Question about Honeywell Heating & Cooling
Heater model no. HZ-367 shuts off after a few minutes of running. How to fix it?
For the last several months this heater runs for a few minutes and then shuts off. I suspect some temperature sensor may have gone bad. Anyone know how to repair this?
SOURCE: heater keeps shutting off !!
I have model 5532, but I think they all have the same problem. There seems to be a safety device in the ceramic heater that turns off if it gets too hot. It "remembers" when this happens as well and will shut off until it is unplugged for 10-15 minutes.
This happens on even lightly used heaters if used in dusty conditions. Dust builds up behind the ceramic heater and the lack of flow causes it to overheat. The unit must be dismantled and the dust brushed/vacuumed out. The good news is that not only will the heater work again, but it will have better airflow too!
To do this, tech support and other people say to "clean the rear grill", but my rear was not dirty. The front grill had some dust that I vacuumed clean, but did not help. In my unit there are no filters before the air goes through the heater element. The problem is in the center of the heater. Taking out the internal fan (four screws on the sides of the squirrel fan box), I could see that the radiator was over half covered in dust. I cleaned that dust out using a shop vac and the problem went away.
Opening the heater was a little tricky, two of the screws were triangle head screws. Once inside, however, it is a simple proceedure to remove the fan. Of course, you should unplug the heater and wait a while before opening it up to make sure there are no electrical charges stored in the unit.
Posted on Apr 05, 2008
SOURCE: heater won't stay on
This product does indeed have a problem with the safety switch, that is only supposed to kick in when the unit is turned over. I had a total of 3 units sent to me from Kaz. Each time the unit would work for a short time, then slowly begin to turn off and on. I finally decided to take the unit apart and look for any obvious problems. There is a weighted swivel that will raise a contact point to turn the unit off in an emergency. The contact points would spark off and on, depositing a black carbon on them until they would no longer allow power to pass through. I cleaned the contacts with a fine finger nail file and bent one of the contact arms inward to make better tension between the contacts. This allowed the unit to stay on for longer periods of time. But even with the thermo-stat turned all the way up, the unit does not stay on long enough to heat the room. In effect, what happens is the contacts will continue to ark, putting black deposits on the contacts until you're back to square one. Apparently the unit also has a thermo-stat related problem. I'm sending the unit back again (they only made me send the power cord last time), but will insist on a different model this time. Good Luck
Posted on Feb 24, 2008
SOURCE: Honeywell HZ-709 Oil Filled Radiator
Problem: firs let's identify the problem, there is a sensor on the inside panel, made originally for safety if you tipped the heater off, it kill the power causing it to turn off...after a year of so that sensor get a little rusty/dirty causing it not to work correctly...
let's find out how to fix that annoying turn off..
tool needed, a phillip screw driver.. electrical tape or soldering unit..
fixing it: take out the top and bottom screws, to open the panel. after you open the panel you'll see a metal bar screwed to the front controller...take all 6 screws out...the front panel comes off....then there is about 4 screws holding an inner box, open that up..
inside there, you;ll see lots of wires...look for 2 small blue wire running together to a black sensor that make noise everytime you move it....
disabling the sensor
2 ways you can do this..
-you can cut the wire off using a scissor, and connect the blue wires together, use the tape to tape them.
or
- you can solder them together on the back of sensor panel...
there you go problem solved...
Posted on Mar 25, 2008
  • 8 Answers
SOURCE: lasko heater run about 5 minutes and shut down/how to clean
i have the same problem ... i almost throw this heater out ,,
the fix .. open the unit theres 6 screw at the back.. remove it if you have problem removing the triangle screw use the small square head screw ...size 0 and then you also need to open the black plastic ..
i believe it has 8 screws .. then vaccuum all the dust .. chances are the front and the back of the heating element is covered with dust ..
after that put all back together and i guaranteed it should work like brand new ,,,, dont worry its not that hard ... the only hard thing for me was removing the 2 triangle screws at the back .. Goodluck
Posted on Feb 23, 2009
  • 288 Answers
SOURCE: all pro heater runs for a couple of minutes.then
it only shuts down because of an overheating condition or the lack of fuel. if you have an ohm or multimeter, check the ohms on the fan and see if you have any resistance. If you do the fan is good but may still not be putting enough air across the heat exchanger to safely alloww the heater to run without causing a fire.
