Question about Ovens
Replacing Andi N463 oven fan element
5 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: Neff B1432 oven element and fan not working
If the element has failed again in such a short time , then I would suspect that the fan is the culprit.
If the fan is not working, then the element overheats, and burns itself out.
The fact that the fan spins freely, proves nothing, as the fan can be still faulty.
The only way to prove if the fan is faulty, is to remove the oven from the housing, and remove the rear outer panel of oven,.test with a meter set to ac mains and test the fan motor terminals to see if there is power there when oven is set to heat, disconnect the element first. ,if there is ,and the fan is not running then the motor is faulty..
If there is no voltage there, then problem is elsewhere, and you will have to investigate furher.
Plz rate my solution.
Thanks.
Posted on Jan 12, 2009
SOURCE: replacing electrolux eob944 fan oven grill element
...If you can help me to remove the grill element from my EOB944, I will be able to tell you the wirings.
Posted on Jul 08, 2009
  • 38 Answers
SOURCE: how to replace a fan bake oven hidden element
Before attempting any repairs, make sure the power is turned off! If you are unsure or not confident, please call a service technician.
The element is behind a cover that is held in place either by screws or clips. Once the cover is removed, the element will be visible. The element will be screwed in place by a number of screws on the base plate and around the element itself. After removing the screws, pull the element fron the rear of the oven. the wires should be attached to the element via lugs. The lugs need to be unattached from the element. Before removing the wiring, take note of the connections so that reinstallation can be carried out.
Posted on Nov 22, 2009
barkencoa
  • 3463 Answers
SOURCE: my zanussi built in oven
It will indeed be a faulty oven element.
It is located at the rear of the oven compartment behind a removeable cover.
Posted on Oct 26, 2010
Heating elements in fan oven not working
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Nov 26, 2011 | Smeg Ovens
Fan oven not heating up
This tutorial will show you how to check your Zanussi element and how to replace your Zanussi cooker element.
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
  • If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Apr 24, 2011 | Zanussi ZDQ495 Electric Double Oven
My zanussi FM9232 fan assisted oven is not heating up, the fan is working
Nov 04, 2010 | Zanussi Ovens
Hi my zbf260w built in fan assisted oven is not getting heat in the oven department.The fan and grill are both fine but not the oven,
If the fan is working o/k, then y ou need to replace the oven element, located at the rear of the oven compartment behind removeable cover.
Sep 26, 2010 | Zanussi Ovens
Beko dvc 62 ,all electrics tripped out ,put cooker
The element has blown. It will cost you around
May 16, 2010 | Ovens
Smeg Oven
Their will be two elements in the oven a bottom element and a fan element, sounds like the latter has blown!
Oct 09, 2009 | Smeg SE250XUK Stainless Steel Electric...
Fan but no heat
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on Facebook please
Mar 14, 2009 | Smeg SE280X Stainless Steel Electric...
Thanks.
Jan 12, 2009 | Neff B1432 Single circotherm plus Electric...
Fan oven on zanussi electric cooker does not heat up
From symptons, I would say the fan oven element is faulty, more so if the fan is working. Remove inner rear panel of oven and see if element gets warm, let it run for a minute, switch off and feel if element is warm, if not, then replace.the element.
Plz rate this solution.
Thanks.
Dec 26, 2008 | Zanussi ZHQ575 Electric Double Oven
Ovens Logo
65 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
