Question about HP Compaq nx6310 Notebook
Laptop screen dont like keyboard slot ram
Sorry re posting problem because i created new account.
new ram wont work in keboard slot, but old ram does in it.. the ram fits in, comp runs, but nothign shows up on the screen, what is happening. the 2gb in the other slot (back of laptop) works. and its not the ram not working, cause i switched it with the slot working (with the 2gb ram) :S helps.. and fsb. im not too sure what that means..
  • billz1508 Jan 22, 2009
    thanks for trying but still got no clue why, nothing visual will display when i have bigger ram in the underkeyboard slot.
  • billz1508 Jan 23, 2009
    anyone please? i really need ths 4gb ram in. only got 2gb atm, and i wanna upgrade to vista
  • HP Master
  • 32,281 Answers
The NX6310 laptop supports up to 4 Gb of RAM either 533 or 667 MHz DDR SDRAM.
When memory upgrades don't work, the problem could be incapable memory between RAM modules.
Try to use RAM from the same manufacturer, especially the manufacturer of the working RAM.
Use RAM that have the same speed specification.
Posted on Jul 20, 2009
My msn u180 notebook seems to have locked the keboard. it wont type, though lets me add external usb keboard and works
You might need to replace the keyboard. It should be a fairly inexpensive fix for a computer shop.
Jun 25, 2012 | Computers & Internet
Bought 1G ram from local computer store. It runs for about 5 minutes then i get a blue screen error and reboot. returned to store for a different mem stick...same issue. went to Crucial, found the...
Did you remove the "old" RAM, or did you add the "new" RAM to the old RAM?
Try using your computer with ONLY the "new" RAM installed.
Try using your computer with ONLY the "old" RAM installed.
Try using your computer with the "new" RAM in the 1st slot, and the "old" RAM in the 2nd slot.
Try using your computer with the "old" RAM in the 1st slot, and the "new" RAM in the 2nd slot.
Aug 27, 2010 | HP Pavilion ZV5220US (PF143UA) PC Notebook
I have a Compaq notebook and the keyboard is not working under the administrator. It works fine under any other user. I've tried to update and uninstall drivers with no success. Also I cannot hit...
if the keyboard is working in any other user account . The user account has gone corrupt. You can recreate a new admin account. But before you do that back up all the my documents folder.
1. Restart the computer and press the F8 key a couple of times before windows starts
2. Select safe mode and press enter
3. Select the admin account and log in
4. Click on Yes to continue to work in safe mode
create new account in windows Xp
Create a new account using windows vista
Once the new account is created you and delete the old admin account
Feb 06, 2010 | Compaq Presario Notebook
Hp laptop wont display on screen but the power led
The beep pattern tells you what the problem is. You can lookup the code yourself, or post an update here.
Sep 03, 2009 | HP Compaq Presario V6000T Notebook
New ram installed, but computer screen doesnt work
if your laptop working fine before install ram so that there should be problem with your ram only
check both rams are in same fsb there is no mater of capacity of ram (ie:512mb or 1gb)
like pc-2100
or 667
both rams are intall in same fsb on both slots.
Jan 21, 2009 | HP Compaq nx6310 Notebook
Ram not working with motherboard
Check if your motherboard only supports only dual channel interleaved memory from the manual because it might be the main issue of your problem. Also DO NOT plug in the 512 MB ram you have over there. If it is ok to have one Slot empty then there should be no reason why it should not POST properly. Before jumping to conclusions that the RAM is faulty. Make sure that you REMOVE any overclocking you might have on the system. Some RAM won't post wihen the CPU clock and multiplier are not standard. Also it could help if you load FAIL SAFE settings in the BIOS until you determine the proper cause of the problem.
Hope that this helps :) (please rate thanks)
Jan 07, 2009 | Intel D865GBF Motherboard
Help to start please
It's possible the power cord is defective only giving enough power for a partial boot. I would try another power cord.
If it's not the powercord then it would definitely be the motherboard not taking the power and distributing it correctly and you would have to replace it.
Sep 06, 2008 | Compaq Presario Notebook
Installing RAM to Maxdata ECO 3100x
The ram is sited under the keyboard, to remove undo case screws on underneath of laptop. Then, where the keyboard bottom edge meets the laptop case yo will find 3 lugs... which can be pushed in. Lift off keyboard, then undo access panel on right side of laptop. There you will see the 2 memory slots.
Aug 24, 2008 | Computers & Internet
Acer Travelmate 270 Memory Upgrade
Acer TravelMate 270 upgrades:
The official upgrade slot is located on the bottom of the laptop and is easy to find. Just unscrew the small cover and there it is.
The other slot requires you to unscrew the two screen bracket screws. Once you have done this, between ESC and F1, F4 and F5 and F12 and PrtSc there are small plastic rings. Put a biro nib into these and pull down. They will pop down. You can now remove the plastic cover.
Unscrew the two screws marked "L9" on the bottom of the laptop which are located at the top of the memory cover. Now you can remove the keyboard. Underneath the keyboard is the second RAM slot. The SiS 650 chipset supports a max of 1GB per memory slot and since this laptop has two slots that means 2GB of RAM. I've used Kingston DDR400 PC 3200 SODIMMS.
You can also upgrade the CPU - the fastest CPU available is the Pentium-M 2.6GHz. Nothing faster will work - trust me on this. It must be a Pentium 4 Northwood architecture CPU with a 400MHz FSB. Standard P4 Northwood CPUs with the metal shim won't fit - unless you know a way of removing the shim without destroying the CPU. Best to stick with a Pentium mobile (Pentium 4 M) chip. Look on Ebay for these.
Of course the hard disk can also be upgraded - a 200GB 7200RPM 2.5" drive works a treat. Non SATA of course.
You can add wireless and USB 2.0 using PCMCIA carbus cards. I use a StarTech 54mbps wireless card with the RAlink chipset and a NEC USB 2.0 card with 4 USB ports. Both cards fit in at the same time.
The laptop absolutely flies with these upgrades.
Mar 22, 2008 | Acer TravelMate 2702WLMi Notebook
HP Compaq nx6310 Notebook Logo
198 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
