Question about Boating
What should I do regularly in order take care of my boat?
    Problem Solver:
  • 8 Answers
First of all, you must remove the boat from the water every couple of days in order to prevent stockpiling of algae and barnacles. In addition, you should recharge the battery after every trip. Lastly, check your battery regularly to make sure it is charged. For more information, check out this very informative website:
Posted on Jan 10, 2013
Hi, have a mariner 75hp outboard serial number 9502368. Can you please identify year and model so I can order spares
Hey Arthur,
These guys will take care of you,,, that serial number doesn't satisfy the rewquirements for a search...? They will need more info.. more numbers on any plate..freeze plug..look around the outside of the engine carefully..
Outboard Motors Boat Parts Marine Engines Inboard Boat Motor
Jun 19, 2017 | Boating
I switched from lipo batteries to regular batteries on Spartan boat. Now will not run on either batteries. Is there a way to reset and start over
You can't switch form LIPO to "regular" because the voltages are completely different LiPo is 3.7 Volts per cell, standard is 1.5 Volts. Hope you haven't burned out the electronics.
Apr 25, 2016 | Boating
Stratos bass boat
Is your speedometer working? If not, the pick up tube may have come off and is dripping water in through that.
May 02, 2014 | Boating
How can I make sure I wont suffer from battery failures?
In order to make sure that your battery won't die on you, make sure to fully charge it every time. One of the mistakes people make is only partly charging the battery at a time, which leads to battery failures in the long run. For more information on how to take care of your boat battery, check out this website: http://www.yachtsurvey.com/boat_battery_basics.htm
Feb 06, 2013 | Boating
What soap should I use in order to wash my boat?
In order to wash your boat, you should use surfactants. If your boat contains aluminum, you should use special aluminum cleaners, such as Pontoon Boat Cleaner and Polish.
What materials are pedal boats made from?
The best material for a boat is Fiberglass. However if you prefer Plastic you may want ABS which is harder and lighter than the regular plastic. Aluminum is also a good material for boats. Its downside is that it lacks the foam and it conducts electricity.
Jan 14, 2013 | Boating
1964 5 1/2 hp evinrude kills at high speed
You should have a High Speed carb adjust and a Low Speed carb adjust. If it's running fine while idling, adjust the high speed setting. If you have two nobs, its the lower one. May be set wrong. If you don't have two nobs, remove the carburator and check the jets to make sure they are completely clean or better yet, order yourself a carb rebuild kit to take care of all of this. I just rebuilt my 1971 evinrude 4hp and the carb kit made the world of difference.
Apr 17, 2010 | Light Outboard Motor Boat Bass Fishing...
I need a new inflation valve for my colorado pontoon boat
Check E-bay -
Item number: 310151809453, Pontoon Boat Boats Outdoor Parts Repair Kit Kits black
What is your problems with pontoon bladder
Thanks for reply
May 30, 2009 | Sage Colorado Pontoon Boat
How do iI chose a fishing boat?
There are three styles of regular fishing boats; deep v, regular v or modified v. The v determines how well the boat cuts through the depth of the water. The deep v is better suited for large lakes because they can handle heavy waves better. Regular "v" is more appropriate for smaller lakes and a man made body of water. As the water is not as deep and the waves are not as heavy, this type of boat is able to handle the situation. The modified v is the most popular version. It is capable of handling speed best. Most fishing boats on the market today are made of fiberglass or aluminum. What is best for your fishing situation? Do you want to fish in large lakes or small lakes? The options are endless. There are several classes of fishing boats for different situations. All purpose fishing boats are great for your basic fishing needs. This type of boat has space for some bench seats, fishing gear and a simple steering station. They are made of either fiberglass or aluminum and are between 15 and 20 feet long. Another type of fishing boat is a bass boat, which comes fully equipped with space for rods and fishing gear. The boat is fully built with electronics and livewells. This boat also is made out of fiberglass and aluminum. The advantage to this type of boat is it is made especially to catch bass, fast. The third type of fishing boat is the center-console. It allows a fisherman to angle from any place on the deck. The control center is located in the center. Depending on the size of the boat they can be used offshore as well as near. Flats boats are mostly made up of fiberglass. The advantage of these boats is they allow easier angling access to saltwater flat fish. Another advantage it has is a poling platform that allows for fish spotting. Finally, a casting deck allows the angler to keep control. This makes this ype of boat convenient for fishing. The final category of fishing boats is the fun boat because it combines the motor of a yacht and the functionality of large a cockpit to work trophy fish and bring them on board. If ou are a fishing fanatic then it is important to have all the things that you need to make your fishing trip a success. Fishing boats are definitely the finishing touch to a nice fishing trip.
Dec 01, 2008 | Sea and Sea Sea Eagle Inflatable Fishing...
Boating Logo
401 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
