Question about HTC Desire Cell Phone
It is showing red coloured beam or you can say light in the four side whenever i connect to internet or try to call someone or use my gallery or any other stuffs
It is showing red colored beam or you can say light in the four side whenever i connect to internet or try to call someone or use my gallery or any other stuffs the light appears and fast it disapears within seconds like how it is showing some warning
    New Friend:
  • 3 Answers
Its just your phones theme.dont worry about it
Posted on Jan 10, 2013
  • robin Jan 10, 2013
    i buyed this phone on this past sunday but on wenesday the problem started when i connected my device on my office computer or i eas updating my phome at that some thing might have happened ????
I have a 96 barina 3 door city and the low beam headlights refuse to work high beam and parkers are fine have replace indicator head light stalk switch but am now wondering if it may have some thing to do...
have you checked the bulbs low beam can blow and high beam will still work take head light bulb out and make sure both springs in side the bulb are attached the bulb will also show a blue burnt looking colour if blown
Mar 25, 2015 | Holden Barina Cars & Trucks
I have tried hundreds of times to connect to the internet and the same thing shows up every time error code 052000-1 please help me fix my dsi
What is a "dsi"? You have to be very specific when you ask questions on a forum like this. We aren't mind readers.
Jun 19, 2014 | Nintendo DSi Black Console
Hi. I am charging up my battery for my Harley and am using an oxford oximiser 600, but have lost the instructions. I would like to know what the two lights are to either side of the four lights. They...
You have the four coloured lights to show battery state Red - irrecoverable; Orange - 3 to 6 Volts in the battery, Oximiser will attempt recovery; Yellow - 6 to 12 Volts in the battery, Oximiser will charge and and optimise and Green - Full charge, about 14 V, the Oximiser will maintain the charge.
On the left of this you have a Green light to show that the Oximiser is connected to the mains and on the right you have a Red light to show that you have connected the charging leads thewrong way around, i.e. the positive charging lead is on the negative terminal and the negative charging lead is on the positive terminal. This light should be off.
Sep 29, 2010 | Harley Davidson FLSTC Heritage Softail...
Where do I find the meaning of various lights on the dashboard?
hi, all lights the first and important battery light this shows RED when the alternator NOT carging:
the oil light shows ORANGE LOW on oil:
the engine managment light shows when engine sensors detect faults shaped like an engine ORANGE light
head main beam BLUE when ON MAIN BEAM
indicator FLASHING GREEN light
hazard warning RED light
brake fluid low light RED looks like this ( )
brake handbrake ON RED light looks like this ( )
side light GREEN looks like a star
most of the important lights are RED or ORONGE gerry
Sep 10, 2010 | 2007 Toyota Sienna
No low beams toyota tercel
Check that there is not a relay on the low beam circut, you should find the relay for this in the engine bay area. Also check for a separate mounted relay which may have been fitted to allow larger wattage headlight bulbs to be fitted. I hope this helps, let me know how you get on.
Jason
Apr 04, 2010 | 1991 Toyota Tercel
Where is the internet light?
i believe all laptops doesnt have internet light
TIPS:
--whenever you plugged the ethernet cable on your laptop ethernet port you'll notice that the computer icon on the lower right side will show that there is no more red x on it and when you point the cursor on it it will show "CONNECTED"
Mar 27, 2010 | Toshiba Satellite L305D-S5874 Laptop
My omnitech monitor is turning red when it wants to. no certain program just whenever
Colours on the screen are generated by "mixing" the 3 primary colours.
Of the primary colours is RED.
So, your LCD monitor is not receiving signals from your computer,
specifying the other two primary colours.
Check the data-cable between your computer and your monitor,
to ensure that the connections are tight at both ends.
Try a different data-cable.
Try your monitor on a different computer, with two different data-cables.
Try a different monitor on your computer.
It could be the video-card inside your computer is failing to "send" one or two of the primary colours.
Dec 31, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
No Hi Beam on 93 Camry
The headlamp circuit is rather simple. From the 15 amp RH headlamp fuse, there is a red w/yellow trace that goes to the RH high beam. Out of the 15 amp LH headlamp fuse, the wire going to the LH Hi beam is solid red. Both of these wires should have power when the headlamp relay is energized. The wires from the Hi Beam bulbs going back to the switch should both be red w/black trace. The wire going from the headlamp relay to power the 2 15 amp fuses is white. The headlamp switch applies a ground to illuminate either the Lo Beams or the Hi Beams.
Sep 10, 2008 | 1993 Toyota Camry V6
Monitor goes into standby when RS232<>TTL cable connected
Use original software for the device. Check to see if monitor is compatible with the motherboard
Sep 05, 2017 | Dell P1110 21" CRT Monitor
HTC Desire Cell Phone Logo
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
ChuckyMo
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
