Question about Panasonic Panafax UF-560 Plain Paper Laser Fax
UF885 (YC) OPT-3
Please can you send me some information regarding the above subject. I can't able to send the fax.. With regards,
  • 31 Answers
I need more info to help. Is the phone line plugged into the "L" port? Are you able to receive?
Posted on Jul 03, 2007
SOURCE:
Send picture messege
1. In Idle mode, press <Menu>2. Press <Add> on the Subject 3. Enter the message subject and 4. Press <Add> on the Picture 5. Add an image file. 6. Scroll to the Sound line and 7. Add a sound file. 8. Scroll to the Message line and 9. Enter the message text. 10. Press <Opt.> and select Done.
11. Press <Opt.> and select Send. 12. Select an empty location. 13. Enter a destination. 14. Press <Send> to send the message
Or you can use samsung x640 "code" in my blog
http://pcgadgetdeni.blogspot.com/2013/02/all-phone-samsung-codes.html
Feb 14, 2013 | Samsung SGH-X640 Tri-Band GSM Camera Cell...
Email purporting to be from yahoo. please investigate
It's a froud. Don't fall for it. It is a low process but it is risky for you, and I do not think it matters. If you have one that sum, I bet it wasn't just an email
Feb 13, 2010 | Yahoo Mail
Cannot send out fax
Please check the following document which would help you to fix the issues regarding the fax issues.
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?lc=en&cc=us&docname=bpu02151
Regards,
Sagarjd
Nov 21, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Panasonic Panafax UF - 885 unable to send faxes direct
Hi BrendaAsh,
Thank you for the above information.
Please ask rlandriani to access the user parameters on the fax machine and turn the Quick Memory XMT to "Off" or "Invalid".
This should set the machine for direct manual sending without memory intervention.
Regards
Gavin.
Oct 17, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
Broadcast Fax Sending
Change the resolution to STANDARD. This will cut your send times by 50%
Sep 06, 2008 | Symantec Winfax Pro 10.03 (winfax10.03)...
Check Scan Platform
Once run the fax setup wizard from the HP Director and then try to send the fax again.
Apr 24, 2008 | HP Officejet 4355 All-In-One InkJet...
Call Sevice 4
reset the unit..press menu#9000*550 Then press start.Call service 3 has something to do with the temperature of the unit check thermostat @ the fuser unit.replace it because the thermostat is not switching to on/off condition although it reaches its peak temperature.
Mar 17, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
I can neither send or receive faxes
hi 003 - Recording paper jammed when feeding from the 3rd cassette. Remove the jammed paper. (1) Open the Printer Cover. (2) Remove the jammed paper. (3) Slide out the Paper Cassette. (4) Remove the jammed or wrinkled paper and reload the recording paper into the paper cassette. Caution: Make sure that the paper is set under the clips of the Paper Cassette. You can load about 500 sheets with standard weight paper (20 lb. or 75 g/m2). good luck
Feb 23, 2006 | Panasonic Panafax UF-885 Plain Paper Laser...
Panasonic Panafax UF-560 Plain Paper Laser Fax Logo
50 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Shannon Murphy
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
