Question about Fuji FinePix S2000hd Digital Camera
Not opening I was taking a picture when a spark suddenly appeared near the flash and now it won't open..The batteries are in good condition though.
    Sergeant:
  • 321 Answers
Your plastic part near flash got puffed due to burn spark, serv. req
Posted on Jan 10, 2013
The film comes out all blank when I take a picture on my Fujifilm instax 210. What do I do?
try take 10 shot without any films insert to the camera.
If there is flash mean camera is working in goods condition.
It will appear black because someone had open the film cover before, therefore , it detect it's a new film box, and eject the first film cover.
film will appear black.
Sep 23, 2013 | FUJIFILM Instax 210 Film Camera
Cannot unlock doors and reset alarm
Go on youtube and put in how to reset your car key after renewing key fob battery good luck colin
Jun 30, 2017 | 2005 Mercedes-Benz Mercedes Benz E320 Cdi
Yamaha jog r 50cc won't start first thing in the.morning put new choke on still no good
Hi, Anonymous and the usual suspects are:
1. Spark plugs in bad condition or have an improper gap or are partially fouled.
2. Spark plug cables in bad condition.
3. Battery damaged or nearly discharged, should have 12.5 volts.
4. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
5. Throttle controls not adjusted correctly.
6. Water or dirt in the fuel system.
7. Water or dirt in the carburetor.
8. Faulty fuel pump.
9. Intake air leak.
10. Fuel tank vent hose and vapor valve plugged, or fuel line closed off, restricting fuel flow.
11. Enricher valve inoperative.
12. Engine lubricant to heavy (winter operation).
13. Ignition is not functioning properly (possible sensor failure).
14. Faulty ignition coil.
15. Valves sticking.
For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
1995 yamaha jog wont start plz help
Yamaha Zuma won start
https://scootergrisen.dk/scooterhjemmeside/download/yamaha_jog_servicemanual.pdf
OEM parts for Yamaha
YAMAHA JOGR JOGRR CS50 Owner Manual
Mar 16, 2013 | 2006 Yamaha Jog R
1976 super glide only one spark - won't start
Hi Emile, and the usual suspects are:
1. Plugs in bad condition or partially fouled.
2. Spark plug cables in bad condition or leaking.
3. Spark plug gap to close or to wide.
4. Faulty ignition coil, module and or sensor.
5. Battery nearly discarged.
6. Damaged wire or loose connections at battery terminals especially the ground cable at "BOTH" ends, ignition coil, or plug between ignition sensor and module.
7. Intermittent short circuit due to damaged wire insulation.
8. If your bike has a CKP sensor you must leave both plugs in
head and check for spark with a 3rd plug. Good luck and have nice day.
Sep 07, 2012 | Harley Davidson Motorcycles
CameraWindow won't open or will suddenly close before loading
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Jun 03, 2012 | Canon PowerShot S90 Digital Camera
How do i transfer pictures from usb memory stick to computer
hello sir,
Open the folder where you have the pictures.
Insert the Flash drive.
Open the flash drive (using 'Computer' from the Start button).
Drag the pictures you want onto the flash drive window.
If it won't copy check the write protect switch on the flash drive (if it has one)
Godbless!!
Aug 11, 2011 | Computers & Internet
Nikon coolpix S3000 won't take a picture when the
Assuming you have new batteries and the camera lens cover is opening when turned on. Try switching to any mode other than automatic, turn off the flash, and press the shutter button. Many cameras have a safety feature that prevents the flash capacitor from charging if the case is opened. This is to lessen the chance of electric shock. They usually use one or two of the screws along the perimeter of the camera to complete a circuit that lets the processor know that the case is closed. Verify that all the screws are in place along the perimeter of your camera, and that there are no gaps along the perimeter seams. If you're missing a screw, try using one of the others to replace it.
If they're all there, next thing to check is the batteries. The brand that you're using may have reached its shelf life, or just may not have sufficient power to charge the flash capacitor. Try a better brand, or better yet rechargeable NiMH batteries.
If the above didn't help, then the flash tube or its circuit is probably at fault. In this case, would then recommend professional repair. This repair is somewhat difficult, requires some soldering, has some danger of electrical shock, and goes beyond what I'd like to describe here
Jun 13, 2011 | Nikon Coolpix S3000 Digital Camera
My camera works fine in all ways except whenever i turn the 'flash' on and try to take picture the green light just flashes repeatedly and it won't take a picture at all, but if i turn the...
Referring user guide:
Are you press ligthly? if press half and ligthly, it will not take the picture.
When you have using macro mode, you need to disable Flash mode.macro mode will show picture(flower) and avoid hand shake during this mode.
When you take in 10cm range in macro mode, it will take more longer time to autofoucus, you need to be freeze a while until it take the picture. The best it, try to take picture in without you inhale. it will avoid you from shage
Try using in different DIS mode when you using the flash.
In some mode, it will have twice flash. First flash it will check the condition and wait until second flash and dont move your camera.
Some condition, you will get the picture is white, it because from dust atmhospheric that we cant see. it reflective to ur flash.for the best picture, you need to try in different mode and different condition. that will make you as proffesional. this camera have many mode that you need to understand. training urself to be perfect. download manual and test your camera
May 12, 2011 | Samsung S860 Digital Camera
Fuji FinePix S2000hd Digital Camera Logo
21 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
