Question about Compaq Presario Notebook
My laptop opens a different program or opens multiple identical programs?
Every time i type or open a program my laptop opens different application such as if i click the start menu it opens the outlook program?????
  • Anonymous Jan 27, 2009
    tehse
  • murugesan_ke Jan 27, 2009
    these are some profiles is not working fo my laptop please able to solve the problems in our downloading my laptop modle is presario v 3500 plesae solve it
Compaq presario cq 40 not supported webcam vista edition
Posted on Feb 17, 2009
1,pls check if your pc's virus 2, if possible, check the regedit, the outlook is well and correct installed 3, not, phone me
Posted on Jul 02, 2007
SOURCE:
.fxp is not an object file
For additional information click the following link: https://www.fixtoolbox.com/dbffix.html
DBF Fix Toolbox
Also you can try to follow these steps:
    1.Click on Start and then Control Panel. 2.Click on the Programs link.
    Note: If you're viewing the Small icons or Large icons view of Control Panel, you won't see this link. Click on the Default Programs icon and then click on the Associate a file type or protocol with a program link. Then proceed to Step 4.
    3. Click on the Make a file type always open in a specific program link under the Default Programs heading
    4. In the Set Associations window, scroll down the list until you see the file extension that you want to change the default program for.
    5. Click on the file extension to highlight it, once you've found the one you're looking for.
    6. Click the Change program... button above the scroll bar.
    The Open With dialog box should appear.
    7. Look through the options in the Recommended Programs area and choose the application that you want to open the file extension with when you double-click on the particular kind of file on your computer.
    Note: Chances are, the applications listed under Recommended Programs will contain the most applicable programs for this file type but be sure to look at the applications under Other Programs. You may need to click the v to expand the list of these programs.
    Note: Click Browse... to search through your computer for any program not listed that you'd like to use.
    8. Click the OK button on the Open With window. Windows 7 will refresh the list of file associations to show the new default program to open this type of file.
    9. Click the Close button at the bottom of the Set Associations window. You may also close the Control Panel window if it's still open.
    10. From this point forward, when you double-click on any file with this particular file extension, the program you associated it with in Step 7 will launch and load the particular file.
    Important: Whatever program used to automatically open when these types of files were launched will still open these types of files. To use another program, you'll just need to start the program manually and then browse your computer for the particular file.
Nov 12, 2015 | HiBase DBF Viewer 2000
Evite website keeps freezing up. Both in chrome and explorer. works on another computer just fine. popups have been allowed. cookies and cache are cleared. It seems to freeze up when it's trying to...
Fixing Hardware or Software Issues
  • If the freeze happens every time a certain hardware device is plugged in or switched on, the device itself might be to blame. Check the manufacturer's website for updated drivers for the device, and download and install them to erase any bugs that might exist in your version. Similarly, if the freeze only happens when using one particular application, that program might also be the root cause. Check the developer's website for updates. If the problem persists, uninstall and reinstall the program. This process replaces any software files or settings that may have been damaged or deleted.
Overwhelming a PC's processor or memory by requests can also lead to the computer freezing up. If the issue occurs when large files or complex applications are being handled, shut down any running application or background utilities you don't need for the project you're working on. This frees up CPU time and RAM space. Within individual programs, avoid opening up multiple files or websites at the same time. If the problem persists and if opening multiple large files simultaneously can't be avoided, consider a hardware upgrade
Please follow this instruction.
God bless you
May 25, 2013 | Computers & Internet
I cannot open WordPerfect files with a double click.
Have you tried check the file associations? Try re-associating the application that your OS uses to open a type of file.
To do this, find a file of the type that you want to associate with a certain program. Right-click on this file and go to properties. Under the general tab, find the line that says "Opens with", select change. Now a new window will pop up asking you to select a program to use to open files of the same type. In this case you would want to select Word Perfect. If the program you want isn't on the list (and you know you have it installed), select "Browse". You will now have to look through your program files to find the main application for the program.
Hope this helps.
Jan 19, 2013 | Dell OptiPlex 980 Desktop Computer Core i7...
Lifeframe webcam on an asus laptop, says camera is used by another program
Don't open two programs that uses webcam, for example: if you have skype application opened with video call you can use the webcam at yahoo messenger. make show application that requires one web cam features like video calling are online opened when needed.
if the is a hidden program that you sure to have close it that is still in process, then open the task manager and click on applications, you will see and end it process there, if the problem persist then restart the computer.
May 16, 2011 | Computers & Internet
If i try to download something,like a video,it says connect media to save destination
You do not have a default program for your video viewing or that particular video requires a specific program to be used. Ensure that your computer has a video player such as Windows Media Player if you are using a Windows OS or that you have Quick Time if you are using a Mac OS. If these programs are already installed, then you may want to ensure that they are set to be the default program for that particular video.
Download the video, then right click the video and click the option that says "Properties". When the box appears, click open with and select either Quick Time or Windows Media Player. To avoid doing this for every video, follow the instructions below:
WINDOWS OPERATION SYSTEM
  • Open Windows Explorer by right-clicking the Start button, and then click Explore.
  • Click a folder that contains a file of the type that you want Windows to open in a program that you select.
  • Right-click the file and, depending on the programs installed on your computer, complete one of the following steps:
    • Click Open With to choose the program that you want.
    • Point to Open With, and then click Choose Program to choose the program that you want.
  • The Open With dialog box is displayed. Use one of the following methods to select the program that you want to use for this file type:
    • In the Programs list, click the program that you want to use.
    • Click Browse, locate and then click the program that you want to use, and then click Open.
