My son in law died and i am not authorized to add on color printer
I need administrative permission
  • 32,281 Answers
You can remove or change the Window's User or administrator's password. You need access to a computer with Internet access to download the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot up the laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CD which contains quite a lot of Utility programs including a password removal program. Click on one of these links to download HIREN'S BOOTCD :- http://www.hirensbootcd.net/ http://67.20.82.163/
Posted on Jan 10, 2013
I do have a FNB app , I need permission-please ask administrator for permission
Hello John Neale Spear ...
When you buy an APP the ONLY PERMISSIONS needed
are the ADMIN for the system on which you are loading
the "APPLICATION"...
Whatever SYSTEM YOU ARE ATTEMPTING this modification...
you DO NOT HAVE THE AUTHORITY to do so...!!
Got absolutely NOTHING to do with the FNB software...!!
Check with the owner... or log in as ADMIN...!!
If that's you... Re-orient yourself with your
own security systems.
Carnac
Carnac the Magnificent
Jan 31, 2017 | Computers & Internet
Scan to computer hp color laser jet 6030 printer
Need administrator permission to create scan to folder option..once permitted,insert driver cd open it choose send to folder option create folder, name it & create.. if its success check in printer same folder has to create...Any difficulty go to hp website there you can find out how to create folder as well as its described in driver CD.. But with out administrator's you cat,t do it...
Feb 01, 2012 | HP Office Equipment & Supplies
Window cannot access the specific device,path,file. dont have appropiate permission
Ok this happens when the user account don't have the permission to acces the folder, disk etc.
Verify that the account you are using have the permission to access it. Right click the object you are trying to access and choose properties, then security (I don't know your window versions but is very similar in all versions). Check if the user account show in the box and the type of permission. If is not in the list should be add. To add you need administrator account privileges. çlick edit and add the user and the type of permission to grant. gabytek_1.gif
May 23, 2011 | Samsung N13013B Netbook
NO PERMISSION TO EDIT OR VIEW As an administrator, I thought I have all the privileges to edit, view read, modify, execute and write any folder, but on certain folders I must first grant myself the...
you need to Take ownership of those files...
For Files:
takeown /f file_name /d y
icacls file_name /grant administrators:F
For Folders or Directories (will perform action recursively):
takeown /f directory_name /r /d y
icacls directory_name /grant administrators:F /t
Replace file_name or directory_name with actual file name or folder name, with path when applicable. The first command will take ownership of the file or folder specified, and the second command will grant full control permissions to administrators user group. Note that when using command for folders, to command will run recursively. To prevent the task been perform recursively, remove the “/r” and “/t” switch.
Above two commands have been scripted in Windows command shell batch script that easily perform the task of taking ownership and grant full control permissions to Administrators user group by typing simple command. Alternatively, users can add “Take Control Of” option to right click menu so that the next time you need to take control of a file with full control permissions, it’s just a one click task.
Feb 04, 2010 | Acer Aspire™ T180 PC Desktop
How to install the printer via internet ?
Viewing Internet Printer Configurations Using PWM loadTOCNode(2, 'summary');
  1. Click Start, point to Settings, click Control Panel, and then double-click Add/Remove Programs.
  2. Click Add/Remove Windows Components.
  3. Click to select the Internet Information Services (IIS) check box, and then click Next.
  4. Continue through the wizard and accept all defaults.
  5. After you finish the wizard process, install a local printer and share it.
  6. Right-click the taskbar, and then click Properties.
  7. On the Advanced tab, click to select the Display Administrative Tools check box.
  8. Click Start, point to Programs, point to Administrative Tools, and then click Personal Web Manager.
  9. Click Advanced.
  10. In the tree view of folders, scroll down and click the Printers folder.
  11. Click Properties and verify the following information:
    • %SystemRoot%\Web\Printers is listed in the Directory box (where %SystemRoot% is the path to your Winnt folder)
    • The Read check box is selected in the Access Permissions area.
    • The Scripts button is selected in the Application Permissions area.
  12. Click the printer you want to install and view its properties.
  13. On the left side of the screen, click Connect in the Printer Actions section. You are now ready to print.
Jan 16, 2010 | Office Equipment & Supplies
Help with HP Deskjet D1560 Printer!!
Solution 1
Right click on setup file and select run as administrator
Solution 2
  • open registry editor, start -> run -> type in: regedit
  • Open Hkey_local_machine folder
  • Open System folder
  • Open Currentcontrolset
  • Right click with mouse on enum
  • Select Permissions
  • make sure user: SYSTEM has FULL CONTROL permission
  • See picture:
Make sure system has Check On Allow Full control and read.
Check all users listed that there are no checks on deny.
You can also press ADD to add your own user, then click advanced, then click find now , select your user, click ok, click ok, give your
user full control and read permission.
Apply and ok. double check that there are no Deny permissions set.
let me know the results and do not rate solution untill we have solved the problem.
Thanks,
Ekse
May 05, 2009 | HP D1560 Deskjet Printer InkJet
Son-in-law is unable to download a program into PC that we gave
try run windows in sefemode u can log in as administrator there and change under control panel, users the user password
Dec 27, 2008 | Computers & Internet
I CAN'T DELTE YAHOO MESSENGER
all you have to go to is CONTROL PANEL THEN TO ADD/REMOVE PROGRAMS. on there it should say yahoo messanger. click on it and press remove and restart your c.p.u. then the yahoo instant messanger will be gone
Dec 01, 2008 | Computers & Internet
HP LaserJet 5100 network printer
In admin mode, you need to add the client to printer permissions
You must be logged on as an administrator or a member of the Administrators group.
To assign this user right, follow these steps:
1. Click Start, click Run, type gpedit.msc, and then click OK.
2. Click Computer Configuration, click Windows Settings, click Security Settings, click Local Policies, and then click User Rights Assignment.
Dec 15, 2007 | HP LaserJet 5100tn Printer
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
