Question about Home
1 handle shower tub for eljer low water pressure
  • 14 Answers
SOURCE: moen single handle valve tub/shower
The Moen Posi-Temp Valve is a pressure balanced valve and when not used for long periods of time they can stick causing only cold or hot water to pass through the valve.
A New Posi-temp cartridges can be purchased at most plumbing supply houses or big box outlets such as Lowes or Home Depot.
As long as you had cold water before, a new cartridge will solve the problem. In the future it would be wise to occassionally operate the valve at least a couple of times a month in order to keep the pressure assembly from becoming lodged in position. Just follow the instructions included with the new cartridge on the proper removal of the old cartridge and the installation of the new cartridge. a little silicone grease inside of the valve before installing the new cartridge will also help.
Be sure that there is no particles of the old cartridge left in the valve.
sanray
Posted on Dec 27, 2008
  • 102 Answers
SOURCE: low water flow in Shower
Definitely try reversing the cartridge.
Posted on Mar 11, 2009
  • 49 Answers
SOURCE: Moen shower/tub faucet
hi... yes that's a very common issue with moen "cartridges" -- it's very simple to fix..... grasp the handle and give it a gentle tug upwards when the water is on... if it retracts again, pull the handle out again and tug again but this time a bit harder. Not sure what causes this on new cartridges but it will fix your issue.
Posted on Sep 03, 2009
  • 35 Answers
SOURCE: shower diverter push handle is squirting water out
If you are handy, the best solution is to call delta and have them send you a new diverter. They will need the model of your faucet. The new diverter will come with instructions on the install process. As far as fixing it without the new diverter, I don't believe you will be able to.
Posted on Nov 18, 2009
jeff_drakesr
  • 155 Answers
SOURCE: no cold water from Moen 2253 tub/shower valve,
Here is a quick check to see if the cartridge may be at fault allowing the cold and hot to mix. Turn off the hot water supply, with hot water supply off turn faucet on. Turn to the hot and cold sides, If you have only cold water then your faucet cartridge is at fault or the cartridge housing is worn. Shut all supply valves and remove cartridge and inspect housing for signs of wear. If wear is visible a new shower valve is needes. If none visible replace cartridge. I have included a link of a PDF file an exploded parts list. I hope this helps in solving your problem. Please rate if the answer helps in any way. Good Luck and have a great week. Jeff
Posted on Apr 05, 2010
Hot water pressure is weak. Shower head isn't clogged. Cold water pressure is good. How do I increase the hot water pressure?
Is the hot water pressure good at other fixtures in the house? I'm guessing your newer valves have a scolding adjustment that is set very low. Check the instructions that came with the valve assembly.
Feb 10, 2016 | Danze & Single Handle Tub And Shower...
Low water pressure with Jado
On the cartidge there should be a little stopper on the stem that sticks out where the handle goes on ( this prevents the handle from going all the way up ) try repositioning this stopper. good luck
Jun 22, 2012 | Jado Shower Valve Trim Perlrand ...
Danze opulence diverter handle does not work
you have to replace diverter....if its in the tub spout unscrew and go to lowes or plumbing supply and match up style and replace...use pipe dope and screw back on tight...good luck
May 01, 2012 | Danze & Single Handle Tub And Shower...
When i'm filling the tub with water, the water back feeds up to the shower head and sprays out. I changed the spout and also moved the shower knob to make sure it wasn't stuck in the up position for the...
You will have water coming out of the shower head when you have really good water pressure. There might be more water volume coming out through the valve then what the tub spout can handle and in turn sends the water up to your shower head. When you fill your tub try turning the water only half way on not at full pressure, does this keep the water from coming out of the shower head? Most likely your valve has a 3/4" supply line while your shower head and tub have only a 1/2" supply line. Sounds like you have more volume to the valve than what the tub spout can handle. You might consider one of two things: 1) you can put a water regulator on the main supply line going into the house to lower your pressure, or 2) change out the supply line to the tub spout, increasing it from 1/2" to 3/4". Let me know whats going on.
Dec 03, 2010 | Delta Home
The shower has very low pressure in the cold water and hot water is fine
If at one time there was good pressure on the cold water shut of water supply remove the cartridge from the valve (under the handle) and then turn the supply back on (just alittle) to flush out and reinstall. I hope this has been helpful if I can help further please let me know. Please rate if the information has been helpful. Good Luck and have a great weekend.
Apr 02, 2010 | Moen & One Handle Tub & Shower Faucet
My moen shower faucet has low hot pressure and high cold pressure.
Either your water softener has a clog or your hot water tank has sediment build up in it.Either way your looking at have a licensed plumer come out and give you an evaluation.
Mar 20, 2010 | Moen & One Handle Tub & Shower Faucet
Shower/Tub Diverter Value Low Water Pressure
I had the same problem. I discovered that an O ring was missing (or I lost it without noticing) from a new diverter that I installed. Just got an O ring that fits on the threaded part of the collar where it meets the pipe. Worked fine. Amazing how a little plastic piece could make such a difference.
Jan 25, 2010 | Eljer Arlington Non-Jetted Acrylic Bath...
Low pressure in the shower
if the regular tub faucet has normal pressure, then carefully remove the shower head and soak it in de-limer and rinse in clear water before using again
Oct 26, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Low water flow in Shower
Mar 11, 2009 | Moen & One Handle Tub & Shower Faucet
Home Logo
43 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
