Question about KitchenAid Microwave Ovens
KITCHEN AID MICROWAVE KBHC109JSS04
LIGHT
MicrowaveSvc
  • 9047 Answers
SOURCE: How do you replace the fuse in a microwave oven.
Be sure the oven is unplugged or the breaker is off.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgdee77f7.jpg
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
You can also find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Let us know if we can help further.
Posted on Jun 06, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: Burned out bulb on Kitchen Aid Microwave Model KBMC140
You will need to remove the oven from the wall and remove the outer cover.
If for some reason you don't have yours, you can download your owner's manual and installation instructions free from this page.
These models use halogen lamps. You must not touch halogen types with your bare skin, as the oils will shorten the bulb life.
You should be able to get one from a home center or local appliance parts store.
If you order it online (from the link above) it is part # 4375348.
Posted on Aug 04, 2009
hiltonjug
  • 612 Answers
SOURCE: kitchen aid microwave model# khms 147 hss-1 runs but doesnt heat
Your problem is your mag tube (Magnatron) you can go to www.partsselect.com and your part number is PS2352604. Their price is $123.44. I work on micro waves myself and have found that if one isn't a built in over the stove like yours, they are not worth repairing because you can buy one cheaper. If this unit is not real old and you can replace this parts yourself it might be worth fixing bit if you are going to have it repaired, it might be cheaper to replace it. Good luck.
P.S. If you open this unit up. Make sure you bleed the capacitor off, this is one that will knock the _ _ _ out of you if you ground it by touching it. Bleed it by using screw driver to short capacitor to ground or case.
Please rate this solution
Posted on Sep 03, 2009
  • 15 Answers
SOURCE: lightbulb burned out for microwave model # KHMS
Most home improvement stores and even some Walmarts/Chain grocery stores/Ace Hardware carry replacements. You will need to remove the cover from the microwave oven on most models unless your bulb is inside a protective cover inside the actual oven. Take the bulb with you when you go to make certain of a proper match. Be certain to unplug the oven if you need to remove the cover in any case.
Posted on Oct 13, 2009
  • 167 Answers
SOURCE: kitchen aid microwave is locked
Touch and hold cancel/off button until unlock appears on the display.
Posted on Jun 21, 2010
Mod.KHMS155LSS-1 Getting F-6 Fault code ????
Search Results
    Combination Microwave Wall Oven - Error Code/Message ...
    www.kitchenaid.com/...microwave...error-code...f6-error-cod...
    KitchenAidQuestion: Combination Microwave Wall Oven - Error Code/Message - F6 Error Code -F6 E8. Answer. Product Symptom: Combination Microwave Wall Oven ...
    Over-the-Range Microwave - Error Code - Starts with F ...
    www.kitchenaid.com/...microwave-error-code...f...f6...code/P...
    KitchenAidKitchenAid's product help articles give answers to your frequently asked questions (FAQs). ... Microwave - Error Code - Starts with F - Starts with F6 - F6E0 Code.
    Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kitchen Aid Model # KEMS308SSS02 and I getting the follow error message... is working and was always working but the top microwave/oven does not work. ...Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost Err/ F6 E0/ ... Most "F6/E0" fault codes is usually because of a loose wire connections, loss of ...
Feb 05, 2016 | KitchenAid Microwave Ovens
Why won't my interior microwave light turn off and my microwave won't start?
It sounds to me that your door switches aren't working.Your oven is protected by a couple of switches that engage when you open or close the door.They control a couple of safety features and also your interior light.One of them seems defective.
Dec 17, 2014 | KitchenAid Microwave Ovens
Installation instructions for Kitchen Aid KEMC378KSSo3
Hello, John. Hereis a link you can use to find manuals and parts list for your unit: http://bit.ly/bOwwxbI hope this information is helpful.
Sincerely, Melanie.
Apr 09, 2012 | KitchenAid KBMC140HSS Convection/Microwave...
How do i remove the halogen light in my micowave
I have a similar Kitchen Aid model. The little light inside my unit also went out. I called Kitchen Aid and they scheduled a tech to come out to change it. He said the only way to get to it is to pull the unit out from the wall (it's a built in unit). $150.00 bucks later I had a light for about another year before it burned out too. Needless to say, the heck with it, I don't need the light that bad.
Nov 16, 2011 | KitchenAid KBMC140HSS Convection/Microwave...
I'm looking for repair manual for range made by Kitchen Aid
web search-kitchen aid range manuals- or -kitchen.manualsonline.com
Oct 15, 2010 | Microwave Ovens
Microwave Ovens Logo
69 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Stu Ungar
Darial Jr Lasaria
Darial Jr Lasaria
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
