Question about HTC G1
My G1 can't power on :<
I have had my G1 yesterday. When I charged it by usb today, it powered off suddenly. It can't be power on by pressing the End Call button. The battery can be used with my good friend's G1.
  • reyara Jan 21, 2009
    I have a new problem with my HTC G1 --- it won't SWITCH ON! I was just surfing the Net using the
    WIFI, and it was working fine. After surfing, I switched off the
    screen and put the phone on standby mode. After a while, I noticed the
    green blinking light which usually meant that a text message has just
    arrived, so I tried to activate the phone but the screen remained dark. It stayed this way, with a dead screen and the green light
    continuing to blink, and wouldn't turn on/off no matter what button I
    pressed. Finally, I decided to remove the battery to force it to
    switch off. I then tried to recharge the battery, but still no
    response from the phone so it's not a battery problem. Any advice please, anyone? Thanks.
  • 97 Answers
Sounds like the red buttons have stopped working. you can attempt to reset the phone, if that fails either the button will need to be replaced, or you can contact T-mobile for a replacement given it is still under warrenty.
to reset the phone, try this:
with it OFF press the HOUSE and the POWER buttons until the phone powers up with a triangle and a yellow '!'inside. slide open the screen and press 'ALT' and 'W' at the same time. the phone should boot up as normal. if that fails, call t-mobile 1800-937-8997 for a replacement.
Posted on Jan 28, 2009
My Axiom 49 won't turn on or light up. It was just working yesterday. How do I get it working again?
The cable could be bad. Try another cable. USB port problems are also common with M-Audio.
If that doesn't work, try using a 12v adapter to power it on.
Just make sure you don't use both USB and the power adapter at the same time, or you can fry the board.
If it powers on with the adapter then it's an USB issue. If it doesn't, then it's something else.
Apr 09, 2015 | M-Audio Axiom 49 49-Key Semi-Weighted USB...
I have a g1 and it downgraded to 1.0 how can I upgrade it without a manual update
How to Update G1 Phone Firmware RC33
1. Download RC33 update from Google here.
2. Rename the download file from to, and place it at the root i.e the very top directory of your Micro SD card. (If you added the file to your microSD card by connecting the handset to your computer via USB [rather than using a dedicated microSD card reader], make sure to unmount it and disconnect the USB cable now.
3. Turn off your G1 Make sure it's completely powered off. Now again turn it on by holding the Home+End keys until you see T-Mobile G1 logo.
4. From the icon screen, open the keyboard and hit Alt+L.
5. Press Alt+S to begin the update. Remember, the update needs to be in the root of the Micro SD card and needs to be named
6. Once it finishes, follow the onscreen instructions and press Home+Back to finish.
7. G1 Phone will reboot a few times to flash different parts of the firmware.
If all went well, you should now be running the latest update, RC33. Enjoy your new, shiny RC33 update, complete with Google Latitude!
To make sure all your hard work wasn't for nothing, hit Menu > Settings > About Phone > scroll to Build Number. You should see RC33 in there somewhere.
Mar 23, 2011 | HTC G1
I drained my battery and Just finished charging, i press the power and it starts up but the it only shows Android and never realy turns on.
Princess I experienced a similar problem because I was using the ahome app you should do a hard reset on your phone
  1. Power off the G1
  2. Hold Home Key + End key for 20 seconds or until you see a "triangle with an exclamation point and a picture of the G1"
  3. Open the QWERTY keyboard and hit Alt+W
  4. Restored!
Sep 27, 2009 | HTC G1 Smartphone
My g1 phone wont let me put pics on my computer suddenly
My next step would be to try a different USB cord.
Next thing to try is pop the sd card out of the phone and then back in.
If that does not work power cycle the phone.
After that your guess is a good as mine.
Jun 21, 2009 | HTC G1
HTC g1 can not power on after dropped down
If cleaning and checking the battery terminals doesn't work, you may have a broken motherboard. The T-Mobile G1 logic board is nottoo hard to replace. A good source for the part would be ebay. Thereis a step by step guide too that explains how to replace the board : T-Mobile G1 repair. There are also third party T-Mobile repair companies that do it for you.
Jun 05, 2009 | HTC G1 Smartphone
Yesterday I talked to one of your technician I wanted to know how to download MP3.He came into my computer and show me how to work it every thing for that specific problem was solve Today I installed the...
Please make sure the camera is charged. Also try a different usb port in the computer. Usually in this instance the camera has to be fully charged or plugged into another power source. Depending if the camera can draw power from the usb or not.
Jan 02, 2009 | Jazz DV-179 Digital Camera
G1 Android T-mobile battery dying ???
hey, buy another battery, bye
Dec 27, 2008 | HTC G1
G1 touch screen not working
my workaround is to charge with a different power source, or stop charging. i think it's the power source. for me, the touchscreen goes crazy when i'm charging via usb with this old computer, but it's fine when i stop charging. it's probably an unclean power source messing with the capacitance sensor.
Nov 10, 2008 | HTC G1
G1 Phone Wont Charge
take the batteries out and put it back in again and try charging check in diff power sockets press the end of the charging cables with little amount of pressure and have a check try to connect via the usb cable to the computer and check if it charges, if works the charger is faulty if still did not work then it will be firmware problem with of phone
Nov 03, 2008 | HTC G1
HTC G1 Logo
823 people viewed this question
Top HTC Computers & Internet Experts
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