Posted on Dec 19, 2009
My Dyson Bladeless Fan/Heater is displaying E7 after a few minutes of running and then shuts down? It is brand new (a couple of months old) and been run about 3 times.
Hi Michelle, it's Jack at Dyson.
If your AM05 Hot + Cool heater is displaying the E7 error code, the best course of action is to contact us directly for further assistance. To diagnose the cause of the issue we would need to understand more about how the heater is being used - we should also be able to suggest a suitable resolution.
You can reach us by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
We'll look forward to speaking with you.
Dec 08, 2014 | Dyson Air Multiplier 10" AM01 Bladeless...
Model hz709 manual
Was there any physical damage to the heater when it fell over?
The HZ-709 has safety features that might prevent its subsequent operation.
1 - It has a tip over switch but the heater should operate normally when it's upright again.
2 - A thermal cut-off fuse will permanently shut down the heater should it operate at a higher than normal temperature. Was it operating when it fell over, or could it have overheated?
If it's none of those, try contacting the manufacturer Kaz directly by email, Facebook, Twitter, etc. as the HZ-709 has a 3-year warranty.
Digital Electric Radiator HZ 709
Jan 31, 2014 | Honeywell HZ-709 Oil Filled Radiator...
HEATER STARTS RUNS FOR FIVE MINUTES AND SHUTS OFF,.
thermo stat saying its already heaps hot .is it turn up fully? also could be a saftey thing you know how it tips over and turns its self of mybe that sensor is faulty . if its under warranty take it back . try shaking it first
Nov 10, 2010 | Honeywell HZ-709 Oil Filled Radiator...
Heater starts and runs for several minutes and then turns off
Since the unit runs for a couple minutes, I would first check for proper water flow. Find the pressure switch. It is usually round with two wire terminals and a copper/metal tube attached to it. With the wires attached, use a jumper wire to bypass the switch. If it runs longer check for flow problems.. (WARNING don't jump the switch for too long!!! Just enough time to see if the run cycle improves). Clean all the skimmers baskets, pump basket, backwash the filter (if a cartridge filter clean the filters). Try firing the heater again. If it still shuts down, replace the pressure switch. I never recommend adjusting it. Adjusting it too low can damage your heater and/or cause injury.
Jul 21, 2010 | Hayward 250K BTU NATURAL GAS POOL HEATER...
Heaters runs for a few minutes then shuts off.
was working fine refilled it and now it will run 5sec. and kick the breaker on it.It's an old 80's model 35,000 B.T.U. I cleand the photo eye with a cloth no change. Any solution's
Jan 29, 2010 | Reddy Heater-30-55,000 BTU Variable
Kerosene Portable Forced Air heater comes on, runs awhile
Here is a link to your owner's manual... http://12.153.20.74/manuals/123919-01A.PDF. Look on page 8 and 10. It could be several things. It could only be a dirty fuel filter or the pump pressure may just need adjustment. If you need a part you can contact Master Parts at 800-466-1446 or you can find them on-line at www.masterparts.net. I hope this helps!
May 04, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Heater runs hot for a few minutes then stops heating
I would say from what you have described your problem is a bad thermostat heat sensor (you may have to replace the whole thermostat on this model!) This is a very common problem for this unit!
Please rate my sesponse!
THANK YOU
Jan 14, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Similar model compact heater will not "power up" after storage
they is no reset internal the electronic circuit is deferctive some electronics parts need no be changed. i have fixed one and modify it to be more reliable.
Oct 01, 2006 | Honeywell SureSet HZ-339BW Ceramic Compact...
Heating & Cooling Logo
129 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
