Question about Refrigerators
Gss23qsta SS refrigerator GE the freezer has warmed up to 28 degrees. Help?
2 Suggested Answers
fixyourboard
  • 310 Answers
SOURCE: Ge Artica Refrigerator PSC23PSTA ss not cooling or
Typical problems that can cause this:
- iced up evaporator due to defrost problem
- failed thermistor (temperature sensor)
- compressor not running
all of the above could be due to a failure in the main control board
there is a diagnostic mode that can help you diagnose cause
Posted on Jun 22, 2010
Model ZFSB26DNA SS Side by side / refrigerator and freezoe not able to get cool enough. Refrigerator side temp 49 freezer temp 7
refrigerators run from 5 to 10 degrees C so your machine is on the upper limit of 9 degrees c
the freezer is at minus 13 degrees c and most work down to minus 20 degrees c so that is in limits
Get a technician in to check the thermostats and in the mean time check the condition of the door seals as they will loose the cold very easily is cracked or not sealing properly
Nov 04, 2015 | GE Refrigerators
GE Profile Arctica top freezer: freezer and fridge have been too warm all day. The freezer is 40 degrees and fridge is 46 degrees. Adjusting the temp does not help. Please help
Hi,.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then checkout the last two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 26, 2010 | GE Profile Arctica Stainless Steel Top...
I have a GE refrigerator model number PSC25SG SA SS which has Problem that in every couple days the freezer and the refrigerator display panels display out of their setting ranges. For example, the...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Aug 24, 2010 | GE PSC25SGSSS Stainless Steel Side by Side...
Freezer is freezes it self up and a giant block of ice froms but refrigerator is warm
Hi: your model number dosn't get a match on a search. Did you check the defrost heater? I hope this helps Jeff,
Jun 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Not keeping cold temperature and can smell plastic from heat
Sounds like the condenser fan motor is either jammed or has failed. if you wil pull the refrig from the wall and remove the lower compartment cover you will see the fan I'm reffering to as well as the condenser coil and compressor. if the fan has failed you can put a house fan blowing into this compartment to keep the unit operational until you can get it repaired. thanks for using FixYa Peyton
Feb 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Power is on but nothing is working, not cold ,no water, no ice
Sounds like the unit needs a reset of sorts, Get your food into another refrigerator or ice chests and unplug the unit. let it stand open for several hours (just in case the vents are iced) and then plug it back in.
Jan 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Refrigerator Problem
you have a leak in the freon line
Aug 16, 2008 | GE Refrigerators
Refrigerators Logo
37 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
