Question about Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV
I have replaced the lamp.Now the lamp wont come on and tv shutts
Hi
I have repalced the lamp.I also took the optical block out and checked for thermal sensor it is ok.Now the lamp wont come and when tv turned on shutts off.4 blinks and tv shutts off after each try.Please kindly advice me
Did you replace the lamp cover after replacing the lamp? Make sure the cover is properly installed.
Posted on Jan 24, 2009
REPLACING OPTICAL THERMAL BLOCK
The Optical does not on its own have a "Thermal block" some Sony sets do have a thermal fuse connected to the Lamp---on most (What is model number?) that will result in shutdown and a 3 blink error code on the front of the TV.
Mar 19, 2012 | Sony Televison & Video
I just recently changed my lamp in my hitachi 50 VF 820 and the screen has a large blue spot on it. I have done it before once or twice and all went well. Did I possibly put the bulb in incorrectly or is...
No. If the set turns on and you have a picture, the lamp is installed properly. Most of the time the optical block is the issue. The lamp shines directly into it. If the picture was good before the lamp was replaced, it is possible that that replacing the lamp might have dislodged some micro dust build up internal to the optical block and it landed in a concentrated area causing the red and green lcd panels not to pass light through as bright as the blue giving you a blue spot. Unfortunately the optical blocks are not designed to be taken apart to clean. Replacing the optical blocks are expensive. Most costing in the area of $700.00 to $1200.00 for the part. It also is a major tear down to get to the optical block to replace it. Once upon a time Hitachi had a couple of recalls on their optical blocks for various models. I do not know however if this qualified.
I hope this helps,
Skyassoc
Jan 06, 2011 | Hitachi 50VF820 Projection TV
Tv won't turn on 4 blinking led
Red led blinks 4 times is an error code that shows that fan is not running in tv, check fans connections and make sure all are plugged properly.
Thanks.
Jul 18, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
How do I change the optical block in a sony tv
Disconnecting wiring from power supply block
This step may be optional, if power supply block must be transferred to purchased replacement optical block. Undo the blue plastic-coated wire holders to release the two wire bundles. Disconnect the connectors shown with the dotted lines in the photo below. One, which presumably provides power, is disconnected directly from the power supply block, and the other is a regular wire connector.a837b7e.jpg
moz-screenshot-2.pngDisconnecting the optical block fan wires
Disconnect the optical block fan wire connector:
Disconnecting the wiring from the optical block circuit board (C Board)
Carefully pull up on the three wire connectors directly connected to the top of the C Board:
Final wire disconnection from C Board
Remove the screw and gently pull the blue ribbon ribbon cable out of the side of the C Board:
Your optical block should now be entirely free of the TV and ready to ship. I recommend adding specific protection for the projection lens, then sealing the whole unit in a bag to prevent infiltration of dust or packing materials, then carefully packaging it with substantial padding.
Removing the projection lamp (in cases where you are installing a purchased replacement optical block)
Loosen the hex screw next to the projection lamp housing, and pull the lamp and housing outward from the metal clips.
Picture of replacement optical block for KF-60WE610 (courtesy John Setar)
Here is a picture of a replacement optical block for the KF-60WE610. Note that some parts of the old optical block need to be removed and installed on the replacement block.
Jan 25, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Faint blue "cloud" on upper left screen duriing viewing
I hesitate to tell you this for fear of a bad rating from you, but it is likely the optical block is the source of your problem. Sony was covering replacement of the optical block for this unit until June of 2008, but that warranty extension has expired. I would suggest you contact Sony customer support at 800-222-SONY to see if they will allow for some type of accommodation to cover either the parts, the labor or some portion thereof. Sorry!
Nov 07, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
GHOSTING
Hey joseph, actually replacing the optical Block is not necessary at all, all you need to do is get into the "Service Mode" of the Tv and change a few setting around, did it a few weeks ago and now my TV looks perfect, no reason to waster $1200 as sony is trying to get over on all us consumers.
Oct 29, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
Please help-question about sony optical blocks
Talk to Sony about the blue blob issue, they may still replace the optical block for free.
If not, fix the blinking light TV.
Blink Codes
3X - Lamp cover not installed correctly, usually after lamp change, or cover detect switch is bad.
4X - Check fans (one or more failed to pass RPM test during power on diagnostics)
5X - Lamp ballast (power supply)
6X - Usually the thermal fuse - usually from inadequate air flow (fans dusty)
All other codes usually require a trained technician to diagnose and repair.
Oct 29, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
SONY KDF-E55A20
No it sounds like the thermal fuse.
Apr 14, 2008 | Sony KDF-E55A20 55 in. LCD Television
6 red light blinks-possible thermal fuse prob.
The thermal fuse is located under the optical block. However the optical block needs to be removed to replace it. So unless you are very familiar with the disassembly of this tv I suggest you have a Sony ASC to do the repair work for you. You don't want to take a chance of damaging the optical block.
Jan 28, 2008 | Sony KDF-E55A20 55 in. LCD Television
55 in Sony KDF55WF655 Goes to standby and red light blinks 4 times
Check the thermal sensor fuse part# 1-910-023-93 or possibly one of the four fans. If the unit goes into Fan/Thermal Protect shutdown (4 blinks) it can be difficult to determine the cause since the unit turns off too quickly to troubleshoot. Solution: Ground the data line by inserting a jumper between pins 3 and 6 of CN44 on the H4 board. This overrides the protection circuits for troubleshooting. Do this right after turning the unit on and as soon as the lamp is seen lighting. Check pins 2, 5, 8, and 11 of CN6000 on the G2 board for less than 1VDC. Any voltage higher than that indicates a faulty fan. If all voltages are within specs, the H4 board must be replaced. If a fan is found defective, the optical block will need to be replaced if it is located inside the assembly. H4 Board Part Number: A1054674A Replace the following part based on which pin of CN6000 is out of specs: Pin 2: Fan 1 (part of optical block) Pin 5: Fan 2 178723211 Pin 8: Fan 3 178706511 Pin 11: Fan 4 178708111 Optical block Part Number: A1084662A
Aug 26, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV Logo
162 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
