Question about Canon ImageClass MF4570DN Laser Printer
I have a new printer canon mf 4750dn red light was flasing re low toner changed toner and still flashes, prints ok but sure about faxes coming in as of yet
This printer is only 4 mths old bought new, with orig toner, i gather it was getting low since i got over 900 pages of print out of the orig toner. But now that i have replaced the toner with a new one the red light keeps blinking and telling me that the toner is low. which we know it isnt'.. how do you correct this blinking light to shut off
MrARCADIAN
  • 284 Answers
SOURCE: canon mf 6550
The laser Apeture is sticking.
What i did to mine it Sorta hit it on the paper side and caused the shutter to start working
if you take the toner and use a screwdriver to push down the shutter, it will start working again.
the shutter is sticking.
Posted on Jul 15, 2008
SOURCE: CANON MF4140 'LOAD CORRECT PAPER CASSETTE : LTR'
I had the same cr@p of the problem yesterday. The problem was not in the paper. You have to do 2 simple things, from which one will solve the problem.
first, download the latest drivers and install them.
And the more important thing, the problem occurred due to incorrect paper format. Solution is very simple. Open MS word or something similar, file->print.. and before you print open Properties menu. There for the Output Size will be selected "Match Page Size". you don't want that (i don't know why it doesn't work), but the solution is manually select A4, or whatever your page size is.
Posted on Dec 27, 2008
I had the same cr@p of the problem yesterday. The problem was not inthe paper. You have to do 2 simple things, from which one will solvethe problem.
And the more important thing, the problem occurred due to incorrectpaper format. Solution is very simple. Open MS word or somethingsimilar, file->print.. and before you print open Properties menu.There for the Output Size will be selected "Match Page Size". you don'twant that (i don't know why it doesn't work), but the solution ismanually select A4, or whatever your page size is.
And there it is... printer starts throwing pages out like crazy :)))
sitehr
  • 94 Answers
SOURCE: D880 printer won't put toner on the paper (prints blank)
make sure the replaced toner is in good condition and is placed properly in printer refilled toner often alarm about low ink but work properly
Posted on Jul 22, 2009
SOURCE: canon mf 6550 copy no print out its came out empty page
We had the same problem with our mf6550 printing blank pages after we changed the toner cartridge. I called the support desk today and they said it is the shutter. They told me to remove the toner cartridge and then (without a cartridge in) close the door briskly. Then open the door, install the cartridge and again close the door briskly. It worked! He said it may be a permanent fix or it may act up again. He also said I could take it to a service center to have it fixed permanently. The service desk # is 1-800-828-4040. They can tell you where the nearest service center is. Good luck.
Posted on Dec 31, 2009
Out of Toner / Change Toner - Canon image CLASS MF4370dn
The percentage-of-available-toner is based on calculations made by the printer's internal software -- quite different from putting a measuring-stick into an above-ground oil-tank to determine the ACTUAL level.
So, while the calculations say "zero percent left", there still is some toner inside the toner-cartridge, and so it still prints.
Buy a replacement cartridge. When you finally do run-out of toner, install the new cartridge.
Compare it to buying a new quart of milk, and then using the last 1/8 of the quart of the milk currently inside your refrigerator -- use the "old" milk until it is 100% gone, and then switch to the "new" milk.
Mar 11, 2014 | Canon imageCLASS MF4370dn...
Konica Minolta 1690 MF printer says TOner Cartrdige YM is out. I haven;t had the printer that long and have printed less than 1,000 pages.
Hi there, A lot of the new Printer/Multifunctional/Fax Machines nowadays come out with only demo Toner/Cartridges which are not completely full so there average yield is very low. The average yield for your Toner Cartridges should be around 2500 Pages but this is a measurement when you basically print in draft and with toner saving on. The moment you start using colours more intensely the yield will drop drastically.
Regards,
Jul 27, 2011 | Konica Minolta magicolor 1690MF All-In-One...
Canon image class MF 4150: it is flashing, message says toner is not set insert toner. Toner has been inserted, it was working this morning, I printed documents fine, now this message. I have taken the...
spacer.gif If you removed and reinstalled toner correctly several times and this error code is flashing, you need to try another new toner cartridge, even though the other one may seem still good to you. If this doesn't remedy problem the Troubleshooting section of the Canonusa.com website says to call 1-800-OK-CANON.
Jul 16, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
Canon mf 6540 copies come out uneven
Did you clean beneath copy glass ( adf copy glass and platen )?Did you clean scaner also?
Clean the laser unit.
Not genuine toner isnt best solution.
Try to print something.If the print is OK, then the problem is in copy glass and scaner.
Jul 02, 2010 | Canon ImageClass MF6540 Copier
Hl-1440 printer red, yellow lights keep flashing on and off prints ok what is it
Normally nothing to e alarmed about. As you said, it still appera to print okay. This flasing is a warning that your toner is low and will soon need to be replaced. If you recently replaced the toner artridge and know this not to be the case, print out a supplies status page from the onboard menu to see if it show low. Sometimes we are not aware of how much we have printed, hence the warning and the printer is usually right.
Apr 27, 2010 | Brother HL 1440 Laser Printer
Canon ImageClass MF 6550 Error Toner Low- Prepare New Toner
There are two contact on the right wall off the printer cartridge chamber area. They can get pushed in causing the printer cartridge to not read correctly. Take a small Flathead screwdriver and bend them up so the cartridge ink level can be read.
Dec 17, 2008 | Canon imageCLASS MF6530 Monochrome Laser...
Poor print quality like toner low, but toner quanity is fine.
this sounds to me like it could possibly be stemming from the fuser, this is quite common on fuser that use a thin film belt for the heat roller...
May 08, 2008 | Brother MFC 7420 All-In-One Laser Printer
I had same thing happen after a fresh Windows install. It was hard to figure out since it had been working fine until then, but luckily it is simple to fix. Open the Start Menu > Settings > Printers and Faxes folder. Then right-click on the Canon MF4100 Series printer and choose Printing Preferences. In there, change the Paper Size to Letter (instead of A4). You may also have to do this in the Print setup for whatever program you're using to print.
Sep 11, 2007 | Canon i-SENSYS MF4140 All-In-One Laser...
Canon ImageClass MF4570DN Laser Printer Logo
281 people viewed this question
old marine
old marine
