Question about Bosch Ovens
What is a F112 error code on Bosch double wall ovens?
dutchman05
  • 487 Answers
SOURCE: timer clock on bosch double oven
Please follow this link and download the instructions.
Manual
Please rate me as FIXYA
Posted on Apr 29, 2008
jumptrout51
  • 3361 Answers
SOURCE: Double GE wall oven - F7 code
You either have a stuck touch pad button or a bad clock.
Push all buttons several times to try and clear.
If not successful repair is a new clock.
Posted on Feb 22, 2009
  • 234 Answers
from repairclinic.com:
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
It looks like you have a function button pad stuck or a bad clock.
Unstick button or replace electronic range control.
Posted on Apr 27, 2009
rajak2009
  • 527 Answers
SOURCE: F10 Error code on double oven.
Sir,
Check out this link
suggest to reset it by shutting off both main breakers to the stove , wait for one minute and switch breakers on again.
Thanks Good Luck
Appreciate to rate as "Fixya"
Posted on May 15, 2009
SOURCE: kebc207 oven error code E1 F2
This is information from the Tech Sheet.
Fault Code F2 - Error Code E1: Code Explanation: Keypad keytail not connected. Recommended Repair Procedure: 1. Check keypad connector for firm connection. 2. Press CANCEL. If error code returns after 60 seconds, replace keypad. 3. Replace control.
Posted on Sep 25, 2010
A F04 Err is flashing on my Bosch double oven. Please can you tell me what this means?
The only F04 error on a Bosch oven is with the Bosch 5000 Series wall oven. On this model, the problem is with the door latch. Unplug (or turn off at the circuit breaker) the oven. Turn it back on after a few seconds. When the power comes on, the oven should do a self-test of the lock mechanism. If the error persists, you'll need to do some diagnostics to determine if the lock is faulty. The problem could also be with the wiring or the control board didn't register the correct signal from the lock sensor.
Please add a comment with the model number of the wall oven for more assistance and any possible parts lists. You may want to call for service if you aren't comfortable doing this work. You probably need to get the oven out of the wall cavity for some of the diagnostics.
I hope this helps.
Feb 24, 2017 | Bosch Ovens
Flashing PF 32 error code
Hello - This manufacturer does not show to have such an error code for a wall oven. However the error codes F30/F31 indicates that the unit either has an issue with the oven sensor, wiring with the EOC or the probe connections is open or shorted. Contact a professional to move forward accurately.
Nov 10, 2012 | Frigidaire 30 in. Electric Gallery Series...
Double wall oven F0 error code
The F0 error code means that the control board has detected a defect within the control board itself, the F0 code can be cleared by pushing the CANCEL/OFF button and if it goes away and returns all is well,however if a short time later the F0 returns the control board would need to be replaced.
GENE
Oct 04, 2011 | GE Profile 30" Built-In Double Electric...
I need to download a manual for this product. Where can i find it?
I found a users manual for Bosch wall ovens at Retrevo.com
http://www.retrevo.com/s/Bosch-HBL755AUC-Ovens-review-manual/id/925ci470/t/1-2/
Feb 12, 2011 | Bosch HBL 755 Stainless Steel Electric...
Bosch oven function error e124
Can you provide a model number for your oven. Is it a single oven or double ? Wall oven or free standing range ?(conventional with cooking surface)
Unfortunately the error codes for Bosch are different depending on the model of the unit.
Thank you, I`ll look for your reply.
macmarkus :)
Jan 09, 2010 | Bosch Ovens
F4 error message
HI. This is a failed oven temperature sensor error code. Simply replace the temp sensor, asap. This will clear the code. The temp sensors are generally located inside the oven, mounted on the back wall, in the top left or right corner.
It will look like a 4 inch slim probe.
F4 failed temp sensor.
Dec 29, 2009 | Jenn-Air JJW8230D Electric Double Oven
Sir,
Check out this link
Thanks Good Luck
May 15, 2009 | Frigidaire 30 in. Electric Gallery Series...
Ovens Logo
188 people viewed this question
Top Bosch Ovens Experts
ashburton
paulcarew
Are you a Bosch Oven Expert? Answer questions, earn points and help others
