Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Will a genie keypad work with a chamberlin lift master
Door Tech
  • 98 Answers
SOURCE: 2 different openers stopped working by remote at the same time
Both the older genie and a newer chamberlain (3-4 yrs old) both run on 390Mhz frequency. sounds like you will have to change your receivers on both operators (365LM 315Mhz) then get 3 button remote so you can program both doors on one remote.
Posted on Jan 04, 2009
SOURCE: My Lift Master (Chamberlin) does
how do i reset the time?
Posted on Jan 22, 2009
  • 3197 Answers
SOURCE: Lift Master system prior to 1993,
What you need to do is list your model number and someone will help.
Posted on Sep 09, 2009
  • 3197 Answers
SOURCE: Hi
The relay that controls the lights is most likely bad. This is a unfortunately a common problem after electrical storms.
Posted on Sep 28, 2009
  • 3197 Answers
SOURCE: Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+: Can I use a genie wireless keypad on a craftsman o...
No each manufacturer uses a different code that is built into the keypad.
Posted on May 18, 2010
Changing code on keypad
i have a lift master chamberlin garage door opener and need to change the code on my key pad outside, k\my problem is i have no enter button when i put my new code in on my key pad, does anyone know how to help me change my code on my keypad without the enter button....there is a pound and star button
Jan 04, 2014 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener Chamberlain - programming problems
I bought a new keypad and 2 VISOR remote (30498). As to programming garage door opener, I did like here:
- it tooks me 20 minutes and works great
Feb 07, 2013 | Sears Craftsman LiftMaster Chamberlain...
Chamberlin Liftmaster keypad entry does not worek
It will only take a 4 digit program code. After you program the code, and then enter that code to open the door, hit an additional number on the keypad. Some need the additional digit to act like an 'enter' key.
Aug 16, 2017 | liftmaster Chamberlain Garage Door Opener...
Will a genie wireless keypad work a liftmater opener?
No. These components are not compatible between different manufacturers. You can get a universal keypad that will work with the liftmaster opener though.
Good Luck!
Mar 06, 2011 | Genie Company Genie Gwkp Keypad...
I have a clicker model KLIK2U and forgot the code. How do I reprogram without the old code?
It's really easy to reprogram your unit:
Step 1. Hold down the (*) and the (#) keys until the keypad stops flashing.
Step 2. Determine your opener ID using the list below:
*1= linear garage door openers manufactured from 1997 to
present.
*2= Chamberlin, Sears, Craftsman, LiftMaster, Master
Mechanic and Do it garage door openers manufactured from
1997 to 2004 ( Orange learn Button)
*3= Same as *2 above, but manufactured from 2005 to present
with a (Purple learn Button)
*4= Same as *2 above, but manufactured from 1993 to 1996
with a (Green learn Button)
*5= Genie Intellicode and Overhead Door garage door openers
manufactured from 2005 to present (315 MHz).
*6= Same as *5 above but manufactured from 1995 to present
(390 MHz).
*7= Stanley garage door openers manufactured in 1998 to
present.
*9= Wayne Dalton garage door openers manufactured
in 1999 to present.
Openers with learn Buttons
Programming: Enter the PIN that you want to use, remember
(4) digits only. then press #
Enter ID # from list above, for example 2 then #
Press and release the Learn button on your
garage door opener.
Enter your (4) digit PIN and press (0),
for Genie and Overhead door units press
(0) twice. To test and use wait for light to go out
on keypad, Enter you PIN and press (0).
Note: If opener doesn't function repeat programming.
Instructions if required.
Sep 17, 2010 | Universal Garage Wireless Keyless Entry...
Hi I have a chamberlin lift master Professional formula 1 garage door opener and the lights use to time out but now they stay on.
Sep 27, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door opener will close door but will not open it chamberlin model 7200
IF THE DOOR WORKS PROPERLY - MANUALLY
TRY ADJUSTING THE UP SENSITIVITY.
IF IT IS HARD TO LIFT OR CATCHES ON ANYTHING - YOU NEED TO FIX THE DOOR.
HOPE THIS HELPS
Apr 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
Jan 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
16 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
