port is working fine.
4)If Dell speakers, check speakers Manuals from support.dell.com
Dec 04, 2009 | Dell Dimension 2400 PC Desktop
How to hook up 2 kicker 10" speakers & kicker amp to a 2002taurus
Good day ma'am, hi, hooking up an extra amp. on your radio is done by audio professionals, but if you can remove the radio out from your ford, you can install that extra amp. Just follow the diagram below.63bff30.gif You need to find line out of your radio to line in of your kicker amp. connect them using audio shielded cables. connect your speakers to the amp. I guess you this already.
Nov 23, 2009 | Kicker KX600.1 Car Audio Amplifier
Speakers stopped working
you should format and reload that system
Feb 16, 2009 | Dell Dimension 2400 PC Desktop
Video out on dimension 2400
all of those are controlled by the video card-software management panel..go to dell support website, and make certain you have that latest driver set..then you should be able to enable any of those options.
Oct 09, 2008 | Dell Dimension 2400 PC Desktop
Sound Problems
To make it easy for you this is the default audio driver for Dimension 2400 systems. Click on this link ---> http://support.dell.com/support/topics/global.aspx/support/downloads/en/downloads_splash?c=us&l=en&s=gen&~mode=popup&file=122481
this would install your integrated audio driver for your system.
Let me know if this resolved this issue.
Sep 21, 2008 | Dell Dimension 2400 PC Desktop
A friend hooked extra speakers to my system and now the speakers have no sound what have he done/
He probably overloaded the system...it is rated for a specific resistance and adding extra speakers can ruin the speakers or the system or simply not play. I recommend researching the rating or simply disconnecting the extra speakers.
Jul 21, 2008 | JVC AM FM CD DET FACE CAR STEREO
Dell Dimension 2400 PC Desktop Logo
Alun Cox