    • Click Look for the appropriate program on the Web to browse the Internet for the program that you want to use.
  • Click to select the Always use the selected program to open this kind of file check box if it is not selected.
  • Click OK.
  • MAC OS
    1. 1quick-change-files-default-application-1.1-120x120.jpg Select the File to Make the Default Application Change
      In an open Finder window, select the file you wish to make the default application change to.
    2. 2quick-change-files-default-application-1.2-120x120.jpg The Contextual Menu for the File
      Right-click your mouse or use a "Ctrl-Click" with the keyboard to bring up the contextual menu for the file.
    3. 3quick-change-files-default-application-1.3-120x120.jpg Clicking the "Option" Key Changes the Menu Item to "Always Open WIth."
      Press the "option" key on your keyboard and you will notice that the "Open With" menu item in the contextual menu will change to "Always Open With." Select the "Always Open With" option in the contextual menu.
    4. 4quick-change-files-default-application-1.4-120x120.jpg Select the Application from the "Always Open With" Menu
      Select the Application from the "Always Open With" menu to make your changes to the file, and the newly selected application will become
    Nov 29, 2010 | Computers & Internet
    My computer will say ''not responding''.
    It can happen when the computer is busy executing other programs or the CPU usage is more due to multiple application running at the same time. The best way to resolve this issue is Upgrade the memory on your system. You can also try to disable the startup applications from system configuration.
    Press the Windows key and letter "R" on your keyboard
    It will open the run windows
    Type "msconfig"
    Click ok
    In the system configuration window select the Starup tab
    Click on disable all
    Click apply
    Click OK or Close
    Restart the computer
    Jul 19, 2010 | Gateway GT5220 PC Desktop
    HAVEA TOSHIBA LAPTOP WITH A FINGERPRINT IDENTIFIER TO OPEN WINDOWS, WANT TO CHANGE THE FINGERPRINT TO MY DAUGHTERS. HOW DO WE ACCESS THIS?
    dentifying the fingerprint readerA fingerprint reader provides extra security for the PC. The VeriSoft Access Manager by Bioscrypt uses the fingerprint reader to identify the user, and controls access to Windows or other secure systems. Instead of typing a User ID and password, you can move your finger across a sensor to logon or start commonly used applications. Verisoft Access Manager can manage all of your different secure accounts and the required user names and passwords by recognizing your fingerprint.On HP notebook PCs, the fingerprint reader is a small metallic sensor located near the keyboard or display. By swiping your finger perpendicular to the metallic sensor you can logon to the PC, a network, or open a program. c00897920.gifBefore you can use the fingerprint reader, you must set up the fingerprint reader by registering your fingerprint with the Access Manager. Set up the fingerprint reader To set up the fingerprint reader to recognize a user, the user must have a logon account on the PC and the account must have a password. Multiple users can be registered for the fingerprint reader if each has their own user account.
    1. In Windows, double-click the VeriSoft Access Manager icon c00897921.gif in the notification area of the taskbar to open the My Identity window. Alternately, click Start > All programs > Verisoft > My Identity .
    2. Click Log On to open the VeriSoft Logon Wizard. Click Next to begin.
    3. Enter the User's Windows password in the Password field on the Introduce Yourself page, and click Next . If you have successfully logged on to Windows, click Finish to close the wizard.
    4. Click Register Fingerprints on the My Identity window, to open the VeriSoft Logon Wizard. Click Next to begin. c00897922.gif
    5. Select a finger shown on the hand graphic, and then slowly swipe your finger across the sensor. One of the squares below the hand graphic will change color when the scan is accepted. A message displays if the scan is not accepted.
    6. Swipe the same finger across the sensor again until all four squares change color, then clickNext to register the finger print. If you need to start over during the fingerprint registration process, right-click the highlighted finger on the screen and then click Start Over .
    7. If prompted to register a second fingerprint, click a different finger on the hand graphic, and then repeat steps 5 and 6.
    8. After using the Registration Wizard to registered at least 2 fingers, click Finish .
    9. To set up the fingerprint reader for a different Windows user, log on to Windows as that user and then repeat steps 1 through 8.
    After registering your fingerprint you can log off and then use your registered fingers to log on to Windows. Using Fingerprint reader before registeringIf you swipe your finger across the fingerprint reader before it is set up, the Access Manager opens a logon wizard window and prompts you for informa
    Feb 03, 2010 | HP Pavilion DV5234US Notebook Laptop
    I have downloaded a MRL'mms' file that I chose open with vlc as the default programme, how do I change this setting because it will not play on vlc, would like to choose another application to open it with
    hello, you can make a right-clic on you're file and choose "informations".
    you will have a choice "open with" :
    two ways:
    1 you want to read the file once with another program, choose it in the list.
    2 you want to assign the program to this type of file, choose "other" and then point the program in the applications directory.
    Jan 20, 2010 | Apple MacBook Mac Notebook
    I bought a new laptop 4days ago and got a free microsoft word 2007 trial with it for 60days.it is now locked and even though i have type in the product code it wouldnt except it.how do i unlock it?
    you have to put the disc on the laptop and install the it will ask you product key then you open your ms office disc book and its there inside .then you type in .
    Jan 12, 2010 | Microsoft Office Professional 2007 Full...
    Dealing with spontanoeous opening of multiple applications
    There is a possibility of the programs of the phone being corrupted ,get the item software reinstalled becouse a virus might be present ie from net
    Aug 31, 2009 | Motorola Mobility ROKR E6 Smartphone
    Compaq Presario Notebook Logo
    96 people viewed this question
    Top Compaq Computers & Internet Experts
    Ekse
    Thomas F. Schneider
    Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
