Question about Biostar M7VIZ-A23 Motherboard
Hard drive won't run
When first start up, the the hard drive will not start but the psu is ok, the motherboard is M7VIZ-A24, thanks, Ray
  • 112 Answers
Remove the hdd cable and add hdd cable.
Posted on Jan 21, 2009
My computer won't start in safemode or in any other mode
test all leads that attach to your hard drive including electrical extensions SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
laptop or desktop computer??
test your psu power supply unit if the psu units fan is not working the psu is faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty ?
even something as small as an electrical extension or a faulty fan lead can cause this problem computer needs all of the data and power to travel through every working device and to have an end for a computer to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
also check your computer ram and cmos battery to make sure they are securely seated and the battery has plenty of charge Cmos battery on some motherboards are soldered in
hope this helps you
Sep 24, 2011 | Computers & Internet
Continue looping restart, i replace new PSU, memory and hard drive but still looping motherboard Asrock G31M-S DDRII
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error if this fails to fix the problem
another possible reason could be a memory dump you might be running to many programs at the one time placing to much strain on the CPU also you might not have enough RAM random access memory to check what is running when your computer is running scroll to the bottom toolbar right click select task manager applications and processes if you see something you dont need running select end now to check how much ram you have click start right click on my computer select properties you will see all of your computers details another way to check how much RAM you have click start all programs accessories system tools system imformation all of your computers imformation will be there try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive this will schedule on a restart don
Jul 21, 2011 | ASUS P5KPL-AM SE Motherboard
I have a an Asus P4P800 Motherboard and when I boot up it is giving two short beeps, displays the motherboard screen, goes black, and then does the sequence starting with the two beeps again and...
first make sure the RAM is securely seated
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
May 17, 2011 | ASUS P4P800-MX Motherboard
I cannot start my PC. Screen is always black wen I start PC. Power sup play is OK. Hard disk is OK processor is AMD athlon and I don't know haw to test. Please answer to me
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
Apr 24, 2011 | Abit KU8 (841020002984) Motherboard
Computer will not boot all the time. Getting worse. Have to do a cold boot and it may start up. Boot failure will not recognize hard drive but BIOS will. I changed the hard drive about 6 mths ago. I...
It doesn't appear to be a RAM or CPU problem. It could be the motherboard (maybe the SATA controller), or the hard drive. There are two thinkg you can try:
1 - connect the hard drive to another SATA port, and change the boot order in the BIOS to point to the new port. If it works then it's a problem of that specific port. (motherboard problem)
2 - connect the hard drive to another SATA port on another controller. If you have the hard drive connected to a red port, try a black port. If it's connected to a black port, try a red port. If it works then it's the controller. (motherboard problem)
3 - try to install the OS on another hard drive and connect just that hard drive. If it works, then it's an hard drive problem, and you can replace that.
Mar 04, 2011 | ASUS P5N-E SLI Motherboard
When i turn on my computer, processor fan starts ok , I get bip, but system doesn't start, no single message or simbol on the screen. I removed the cover and shaked processor fan, after it starts and whole...
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
dont forget to vote
hope this helps
Feb 02, 2011 | ASUS P4P800-X Pentium Motherboard
The screen is not started
One bad lead can cause a computer to fail to detect a hard drive continue on a cycle or to shutdown
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA and
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
problems
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors automatically fix any corrupt files on your hard drive then defragment your hard drive you have to keep a computer very clean & free of dust and give it regular maintanance
hope this helps
Dec 14, 2010 | Asrock P4i48 Motherboard
Computer will not start. I have tried a hard reset and cheked the ac adapter, which seems to be ok. I am being told it may be the motherboard. Since it was working fine one day, and then stopped...
this can be due to many reasons namely Power unit (PSU) failure, broken power switch and short circuits. see if your motherboard LED indicator light is glowing when you turn on power
Dec 14, 2010 | HP Compaq Presario F500 F700 and G6000...
I think my motherboard is bad. My computer won't turn on. Have tested the power supply and I believe it is good. When power cord is plugged in the green light is on but very dim. When I disconnected the...
Replace your PSU then test all leads that are attached to your hard drive sounds like a faulty lead of some sorts then
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty because a computer has to have an end to the circuit any fulty leads will lead to no boot up
good luck
Sep 07, 2010 | HP Computers & Internet
Booting
try to reformat your hard drive because it not compatible with the configuration of your new motherboard
Mar 27, 2010 | Biostar M7VIZ-SATA Motherboard
Biostar M7VIZ-A23 Motherboard Logo
Top Biostar Computers & Internet Experts
Jayburt
David
David
Jerry Umali
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
