Question about Cooking
What are the main things I should take into consideration when buying a smoking pipe?
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 18 Answers
As there are so many copycat in the world, so my first consideration would be the brand, world-class brand such as joyetech or anyvape, joyetech series and anyvape cvi are great, you can find more info on the world's largest e cig forum. Be aware buying from official distributor, you can find the distributor from their official website, there's a page listed. For me i would find the best price from their distributor list. My recommendation: Anyvape CVI E Cigarette Hope helps.
Posted on Jul 01, 2013
    Problem Solver:
  • 18 Answers
There are three main things you should take into consideration when buying a new smoking pipe divided into categories, aesthetic, mechanical and financial. You should examine each of them in order to build-up a solid pipe that will be best for you.
Posted on Jan 10, 2013
Which is one of the best way to get real experience of smoking? Suggest some good ideas.
There are a variety of ways that one can use to get real experience of smoking. I know some of the things that people generally go for. They are -
1. Cigars.
2. Cigarettes.
3. Water Pipes.
4. E-Cigarettes.
In which I mostly prefer to use water pipes that provides me with the best smoking experience to get the best detailed knowledge for smoking. This provides you with the best option of smoking tobacco through water pipes and leaves you with its taste in your mouth for a longer period of time. You can also get more detailed knowledge on it from Online Head Shops which provides you with the best quality water pipes at really cheap rates.
Dec 23, 2016 | Cars & Trucks
My 98 firebird tail pipe blows white smoke and water out the tail pipe then as i let it sit for 30 minutes the engine gets hotter then gas like smile and heavier smoke come out the tail pipe it also s
One of the main causes of white exhaust smoke and coolant loss is a cracked or warped cylinder head, a cracked engine block, or head gasket failure caused by overheating. A cracked head may allow coolant to leak into one or more cylinders or into the combustion chamber of the engine. Dirty coolant, a poorly maintained cooling system, a low coolant level, or a non-functioning cooling fan can cause engine overheating. In addition, engine wear can eventually cause the gaskets to lose their capacity to seal properly allowing internal coolant loss. Intake manifold gasket and head gasket failures are two of the most common sources of internal coolant loss caused by engine wear.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Aug 21, 2012 | Pontiac Firebird Cars & Trucks
I have a 1994 Mitsubishi 3000GT with 192,000 miles on it. Recently the oil pressure on the gauge has been dropping down to the "L", i hear knocking sounds coming from under the valve cover and...
the problem with the 3000GT is that most people that had them cars hot rodded the heck out of them. the only thing that can make noise from under the valve cover is a hydralic lifter is bad but often when u hear knocking noises its most caused by bad connecting rod bearings and main bearings dark blue smoke is a clear sign that the motor is burning way to much oil and may either have bad piston rings or other internal engine failure. either way you look at your best bet is to trade it off or buy a rebuilt motor cause there is no way of saving yours.
Dec 25, 2010 | Mitsubishi 3000GT Cars & Trucks
Rayburn nouvelle smoke exhaust from boiler burner front pipe joint-copper small od. metal washer and rope seal!
normaly this little seal and washer is enough to keep the smoke in
you must have a unclear flueway. i would remove and clean the baffles in the top of the boiler burner first that make sure i have an updraught in the main flue pipe then try again
Feb 07, 2010 | Kitchen Ranges
Smoking 305 motor
back vent on valve cover? some is normal especially when hot. you must take into consideration, all engines have blow by(fuel-oil vapor) that if your not re-directing into the intake to be reburned, will be exspelled through the vents. if oil is this or old or if is running hot, that this will cause this also
Sep 02, 2009 | Pontiac Trans Cars & Trucks
Cause and solution
sounds like one of the oil breather pipes is bloked wich will cause oil to feed to the cylinder wich will cause smoke and uneavan running wich will cause the car to **** when standing. take off all breathing pipes main ones come from the rocker covers clean them and put them back. the main engine breather will come out of the engine block do the same.
Jun 17, 2008 | BMW 750 Cars & Trucks
Cooking Logo
150 people viewed this question
Top Cooking Experts
Tom Chichester
ray gallant
Are you a Cooking Expert? Answer questions, earn points and help others
